    Show calendar based on IP Address accessed
    68 Posts 3 Posters 33.3k Views 3 Watching
      Spinster @MMRIZE
      @MMRIZE Browser as of now.
      I also tried using express ipfilter, but the problem is I don’t know how to use it in module.js, it is throwing error saying ipfilter not known etc
        sdetweil @Spinster
        @Spinster well, here is a working example, in addition to the other code already
        watch out if using address AND MM host system not included. as it won’t show either…
        one could make the ipaddress in cal a list (of ip addresses) similar to what @MMRIZE does…
        I don’t like adding the extra block,
        just add the var to the thing that matters…
        see later post
          MMRIZE @Spinster
          @Spinster
          With getip of @sdetweil and MMM-ModuleMonkeyPatch, I did it. (You don’t have to modify the original source code for future-proof.)
          Example.
          Server is running on 192.168.178.63 and I run 2 clients on 192.168.178.22 and 192.168.178.63.
          Both 2 clients can show different set of calendars.
          	module: "MMM-ModuleMonkeyPatch",
          		patches: [
          				method: "socketNotificationReceived",
          				patch: async function (original, args) {
          					const [ notification, payload ] = args
          					if (notification === "CALENDAR_EVENTS") {
          						const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
          						const r = await fetch('http://192.168.178.63:8080/modules/getip')
          						const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
          						if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
          							return original(notification, { ...payload, events: [] })
          					return original(notification, payload)
          	module: "getip",
          	header: "US Holidays",
          		clientMap: {
          			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
          			"192.168.178.22": ["cal3", "cal4", "cal5"]
          				url: "...",
          				url: "...",
          				url: "...",
          				url: "...",
          				url: "...",
          TO Improve
          Whenever notification CALENDAR_EVENTS coming, getip is called. After first execution, to store IP on the localStorage or cookie would be better.
          S S 2 Replies Last reply Reply Quote 0
            Spinster @sdetweil
            @sdetweil will express ipfilter be useful? Similar to whitelist, can we try something
              sdetweil @Spinster
              @Spinster no… as its in the wrong place… (inside node_helper…) we NEED the ip address to compare with
              just get it and return . one time
                sdetweil @MMRIZE
                @MMRIZE said in Show calendar based on IP Address accessed:
                BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
                that have to be processed… this is a bad waste of resources…
                and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
                this could also lead to different clients showing different data between fetchIntervals…
                  MMRIZE @sdetweil
                  @sdetweil said in Show calendar based on IP Address accessed:
                  I Can’t understand your point.
                  My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
                    MMRIZE @sdetweil
                    Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
                    Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
                      sdetweil @MMRIZE
                      @MMRIZE yes
                      @Spinster
                      see later post
                        sdetweil @MMRIZE
                        AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
                          Spinster @MMRIZE
                          @MMRIZE I tried it, but it is still showing the calendar even if there is no calendar defined for the ip. I edited only the config.js file and added your code. Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
                            Spinster @sdetweil
                            @sdetweil Is this working? Should I try it, please advice
                              MMRIZE @sdetweil
                              Still I can’t catch you.
                              [2024-05-07 15:03:33.741] [LOG]   Use existing calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics
                              The log shows, duplicated URL would be integrated into existing fetcher, So unlike your words, 3 clients doesn’t make 3 duplicated wasted fetcher.
                              If clientA needs cal1, cal2, cal3 and clientB needs cal1, cal4, cal5. In this case server should fetch 5 calendars anyway. User may need cal1 ~ cal5 even on 1 screen or 2 screens, ther server’s burden would be the same.
                              The only aspect that could be considered a waste is the transmission of unusing event data for cal4 and cal5 to clientA, but unless it’s a performance issue with the data parsing algorithm, simply having large data size being transmitted isn’t particularly problematic. Moreover, since the data is dropped in my code as soon as the notification is received, it can’t be deemed a significant memory issue. If the data size itself becomes problematic, it implies there’s already a problem with the original calendar module using cal1, cal2, cal3, cal4, and cal5.
                              Too skeptic.
                                MMRIZE @Spinster
                                @Spinster said in Show calendar based on IP Address accessed:
                                in the calendar config, I added clientMap.
                                		clientMap: {
                                			"192.168.178.22": [ "cal3", "cal4", "cal5" ]
                                				url: "...",
                                S 3 Replies Last reply Reply Quote 0
                                  sdetweil @Spinster
                                  @Spinster yes, the two pieces together
                                  ipaddress:“…”
                                  at each cal url block… only does one ipaddress per url
                                    Spinster @MMRIZE
                                    @MMRIZE
                                    Here is my config
                                    		module: "alert",
                                    		module: "updatenotification",
                                    		position: "top_bar"
                                    		module: "clock",
                                    		position: "top_left"
                                    			patches: [
                                    							const r = await fetch('http://10.5.11.1:8080/modules/getip')
                                    							console.log(ip)
                                    		module: "getip",
                                    		header: "Home Cal",
                                    			clientMap: {
                                    				"10.5.11.5": [ "cal1" ],
                                    				"10.5.11.6": ["cal2"]
                                    					fetchInterval: 10 * 60 * 1000,
                                    					symbol: "calendar-check",
                                    					url: "https://homecals/xEzboFt7Kr3Yfiys?export",
                                    This is showing both 10.5.11.5 and 10.5.11.6 the same calendar. Though 10.5.11.6 should not have any calendar since it is not defined. Even I tried without an entry of 10.5.11.6 in calendar map but it still showing the calendar. What am I doing wrong. Please advice
                                      Spinster @MMRIZE
                                      @MMRIZE I even added the calendarmap, I hope you seen my config.js sent earlier
                                        Spinster @Spinster
                                        Sorry, i think I have not installed Monkey module, will install and check again
                                          Spinster @sdetweil
                                          Should I use your earlier code and this? Please advise
                                            sdetweil @Spinster
                                            @Spinster yes you need both
                                            I am away from my system for another couple hours
                                            will collapse to one post then
                                            • 2 / 4
