    Show calendar based on IP Address accessed
    68 Posts 3 Posters 34.1k Views 3 Watching
      Spinster @MMRIZE
      @MMRIZE
      After installing MonkeyPatch and adding the patch you have mentioned, I get the following error message when I run , npm run config:check
      [2024-05-07 23:32:55.179] [INFO] Checking file… /home/vjkings/MagicMirror/config/config.js
      [2024-05-07 23:32:55.222] [ERROR] Your configuration file contains syntax errors :(
      [2024-05-07 23:32:55.223] [ERROR] Line 56 column 20: Parsing error: Unexpected token function
      As per config.js, Line 56 is this
      patch: async function (original, args) {
      Whole section of patch as follows
      const [ notification, payload ] = args
      if (notification === “CALENDAR_EVENTS”) {
      const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
      const r = await fetch(‘http://192.168.1.4:8080/modules/getip’)
      const ip = JSON.parse(await r.text())?.[ ‘address’ ] ?? null
      if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
      return original(notification, { …payload, events: [] })
      return original(notification, payload)
      If I ignore the error and run the server, I don’t get any calendar and it just says Loading… in the mirror page
      What is the reason for the error. Please advice
        Spinster @sdetweil
        Wow, Clear, will try it and provide feedback please.
          Spinster @sdetweil
          I made all the changes you have mentioned, it is working!!!. Thank you so much for the efforts.
          However, following are the observation,
          When I add the config.js with useIPAddress: true (calendar.js has the entry of useIPAddress:false in its default), there is no effect, however in calendar.js if I set the useIPAddress: true, it is working, I don’t understand why the configuration settings are not taken.
          I clearly added the useIPAddress: true before the calendars declared as part of the module configuration. Please advice how to fix this.
          I also have doubt on when we override the start to startup, how the notificationreceived is called. What happens when there is no start in the module.
          In fact this is the first time, I have added code without understanding of anything :).
          Please help me with configuration settings (config.js) to get it effected than hardcoding it to calendar.js
            sdetweil @Spinster
            @Spinster can you show the calendar config, you can leave out the calendars:[] list entries
            start is optional. but only called once
            getip has not placed its content yet.
            the notification ALL_MODULES_STARTED is sent be the system when all the
            modules start methods have been called
            from the module development doc
              Spinster @sdetweil
              Thank you for the details.
              As required, my calendar config as follows
              		module: "getip",
              		position:"bottom_left"
              		useIPAddress: true,
              		header: "My Calendars",
              					fetchInterval: 5 * 60 * 1000,
              					symbol: "calendar-check",
              					url: "https://mycalendar/xEzboFt7Kr3Yfiys?export",
              					ipaddress: "10.5.18.252 127.0.0.1 10.5.14.104",
              					fetchInterval: 10 * 60 * 1000,
              					//useIPAddress: true,
              					url: "https://mycalendar/4aK7xZPQkGKz6nCZ?export",
              					ipaddress: "10.5.11.5",
              Please let me know if I have done any mistake
                sdetweil @Spinster
                @Spinster yes, it has to be inside the
                config:{} section
                everything outside config are MagicMirror properties about a module
                see
                https://docs.magicmirror.builders/modules/configuration.html#example
                config is properties FOR the module and override what is defined in the module defaults:{} object
                  Spinster @sdetweil
                  I made the change and it first showed correctly, but when I refresh any one of the client, the other client is getting both the calendars. What is wrong? Here is my updated calendar.js as suggested by you.
                  /* global CalendarUtils */
                  Module.register("calendar", {
                  	// Define module defaults
                  	defaults: {
                  		maximumEntries: 10, // Total Maximum Entries
                  		maximumNumberOfDays: 365,
                  		limitDays: 0, // Limit the number of days shown, 0 = no limit
                  		pastDaysCount: 0,
                  		displaySymbol: true,
                  		defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                  		defaultSymbolClassName: "fas fa-fw fa-",
                  		showLocation: false,
                  		displayRepeatingCountTitle: false,
                  		defaultRepeatingCountTitle: "",
                  		maxTitleLength: 25,
                  		maxLocationTitleLength: 25,
                  		wrapEvents: false, // Wrap events to multiple lines breaking at maxTitleLength
                  		wrapLocationEvents: false,
                  		maxTitleLines: 3,
                  		maxEventTitleLines: 3,
                  		fetchInterval: 60 * 60 * 1000, // Update every hour
                  		animationSpeed: 2000,
                  		fade: true,
                  		fadePoint: 0.25, // Start on 1/4th of the list.
                  		urgency: 7,
                  		timeFormat: "relative",
                  		dateFormat: "MMM Do",
                  		dateEndFormat: "LT",
                  		fullDayEventDateFormat: "MMM Do",
                  		showEnd: false,
                  		getRelative: 6,
                  		hidePrivate: false,
                  		hideOngoing: false,
                  		hideTime: false,
                  		hideDuplicates: true,
                  		showTimeToday: false,
                  		colored: false,
                  		forceUseCurrentTime: false,
                  		tableClass: "small",
                  				symbol: "calendar-alt",
                  				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                  		customEvents: [
                  			// Array of {keyword: "", symbol: "", color: "", eventClass: ""} where Keyword is a regexp and symbol/color/eventClass are to be applied for matched
                  			{ keyword: ".*", transform: { search: "De verjaardag van ", replace: "" } },
                  			{ keyword: ".*", transform: { search: "'s birthday", replace: "" } }
                  		locationTitleReplace: {
                  			"street ": ""
                  		broadcastEvents: true,
                  		excludedEvents: [],
                  		sliceMultiDayEvents: false,
                  		broadcastPastEvents: false,
                  		nextDaysRelative: false,
                  		selfSignedCert: false,
                  		coloredText: false,
                  		coloredBorder: false,
                  		coloredSymbol: false,
                  		coloredBackground: false,
                  		limitDaysNeverSkip: false,
                  		flipDateHeaderTitle: false,
                  		updateOnFetch: true,
                  		useIPAddress: false,// add config var
                  	timerHandle:null,                 // add this
                  	ourIPAddress:null,              // add this
                  	requiresVersion: "2.1.0",
                  	// Define required scripts.
                  	getStyles () {
                  		return ["calendar.css", "font-awesome.css"];
                  	getScripts () {
                  		return ["calendarutils.js", "moment.js"];
                  	// Define required translations.
                  	getTranslations () {
                  		// The translations for the default modules are defined in the core translation files.
                  		// Therefore we can just return false. Otherwise we should have returned a dictionary.
                  		// If you're trying to build your own module including translations, check out the documentation.
                  		return false;
                  	// Override start method.
                  	startup () {
                  		//const ip = settings.detectIp(req)
                  		Log.info(`Starting module: ${this.name}`);
                  		Log.info(`Vijay starup Starting module: ${this.name}`);
                  		if (this.config.colored) {
                  			Log.warn("Your are using the deprecated config values 'colored'. Please switch to 'coloredSymbol' & 'coloredText'!");
                  			this.config.coloredText = true;
                  			this.config.coloredSymbol = true;
                  		if (this.config.coloredSymbolOnly) {
                  			Log.warn("Your are using the deprecated config values 'coloredSymbolOnly'. Please switch to 'coloredSymbol' & 'coloredText'!");
                  			this.config.coloredText = false;
                  		// Set locale.
                  		moment.updateLocale(config.language, CalendarUtils.getLocaleSpecification(config.timeFormat));
                  		// clear data holder before start
                  		this.calendarData = {};
                  		// indicate no data available yet
                  		this.loaded = false;
                  		// data holder of calendar url. Avoid fade out/in on updateDom (one for each calendar update)
                  		this.calendarDisplayer = {};
                  		this.config.calendars.forEach((calendar) => {
                  			calendar.url = calendar.url.replace("webcal://", "http://");
                  			const calendarConfig = {
                  				maximumEntries: calendar.maximumEntries,
                  				maximumNumberOfDays: calendar.maximumNumberOfDays,
                  				pastDaysCount: calendar.pastDaysCount,
                  				broadcastPastEvents: calendar.broadcastPastEvents,
                  				selfSignedCert: calendar.selfSignedCert,
                  				excludedEvents: calendar.excludedEvents,
                  				fetchInterval: calendar.fetchInterval
                  			if (typeof calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                  				calendarConfig.symbolClass = "";
                  			if (typeof calendar.titleClass === "undefined" || calendar.titleClass === null) {
                  				calendarConfig.titleClass = "";
                  			if (typeof calendar.timeClass === "undefined" || calendar.timeClass === null) {
                  				calendarConfig.timeClass = "";
                  			// we check user and password here for backwards compatibility with old configs
                  			if (calendar.user && calendar.pass) {
                  				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                  				Log.warn("https://docs.magicmirror.builders/modules/calendar.html#configuration-options");
                  				calendar.auth = {
                  					user: calendar.user,
                  					pass: calendar.pass
                  			let ip_match = false;
                  			if(this.config.useIPAddress){
                  			 const client_ip_for_this_calendar = this.getCalendarProperty(calendar.url, "ipaddress", null)
                  			 if(this.ourIPAddress)
                  			 	  ip_match = client_ip_for_this_calendar.includes(this.ourIPAddress)
                  			if(this.config.useIPAddress == false || ip_match==true)
                  			  this.addCalendar(calendar.url, calendar.auth, calendarConfig);   // old original   line
                  			//this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                  		// for backward compatibility titleReplace
                  		if (typeof this.config.titleReplace !== "undefined") {
                  			Log.warn("Deprecation warning: Please consider upgrading your calendar titleReplace configuration to customEvents.");
                  			for (const [titlesearchstr, titlereplacestr] of Object.entries(this.config.titleReplace)) {
                  				this.config.customEvents.push({ keyword: ".*", transform: { search: titlesearchstr, replace: titlereplacestr } });
                  		this.selfUpdate();
                  	// Override socket notification handler.
                  	socketNotificationReceived (notification, payload) {
                  		if (notification === "FETCH_CALENDAR") {
                  			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier });
                  		if (this.identifier !== payload.id) {
                  			return;
                  		if (notification === "CALENDAR_EVENTS") {
                  			Log.warn("Calendar Events called Vijay");
                  			if (this.hasCalendarURL(payload.url)) {
                  				this.calendarData[payload.url] = payload.events;
                  				this.error = null;
                  				this.loaded = true;
                  				if (this.config.broadcastEvents) {
                  					this.broadcastEvents();
                  				if (!this.config.updateOnFetch) {
                  					if (this.calendarDisplayer[payload.url] === undefined) {
                  						// calendar will never displayed, so display it
                  						this.updateDom(this.config.animationSpeed);
                  						// set this calendar as displayed
                  						this.calendarDisplayer[payload.url] = true;
                  					} else {
                  						Log.debug("[Calendar] DOM not updated waiting self update()");
                  					return;
                  		} else if (notification === "CALENDAR_ERROR") {
                  			let error_message = this.translate(payload.error_type);
                  			this.error = this.translate("MODULE_CONFIG_ERROR", { MODULE_NAME: this.name, ERROR: error_message });
                  			this.loaded = true;
                  	eventEndingWithinNextFullTimeUnit (event, ONE_DAY) {
                  		const now = new Date();
                  		return event.endDate - now <= ONE_DAY;
                  	notificationReceived(notification,payload){
                  		if(notification === 'ALL_MODULES_STARTED') {
                  			// if we are using ip address checking
                  			Log.info(`Vijay Calling : ${this.name}`);
                  			console.log("Vijay : Calendar notificationReceived called");
                  				console.log("Vijay : Calendar Using IP Address");
                  				// find our dependent module in config.js, returns an array []
                  				let m = MM.getModules().withClass("getip");
                  				if(m.length){
                  					// if getip is not disabled
                  					if((m[0].disabled == undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                  						// start a timer to wait for getip to finish
                  						this.timerHandle = setInterval(()=>{
                  							// get its dom content
                  							let client_ip = document.getElementById("getip_address")
                  							// if we found id
                  							if(client_ip !== null){
                  								// stop the timer
                  								clearInterval(this.timerHandle)
                  								// save our IP address, only need to look it up once
                  								this.ourIPAddress=client_ip.innerText
                  								// call startup
                  								this.startup()
                  						}, 500)
                  				// didn't start a timer, module not found
                  				  if(this.timerHandle === null){
                  						// didn't find getip
                  						// module not found, can't do this later either
                  						// turn off address checking
                  						this.config.useIPAddress = false;
                  						// start fetching calendars
                  						Log.info(`Vijay No timer, useIP set to false: ${this.name}`);
                  						this.startup()
                  			// use old approach
                  			else{
                  				Log.info(`Vijay timer available :  ${this.name}`);
                  				this.startup()
                  Please let me know if I have to do something about this.
                    sdetweil @Spinster
                    @Spinster sorry, explain
                    the other client
                    on refresh, everything is the same in the module.
                    each module has a unique id assigned, based on its placement in config.js
                    calendar sends its id down to its helper
                    and the helper sends the id back on response. as the response mechanism is a broadcast to all connected clients.
                    the clients then check to see if this response is for their request.
                    from code posted
                    also, please start using code block wrapper for all config, code and error postings
                    paste text into the message editor
                    empty line above and below
                    select that pasted text
                    hit the editor button </>
                      Spinster @sdetweil
                      Sorry for not explaining it clearly.
                      I have two clients, one from a browser using http://ip:8080 and another the native client.
                      upon using pm2 start MagicMirror, I get the out put in native client and the browser properly showing their respective calendar.
                      If I hit refresh button on browser, browser is showing only its own calendar however the native client is displaying both the calendars (ie. its own and the one which is supposed to be shown in browser), If I hit Ctr-R on the native client, then browser is showing both the calendars while the native client is showing only its own calendar.
                      Also I don’t understand the following instructions, please explain what should I do
                        sdetweil @Spinster
                        @Spinster said in Show calendar based on IP Address accessed:
                        when creating a message here on the forum, if you are inserting code, config, or error text (like you did when u pasted the whole calendar.js, or the part of the module config)
                        do the instructions I gave
                          @Spinster I rejected your post (AND a second time) . I already fixed the prior
                          AND you left your unique info in the module info…
                          anyhow…
                          found the issue… the ‘identifier’ is based on placement in config.js SO, it will be the SAME on both browsers… oops…
                          here are the two lines to fix
                          1. in the socketNotificationReceived function
                            change this
                          			return;
                          to this
                          		if (this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') !== payload.id) {
                          			return;
                          and 2.
                          in the addCalendar routine
                          change this
                          to this
                            Spinster @sdetweil
                            You did it! Excellent, I really appreciate your versatility and quick response.
                            Hope this shall become a feature for the calendar or any other modules if anyone has similar requirement and prefers it.
                            Sincere Thanks to you and gratitude for your effort and time~
                              sdetweil @Spinster
                              @Spinster I don’t know if this will become a feature… but at least you know how to add it for your environment
                              if it was a feature, I would recommend adding the getip rest api call to the base MM code.
                              I updated the prior code changes to include these latest , so its all in one place
                              it was a fun, thought provoking, exercise.
                                @Spinster another conversation highlighted another change required
                                and a bug
                                I’ll update my code here later
                                oh, and to help you, you could fork the MagicMirror repo
                                and use it, adding this code,
                                and saving to the repo, so next update
                                you can sync the fork and git pull to your system
                                sorry my new phone and thumb don’t agree where the keys are… lol and correction never gets it right
                                  Spinster @sdetweil
                                  I can’t thank you much for your sincerity in making it correct. Looking forward to the updated code.
                                  I will try to contribute too in future like you.
                                  Thank you once again.
                                    sdetweil @Spinster
                                    @Spinster
                                    SO, the ‘bug’ is that this notification , added in pull request 2881 in
                                    https://github.com/MagicMirrorOrg/MagicMirror/pull/2881
                                    in August 2022
                                    edit: I just opened issue 3443 for this problem
                                    https://github.com/MagicMirrorOrg/MagicMirror/issues/3443
                                    added the code in the WRONG place… socketNotificationReceived is ONLY triggered by the node_helper sendSocketNotification,
                                    NOT by other modules doing sendNotification
                                    NO OTHER module can force a sendSocketNotification from our helper
                                    THAT is notificationReceived… (which we JUST added for the 1st time… oops)
                                    So,
                                    remove this
                                    and move it to the notificationReceived() function
                                    @sdetweil said in Show calendar based on IP Address accessed:
                                     	if(notification === 'ALL_MODULES_STARTED'){
                                            }  else  if (notification === "FETCH_CALENDAR") {
                                    and THEN we need to change the this.identifier to account for the ip based ID, so if some OTHER module
                                    asks THIS calendar instance to refresh ITS data, it asks for the correct content
                                            	this.sendSocketNotification(notification, { url: payload.url, id: this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') });
                                    I’ll add this to the other code, done … I’ll leave the explanation here
                                      Spinster @sdetweil
                                      Perfect, I did this. Thank you so much for your timely help.
                                      Now I am trying to do the same thing in MMM-CalendarEtx2. Because, I want a proper Month Calendar, which is not provided by Calendar.
                                      Is there any module which can display two month calendar, since I searched in modules and could not find.
                                        sdetweil @Spinster
                                        @Spinster ext2 is dead. use ext3, it uses the broadcast from the default calendar module which now is just those for this system
                                        uh, hard to put up one wall cal view, 2 I don’t know.
                                        remove position from default cal, it won’t display but will send it broadcast
                                          Spinster @sdetweil
                                          Oh I did not know, but ext3, I don’t see an option to view a month calendar (not month schedule). I am looking for something like MMM-CalendarExtMiniMonth. Please let me know if this option is available
                                            Spinster @sdetweil
                                            Okay will try it. Thank you.
                                            • 3 / 4
