    With Sam's Backup and Restore script I need help
    10 Posts 2 Posters 2.5k Views 2 Watching
    • kayakbabeK
      kayakbabe
      I’ve read through this topic and several others about backing up magic mirror especially this one
      Re: So I have a question about backup
      I’m trying to use Sam’s backup and restore scripts.
      I actually have it making files into a folder named MM_backup. But now I think my problem is that I don’t understand how git works all that well yet. I’ve only used it in a very simplistic way until now.
      Should my repository on GitHub have the same name as my local MM_backup folder? I ask because what is happening is that when I try to connect my local folder to the repository I made on GitHub, I get error messages about a repository inside a repository.
      I made a repository on GitHub then went to my local MM_backup and git cloned that repository into MM_backup.
      Then I ran the backup script making sure I specified the correct repository name. Then i try to git add the new files. GitHub is having none of it. says i have a repository inside a repository.
      SOOO. I thought aHA! i will change the backup folder path in the bash script. I deleted all the folders i made.
      Created a folder at /home/reponame
      Ran the script using the flag -b /home/reponame
      but the script doesn’t put the files in /home/reponame. The script creates a folder MM_backup and puts the files it made in there.
      So perhaps that is a bug?
      I don’t understand what is happening.
      And i can’t push the files the script made to the repository because i somehow made a repository inside a repository.
      I manually added the files to my repository on Github in the hopes that they’ll be useful at some point.
      I’d really like to make this work. But I need help.
      S 3 Replies Last reply
        sdetweil @kayakbabe
        @kayakbabe thanks for asking
        we have 3 things here
        1. the backup (and restore)
        the scripts take parameters if you want to change from the defaults
        -s is the MagicMirror folder location
        -b is the backup folder location
        1. the git repo
        git creates a hidden folder (.git) to keep track of the content it is given to track.
        you can make successive commits and retrieve/restore to any of those at any
        time.
        git provides a labeling mechanism,
        so you don’t have to remember some gory details, called a tag.
        the tag can be any label you like. I chose numbers. 1,2 3 .
        the actual files are called the working copy
        and you MUST also provide some
        message (-m parm) when you make a commit to the repo, describing why you did that
        so with the repo, you get
        a saved collection of files
        at different levels
        ability to see what changed, a vs b
        the ability to restore to any particular point at any time.
        all in the same folder.
        3 the github repo
        BUT if the storage location (90% sd card) goes bad, you lose the repo too. oh no.
        how to get the backup folder and repo somewhere ‘easily’
        copy to another sd card, usb stick, another computer. all take figuring out new stuff.
        hm. in MagicMirror we constantly use
        git clone to get stuff from github.
        and it’s cloud, so from anywhere to anywhere.
        cool, github provides a way to copy a repo from local to cloud. using similar names, a
        repository.
        so you create a (private) repository on github (login id), and name. it can be any name you like.
        now we have to connect the github repo, with the local repo
        git provides a command
        git remote add name url
        name can be anything, but for command ease of use, it is typically origin
        and there is a command to see the connection
        git remote -v
        the backup script saves that, for each module to know where to get it on restore
        ok, now we have a link between here and github.
        git also provides a quick way to change between collections of files
        a branch, a fork in the road,
        the default name is ‘main’
        it is also a marker for files at some change point. we use this mechanism for MagicMirror updates. the main branch we update once every 90 days. new incoming updates go to the develop branch
        and there is a tag added ever 90 days after the main update. so we/you can get to the collection of files at any release point.
        now to get the stuff from your mirror system to github
        git push (some parms I never can remember )
        and that sends the hidden repo to github.
        hurray!! safe and sound
        hm. how do I get them back when I need them…
        git provides a command for that
        git clone repo_url
        and voila, the files and repo are stored locally.
        one quirk here, BY DEFAULT, the restored folder name will be the same as the github repo name UNLESS you provide an extra parm
        git clone url folder_name
        you an also rename the folder after git clone is finished.
        but restore will do all that (but that points out a ‘bug’ in the script. maybe).
        a couple more details
        what good is a change marker (commit) if you don’t know WHO did it and how to reach them (git username and email)
        I don’t ask for password, git will do that
        the commands will dump.out help with
        -help as the parm
        ask more questions if I didn’t cover something
          sdetweil @kayakbabe
          @kayakbabe ah, I see
          -b xxxxx
          ASSUMES in the $HOME folder
          UNLESS the folder already exists
          so -b xyz
          means $HOME/xyz
          but -b /foo/bar
          means /foo/bar
          ONLY IF /foo/bar already exists
          otherwise I will jam it in
          $HOME//foo/bar
          note the double slash. maybe a bug
          I didn’t want to require sudo to create a folder off the root (leading slash /)
          note /home
          is not the user home
          that is $HOME
          if you wanted reponame in your $HOME folder just do -b reponame
          if you look at the log it might help too
          ~/MagicMirror//installers/backup.log
            sdetweil @kayakbabe
            @kayakbabe I just added some more messages on the backup with a specified foldername…
            (checked on double //)
            /home/fred or /foo/bar
            will create that in the $HOME folder $HOME/home/fred or $HOME/foo/bar
            and on restore to the specified folder, if it exists but is NOT the repo folder abort
            all go to the screen and logfile
            and I checked on restore if the repo name doesn’t match the backup folder name then I add the extra parm on git clone if the folder doesn’t exist
            if it exits, and IS a repo I git pull
            if NOT a repo I exit before doing anything
              @kayakbabe
              and one other thing
              only one side can create the repo with files
              github (with readme), then git clone to pi (and add files via backup)
              or
              github create empty repo, no files
              git push initial files from pi (after backup)
              if u create repo at github w readme
              AND you git commit at pi
              then try to git pull,
              now you have confusion
              if you git clone, BUT it already exists
              you can clone INSIDE the repo/backup
              folder but now you have repo in repo.
              kayakbabeK 1 Reply Last reply
              • kayakbabeK
                kayakbabe @sdetweil
                I’ll put this in my own words to see if I’m understanding what I am to do.
                Depending on how I create my repository on github will determine my next step.
                1. Create respository on GitHub (private is most preferable since I might have private info in my magic mirror config file and I don’t want that public via GitHub).
                Note: This process is easier if you create an empty GitHub Repository.
                1. If I created an empty GitHub Repsitory:
                  2.a.Run the backupscript using the flags on the backup script for repository name, source folder, backup destination folder, github userid, etc.
                  2.b. from the backup desitnation folder run the command
                  git push
                2. if I created GitHub repository with a readme:
                  then I’ve made a big mess and shouldn’t have done that. So delete the local folder and github repository and start over.
                Results
                I ran this
                bash -c ./mm_backup.sh -s /home/pi/MagicMirror -b /home/pi/MMbackup2 -r https://github.com/Kayakbabe/MMbackup2.git -u Kayakbabe -e email@mydomain.com -m 5thTry
                And got this:
                folder created with name /home/MM_backup
                files created inside /home/MM_backup
                no folder named MMbackup2
                I also tried with -b /home/pi/MMbackup2
                and still get home/pi/MM_backup created
                i don’t have a folder named MMbackup2 on my pi at all.
                I then manually created /home/pi/MMbackup2
                ran my command again and still no files were placed in MMbackup2. i tried both =b /home/pi/MMbackup2 and -b MMbackup2 to no avail.
                I noticed .git was created in the MM_backup folder along with the files the script created.
                I ran git remote -v and get no output. (Just to make sure, i went to a diff local git folder and ran git remote -v and it shows the origins for fetch and pull.) so I think the .git being created in the MM_backup folder isn’t correct.
                My questions are:
                What is wrong with my flags that my backup folder isn’t being create with the folder name I chose?
                Was the backup script supposed to do all the git stuff for me, like the git remote add origin and add files and set the branch and message?
                So that, all I am supposed to have to run git push?
                Or, am i supposed to now do all the following stuff?
                git remote add origin https://github.com/<USER>/<repo>.git
                git branch -M main
                git push -u origin main
                  sdetweil @kayakbabe
                  @kayakbabe can you send me the log?
                  MagicMirror/installers/backup.log
                  if you are putting the files in your home folder you don’t use the full path
                  you don’t push, -p will do that.
                  if you do NOT specify -p then YOU have to do the setup to push, and push. I was trying to save you work
                  (but as you specified the github repo, I should prompt if you DO want to push)
                  git remote -v
                  is from the inside backup folder (see below)
                  any parms whos default is good you don’t need to specify
                  also, you don’t clone the scripts to your system, just execute then from the guthub page like install and upgrade (you don’t get my fixes if you clone the repo),
                  you also don’t contaminate your system in case you have disk troubles and are trying to make an emergency backup
                  should be (-s MagicMirror is default)
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p  -b MMbackup2 -r MMbackup2 -u Kayakbabe -e user@email.com -m "first backup after build finished (or whatever)"
                  because you did not specify to push, the script did not setup for push (no git remote add )
                    @kayakbabe
                    try the latest
                    I updated the scripts to check for and handle full paths like you used.
                    and if you specified a repo but did NOT request push, I prompt to discover if you WANT to push this time
                    if the full path of the backup folder does not exist, I will try to create it,
                    if it fails, I will report the error, and abort.
                    -b /foobar
                    will probably fail, with permission denied
                    -b /home/$username/whatever
                    will be used as specified, not jamming $HOME in front
                    thank you for these testcases which I hadn’t considered…
                    please use your prior full path command (but use from github)
                    I also extract the userid from the github repo (and if you specify it thru -u, I check that it matches the one in the url, and abort if not)
                    hm… I typically build the url from username abd reponame. one thing to check… thx
                    • kayakbabeK
                      kayakbabe @sdetweil
                      what was happening is that no matter if i used the full path or just the folder name like this
                      -b MMbackup2
                      the script always used it’s own folder name of MM_backup.
                      when i tried to run from your repository,
                      Illegal option '- ’
                      I tried a local copy pulled a fresh copy from your GitHub and tried again
                      using -s MagicMirror
                      and -b MMbackup3
                      bash -c ./mm_backup.sh -p -b MMbackup3 -r MMbackup2 -u Kayakbabe -e user@email.com -m "second backup after build finished "
                      the backup folder was still created MM_backup and not MMbackup3.
                      Then I tried removing the -p option and I get this
                      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)” -b MMbackup2 -r MMbackup2 -u Kayakbabe -e email@mydomain.com -m “first backup after build finished (or whatever)”
                      environment: line 155: [: too many arguments
                      checking for backup folder MMbackup2
                      folder doesn’t exist, creating backup folder /home/kelly/MMbackup2
                      backup folder is /home/kelly/MMbackup2
                      username specified with -u temp doesn’t match the user in the github repo MMbackup2, aborting
                      Note i used my correct email, just don’t want it out here to get scraped. And the name and email DO match my github.
                      I run git remote-v in the folder it created (MM_backup) and there is no git .
                        sdetweil @kayakbabe
                        @kayakbabe well, all I can say, is I must not have tested it right.
                        my apologies
                        try again… all three scripts corrected now
