    With Sam's Backup and Restore script I need help
    10 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @kayakbabe
      @kayakbabe ah, I see
      -b xxxxx
      ASSUMES in the $HOME folder
      UNLESS the folder already exists
      so -b xyz
      means $HOME/xyz
      but -b /foo/bar
      means /foo/bar
      ONLY IF /foo/bar already exists
      otherwise I will jam it in
      $HOME//foo/bar
      note the double slash. maybe a bug
      I didn’t want to require sudo to create a folder off the root (leading slash /)
      note /home
      is not the user home
      that is $HOME
      if you wanted reponame in your $HOME folder just do -b reponame
      if you look at the log it might help too
      ~/MagicMirror//installers/backup.log
        sdetweil @kayakbabe
        @kayakbabe I just added some more messages on the backup with a specified foldername…
        (checked on double //)
        /home/fred or /foo/bar
        will create that in the $HOME folder $HOME/home/fred or $HOME/foo/bar
        and on restore to the specified folder, if it exists but is NOT the repo folder abort
        all go to the screen and logfile
        and I checked on restore if the repo name doesn’t match the backup folder name then I add the extra parm on git clone if the folder doesn’t exist
        if it exits, and IS a repo I git pull
        if NOT a repo I exit before doing anything
          @kayakbabe
          and one other thing
          only one side can create the repo with files
          github (with readme), then git clone to pi (and add files via backup)
          or
          github create empty repo, no files
          git push initial files from pi (after backup)
          if u create repo at github w readme
          AND you git commit at pi
          then try to git pull,
          now you have confusion
          if you git clone, BUT it already exists
          you can clone INSIDE the repo/backup
          folder but now you have repo in repo.
          kayakbabeK 1 Reply Last reply Reply Quote 0
          • kayakbabeK Offline
            kayakbabe @sdetweil
            I’ll put this in my own words to see if I’m understanding what I am to do.
            Depending on how I create my repository on github will determine my next step.
            1. Create respository on GitHub (private is most preferable since I might have private info in my magic mirror config file and I don’t want that public via GitHub).
            Note: This process is easier if you create an empty GitHub Repository.
            1. If I created an empty GitHub Repsitory:
              2.a.Run the backupscript using the flags on the backup script for repository name, source folder, backup destination folder, github userid, etc.
              2.b. from the backup desitnation folder run the command
              git push
            2. if I created GitHub repository with a readme:
              then I’ve made a big mess and shouldn’t have done that. So delete the local folder and github repository and start over.
            Results
            I ran this
            bash -c ./mm_backup.sh -s /home/pi/MagicMirror -b /home/pi/MMbackup2 -r https://github.com/Kayakbabe/MMbackup2.git -u Kayakbabe -e email@mydomain.com -m 5thTry
            And got this:
            folder created with name /home/MM_backup
            files created inside /home/MM_backup
            no folder named MMbackup2
            I also tried with -b /home/pi/MMbackup2
            and still get home/pi/MM_backup created
            i don’t have a folder named MMbackup2 on my pi at all.
            I then manually created /home/pi/MMbackup2
            ran my command again and still no files were placed in MMbackup2. i tried both =b /home/pi/MMbackup2 and -b MMbackup2 to no avail.
            I noticed .git was created in the MM_backup folder along with the files the script created.
            I ran git remote -v and get no output. (Just to make sure, i went to a diff local git folder and ran git remote -v and it shows the origins for fetch and pull.) so I think the .git being created in the MM_backup folder isn’t correct.
            My questions are:
            What is wrong with my flags that my backup folder isn’t being create with the folder name I chose?
            Was the backup script supposed to do all the git stuff for me, like the git remote add origin and add files and set the branch and message?
            So that, all I am supposed to have to run git push?
            Or, am i supposed to now do all the following stuff?
            git remote add origin https://github.com/<USER>/<repo>.git
            git branch -M main
            git push -u origin main
              sdetweil @kayakbabe
              @kayakbabe can you send me the log?
              MagicMirror/installers/backup.log
              if you are putting the files in your home folder you don’t use the full path
              you don’t push, -p will do that.
              if you do NOT specify -p then YOU have to do the setup to push, and push. I was trying to save you work
              (but as you specified the github repo, I should prompt if you DO want to push)
              git remote -v
              is from the inside backup folder (see below)
              any parms whos default is good you don’t need to specify
              also, you don’t clone the scripts to your system, just execute then from the guthub page like install and upgrade (you don’t get my fixes if you clone the repo),
              you also don’t contaminate your system in case you have disk troubles and are trying to make an emergency backup
              should be (-s MagicMirror is default)
              bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)" -p  -b MMbackup2 -r MMbackup2 -u Kayakbabe -e user@email.com -m "first backup after build finished (or whatever)"
              because you did not specify to push, the script did not setup for push (no git remote add )
                @kayakbabe
                try the latest
                I updated the scripts to check for and handle full paths like you used.
                and if you specified a repo but did NOT request push, I prompt to discover if you WANT to push this time
                if the full path of the backup folder does not exist, I will try to create it,
                if it fails, I will report the error, and abort.
                -b /foobar
                will probably fail, with permission denied
                -b /home/$username/whatever
                will be used as specified, not jamming $HOME in front
                thank you for these testcases which I hadn’t considered…
                please use your prior full path command (but use from github)
                I also extract the userid from the github repo (and if you specify it thru -u, I check that it matches the one in the url, and abort if not)
                hm… I typically build the url from username abd reponame. one thing to check… thx
                  kayakbabe @sdetweil
                  what was happening is that no matter if i used the full path or just the folder name like this
                  -b MMbackup2
                  the script always used it’s own folder name of MM_backup.
                  when i tried to run from your repository,
                  Illegal option '- ’
                  I tried a local copy pulled a fresh copy from your GitHub and tried again
                  using -s MagicMirror
                  and -b MMbackup3
                  bash -c ./mm_backup.sh -p -b MMbackup3 -r MMbackup2 -u Kayakbabe -e user@email.com -m "second backup after build finished "
                  the backup folder was still created MM_backup and not MMbackup3.
                  Then I tried removing the -p option and I get this
                  bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror-backup-restore/main/mm_backup.sh)” -b MMbackup2 -r MMbackup2 -u Kayakbabe -e email@mydomain.com -m “first backup after build finished (or whatever)”
                  environment: line 155: [: too many arguments
                  checking for backup folder MMbackup2
                  folder doesn’t exist, creating backup folder /home/kelly/MMbackup2
                  backup folder is /home/kelly/MMbackup2
                  username specified with -u temp doesn’t match the user in the github repo MMbackup2, aborting
                  Note i used my correct email, just don’t want it out here to get scraped. And the name and email DO match my github.
                  I run git remote-v in the folder it created (MM_backup) and there is no git .
                    sdetweil @kayakbabe
                    @kayakbabe well, all I can say, is I must not have tested it right.
                    my apologies
                    try again… all three scripts corrected now
