npm start is only showing Windows IIS
7 Posts 3 Posters 3.1k Views 2 Watching
  • Y Offline
    yawns Moderator
    Why is IIS installed on this machine?
    • N Offline
      nameless
      I have no idea why it is, but it shouldn’t change the behaviour, does it? I now checked it again, on my notebook with windows 8 its still not working. The only thing appearing is an image of IIS, with a href behind, refering to the page of IIS. One thing I found: When running node serveronly, I get an error, saying:
      Ready to go! Please point your browser to: http://localhost:8080
      Whoops! There was an uncaught exception…
      { Error: listen EACCES 0.0.0.0:8080
      at Object.exports._errnoException (util.js:1036:11)
      at exports._exceptionWithHostPort (util.js:1059:20)
      at Server._listen2 (net.js:1239:19)
      at listen (net.js:1288:10)
      at net.js:1398:9
      at _combinedTickCallback (internal/process/next_tick.js:77:11)
      at process._tickCallback (internal/process/next_tick.js:98:9)
      at Module.runMain (module.js:592:11)
      at run (bootstrap_node.js:394:7)
      at startup (bootstrap_node.js:149:9)
      code: ‘EACCES’,
      errno: ‘EACCES’,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080 }
      What could be wrong? On both computers, I just copied the sample config, without changes, just to have a basic setup…
      • Y Offline
        yawns Moderator
        Try changing the port in your magicmirror config, for example 8888 instead of 8080 and check again. IIS is using port 8080 already.
        • N Offline
          nameless
          This works, thank you. There’s one other thing Im wondering about, maybe you can help me with that, too. I recently saw here (in the part where others can present their magic mirror) that he used german language for complimens for example. How does that work?
          B 1 Reply Last reply Jan 20, 2017, 8:52 PM Reply Quote 0
            broberg Project Sponsor @nameless
            @nameless the default compliments are merely examples, you can type in anything you want in any language you want in the config file to the compliments module
