    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 77.5k Views 11 Watching
      sdetweil @davidgagne
      @davidgagne I am interested in the log to see why the inline pm2 setup failed.
      yes, pi0w is not fast.
      the default calendar and weather take configuration before they produce output.
      D 1 Reply Last reply
        @davidgagne you can also adjust the MagicMirror config so you can open your windows browser to see it too.
          davidgagne @sdetweil
          @sdetweil I’m an Apple user. I am sure there’s something similar, though. Thanks.
            @sdetweil It looks like I spoke too soon. After a reboot, I cannot seem to get any output from MagicMirror.
            I rebooted and then called pm2 start MagicMirror from within the MagicMirror directory, and it seems to execute just fine. But … nothing happens. It doesn’t actually start the app, as far as I can tell. Even though the output seems the same:
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            [PM2] Process successfully started
            │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 4592     │ 1s     │ 148  │ online    │ 0%       │ 27.4mb   │ dvg      │ disabled │
            Any ideas?
            S 2 Replies Last reply
              @davidgagne pm2 logs --lines=75
                @davidgagne that circle with the arrow heading column says times restarted. 148 is a problem
                D 2 Replies Last reply
                  @sdetweil I emailed you the output from that. I’m guessing Error: Cannot find module 'electron' is bad?
                    @sdetweil It’s frustrating because I swear it was working before I rebooted.
                      @sdetweil If you thought 148 restarts was bad … This is what I see now:
                      │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 14132    │ 0s     │ 659  │ online    │ 0%       │ 20.8mb   │ dvg      │ disabled │
                        @davidgagne got it. Just back from my walk… will examine…
                          @sdetweil I followed your tutorial on adding the Jeopardy module (just to see what would happen) and it worked fine. The last step is npm start and when I did that I got this:
                          > magicmirror@2.27.0 start
                          > ./run-start.sh $1
                          [2024-05-29 10:30:09.649] [LOG] Starting MagicMirror: v2.27.0
                          [2024-05-29 10:30:10.200] [LOG] Loading config ...
                          [2024-05-29 10:30:10.267] [LOG] config template file not exists, no envsubst
                          [2024-05-29 10:30:19.159] [LOG] Loading module helpers ...
                          [2024-05-29 10:30:19.394] [LOG] No helper found for module: alert.
                          [2024-05-29 10:30:53.041] [LOG] Initializing new module helper ...
                          [2024-05-29 10:30:53.066] [LOG] Module helper loaded: updatenotification
                          [2024-05-29 10:30:53.220] [LOG] No helper found for module: clock.
                          [2024-05-29 10:31:18.754] [LOG] Initializing new module helper ...
                          [2024-05-29 10:31:18.854] [LOG] Module helper loaded: calendar
                          [2024-05-29 10:31:19.537] [ERROR] Whoops! There was an uncaught exception...
                          [2024-05-29 10:31:20.316] [ERROR] Error: Cannot find module 'request'
                          Require stack:
                          - /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
                          - /home/dvg/MagicMirror/js/app.js
                          - /home/dvg/MagicMirror/serveronly/index.js
                              at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                              at Module._resolveFilename (/home/dvg/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at Module._load (node:internal/modules/cjs/loader:901:27)
                              at Module.require (node:internal/modules/cjs/loader:1115:19)
                              at require (node:internal/modules/helpers:130:18)
                              at Object.<anonymous> (/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js:8:17)
                              at Module._compile (node:internal/modules/cjs/loader:1241:14)
                              at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                              at Module.load (node:internal/modules/cjs/loader:1091:32)
                              at Module._load (node:internal/modules/cjs/loader:938:12)
                              at loadModule (/home/dvg/MagicMirror/js/app.js:183:19)
                              at loadModules (/home/dvg/MagicMirror/js/app.js:213:10)
                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                              at async App.start (/home/dvg/MagicMirror/js/app.js:261:3) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js',
                              '/home/dvg/MagicMirror/js/app.js',
                              '/home/dvg/MagicMirror/serveronly/index.js'
                          [2024-05-29 10:31:20.470] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          [2024-05-29 10:31:20.593] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                          [2024-05-29 10:34:40.779] [INFO] System information:
                          ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero W Rev 1.1; raspberry: [object Object]; virtual: false
                          ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21+
                          ### VERSIONS: electron: undefined; used node: 20.8.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.0
                          ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                          Starting chromium browser now, have patience, it takes a minute
                          Chromium_browser not installed
                          FYI: There is definitely an internet connection, so we can rule that out. Otherwise I have no idea.
                            @davidgagne yep,
                            not my tutorial just one I reference
                            see this
                              @sdetweil Hmmm. Okay. I tried that for the ‘alert’ module but it didn’t seem to have any impact:
                              dvg@hyperspace:~/MagicMirror $ cd modules/
                              dvg@hyperspace:~/MagicMirror/modules $ ls
                              default  MMM-JEOPARDY
                              dvg@hyperspace:~/MagicMirror/modules $ cd default/
                              dvg@hyperspace:~/MagicMirror/modules/default $ ls
                              alert  calendar  clock  compliments  defaultmodules.js  helloworld  newsfeed  updatenotification  utils.js  weather
                              dvg@hyperspace:~/MagicMirror/modules/default $ cd alert
                              dvg@hyperspace:~/MagicMirror/modules/default/alert $ ls package.json
                              ls: cannot access 'package.json': No such file or directory
                              dvg@hyperspace:~/MagicMirror/modules/default/alert $ npm init -y
                              Wrote to /home/dvg/MagicMirror/modules/default/alert/package.json:
                                "name": "alert",
                                "version": "1.0.0",
                                "description": "The alert module is one of the default modules of the MagicMirror². This module displays notifications from other modules.",
                                "main": "alert.js",
                                "scripts": {
                                  "test": "echo \"Error: no test specified\" && exit 1"
                                "keywords": [],
                                "author": "",
                                "license": "ISC"
                              dvg@hyperspace:~/MagicMirror/modules/default/alert $ cd ..
                              dvg@hyperspace:~/MagicMirror/modules/default $ cd ..
                              dvg@hyperspace:~/MagicMirror/modules $ cd ..
                              dvg@hyperspace:~/MagicMirror $ pm2 start MagicMirror
                              │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 16303    │ 0s     │ 744  │ online    │ 0%       │ 18.5mb   │ dvg      │ disabled │
                              Same result; just a bunch more restarts and nothing appearing. (The Pi desktop is there, though.)
                                @davidgagne why alert? it’s the mmm-jeopady module that is missing a library
                                  @davidgagne said in Raspberry Pi Zero 2 W for Magic Mirror:
                                  code: ‘MODULE_NOT_FOUND’,
                                  requireStack: [
                                  ‘/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js’,
                                    @sdetweil So, because I am relentless, I rebooted to see if that would help. It didn’t, but now it looks like I have a different problem altogether:
                                    cd MagicMirror/
                                    [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                                    [PM2] PM2 Successfully daemonized
                                    [PM2][ERROR] Script not found: /home/dvg/MagicMirror/MagicMirror
                                      @davidgagne pm2 status
                                        @sdetweil Oh. I thought the alert module was also indicating it was missing. Okay, I’ve tried npm init -y inside the MMM-Jeopardy dir, too, now.
                                        pm2 status gives me:
                                        │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1865     │ 11s    │ 28   │ online    │ 21.4%    │ 38.6mb   │ dvg      │ disabled │
                                        And now a subsequent pm2 start MagicMirror gives me:
                                        │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1986     │ 0s     │ 34   │ online    │ 0%       │ 22.6mb   │ dvg      │ disabled │
                                        But there’s still nothing displaying (aside from the generic Pi OS desktop, I mean).
                                          @davidgagne there are more commands after npm init
                                            @sdetweil Ah. I see that. But … I don’t think the Jeopardy module is the main problem here. I’d prefer to simply remove that and try to get back to where I can even get MM to run in the first place; then I’ll screw around with adding modules. As it is I still can’t get MM to even run at all (plus all the restarts).
                                            • 2 / 4
