    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 77.5k Views 11 Watching
      sdetweil @davidgagne
      @davidgagne pm2 logs --lines=75
      D 1 Reply Last reply
        @davidgagne that circle with the arrow heading column says times restarted. 148 is a problem
        D 2 Replies Last reply
          davidgagne @sdetweil
          @sdetweil I emailed you the output from that. I’m guessing Error: Cannot find module 'electron' is bad?
            @sdetweil It’s frustrating because I swear it was working before I rebooted.
              @sdetweil If you thought 148 restarts was bad … This is what I see now:
              pm2 start MagicMirror
              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
              [PM2] [MagicMirror](0) ✓
              [PM2] Process successfully started
              │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
              │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 14132    │ 0s     │ 659  │ online    │ 0%       │ 20.8mb   │ dvg      │ disabled │
                @davidgagne got it. Just back from my walk… will examine…
                  @sdetweil I followed your tutorial on adding the Jeopardy module (just to see what would happen) and it worked fine. The last step is npm start and when I did that I got this:
                  > magicmirror@2.27.0 start
                  > ./run-start.sh $1
                  [2024-05-29 10:30:09.649] [LOG] Starting MagicMirror: v2.27.0
                  [2024-05-29 10:30:10.200] [LOG] Loading config ...
                  [2024-05-29 10:30:10.267] [LOG] config template file not exists, no envsubst
                  [2024-05-29 10:30:19.159] [LOG] Loading module helpers ...
                  [2024-05-29 10:30:19.394] [LOG] No helper found for module: alert.
                  [2024-05-29 10:30:53.041] [LOG] Initializing new module helper ...
                  [2024-05-29 10:30:53.066] [LOG] Module helper loaded: updatenotification
                  [2024-05-29 10:30:53.220] [LOG] No helper found for module: clock.
                  [2024-05-29 10:31:18.754] [LOG] Initializing new module helper ...
                  [2024-05-29 10:31:18.854] [LOG] Module helper loaded: calendar
                  [2024-05-29 10:31:19.537] [ERROR] Whoops! There was an uncaught exception...
                  [2024-05-29 10:31:20.316] [ERROR] Error: Cannot find module 'request'
                  Require stack:
                  - /home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js
                  - /home/dvg/MagicMirror/js/app.js
                  - /home/dvg/MagicMirror/serveronly/index.js
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1048:15)
                      at Module._resolveFilename (/home/dvg/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:901:27)
                      at Module.require (node:internal/modules/cjs/loader:1115:19)
                      at require (node:internal/modules/helpers:130:18)
                      at Object.<anonymous> (/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js:8:17)
                      at Module._compile (node:internal/modules/cjs/loader:1241:14)
                      at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
                      at Module.load (node:internal/modules/cjs/loader:1091:32)
                      at Module._load (node:internal/modules/cjs/loader:938:12)
                      at loadModule (/home/dvg/MagicMirror/js/app.js:183:19)
                      at loadModules (/home/dvg/MagicMirror/js/app.js:213:10)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      at async App.start (/home/dvg/MagicMirror/js/app.js:261:3) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js',
                      '/home/dvg/MagicMirror/js/app.js',
                      '/home/dvg/MagicMirror/serveronly/index.js'
                  [2024-05-29 10:31:20.470] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2024-05-29 10:31:20.593] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                  [2024-05-29 10:34:40.779] [INFO] System information:
                  ### SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero W Rev 1.1; raspberry: [object Object]; virtual: false
                  ### OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21+
                  ### VERSIONS: electron: undefined; used node: 20.8.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.4.0
                  ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined
                  Starting chromium browser now, have patience, it takes a minute
                  Chromium_browser not installed
                  FYI: There is definitely an internet connection, so we can rule that out. Otherwise I have no idea.
                  S 2 Replies Last reply
                    @davidgagne yep,
                    not my tutorial just one I reference
                    see this
                      @sdetweil Hmmm. Okay. I tried that for the ‘alert’ module but it didn’t seem to have any impact:
                      dvg@hyperspace:~/MagicMirror $ cd modules/
                      dvg@hyperspace:~/MagicMirror/modules $ ls
                      default  MMM-JEOPARDY
                      dvg@hyperspace:~/MagicMirror/modules $ cd default/
                      dvg@hyperspace:~/MagicMirror/modules/default $ ls
                      alert  calendar  clock  compliments  defaultmodules.js  helloworld  newsfeed  updatenotification  utils.js  weather
                      dvg@hyperspace:~/MagicMirror/modules/default $ cd alert
                      dvg@hyperspace:~/MagicMirror/modules/default/alert $ ls package.json
                      ls: cannot access 'package.json': No such file or directory
                      dvg@hyperspace:~/MagicMirror/modules/default/alert $ npm init -y
                      Wrote to /home/dvg/MagicMirror/modules/default/alert/package.json:
                        "name": "alert",
                        "version": "1.0.0",
                        "description": "The alert module is one of the default modules of the MagicMirror². This module displays notifications from other modules.",
                        "main": "alert.js",
                        "scripts": {
                          "test": "echo \"Error: no test specified\" && exit 1"
                        "keywords": [],
                        "author": "",
                        "license": "ISC"
                      dvg@hyperspace:~/MagicMirror/modules/default/alert $ cd ..
                      dvg@hyperspace:~/MagicMirror/modules/default $ cd ..
                      dvg@hyperspace:~/MagicMirror/modules $ cd ..
                      dvg@hyperspace:~/MagicMirror $ pm2 start MagicMirror
                      │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 16303    │ 0s     │ 744  │ online    │ 0%       │ 18.5mb   │ dvg      │ disabled │
                      Same result; just a bunch more restarts and nothing appearing. (The Pi desktop is there, though.)
                        @davidgagne why alert? it’s the mmm-jeopady module that is missing a library
                          @davidgagne said in Raspberry Pi Zero 2 W for Magic Mirror:
                          code: ‘MODULE_NOT_FOUND’,
                          requireStack: [
                          ‘/home/dvg/MagicMirror/modules/MMM-JEOPARDY/node_helper.js’,
                            @sdetweil So, because I am relentless, I rebooted to see if that would help. It didn’t, but now it looks like I have a different problem altogether:
                            cd MagicMirror/
                            [PM2] Spawning PM2 daemon with pm2_home=/home/dvg/.pm2
                            [PM2] PM2 Successfully daemonized
                            [PM2][ERROR] Script not found: /home/dvg/MagicMirror/MagicMirror
                              @davidgagne pm2 status
                                @sdetweil Oh. I thought the alert module was also indicating it was missing. Okay, I’ve tried npm init -y inside the MMM-Jeopardy dir, too, now.
                                pm2 status gives me:
                                │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1865     │ 11s    │ 28   │ online    │ 21.4%    │ 38.6mb   │ dvg      │ disabled │
                                And now a subsequent pm2 start MagicMirror gives me:
                                │ 0  │ MagicMirror    │ default     │ 2.27.0  │ fork    │ 1986     │ 0s     │ 34   │ online    │ 0%       │ 22.6mb   │ dvg      │ disabled │
                                But there’s still nothing displaying (aside from the generic Pi OS desktop, I mean).
                                  @davidgagne there are more commands after npm init
                                    @sdetweil Ah. I see that. But … I don’t think the Jeopardy module is the main problem here. I’d prefer to simply remove that and try to get back to where I can even get MM to run in the first place; then I’ll screw around with adding modules. As it is I still can’t get MM to even run at all (plus all the restarts).
                                      @sdetweil Am I wrong about this? It actually appears that ‘electron’ is the missing module. But that’s not in /modules it’s in /js … Do I follow the same npm init steps to get it?
                                        @davidgagne no the electron missing is a problem in MagicMirror code…
                                        hang on…
                                          @davidgagne ok, lets clean up and restart
                                          all command line commands
                                          pm2 flush (to get clear out the old logs)
                                          pm2 status
                                          npm start
                                          all show work… and if you loaded the missing library in the MMM-Jeopardy module then all should be ok.
                                          then ctrl-q on the MM screen should stop it
                                          then
                                          pm2 restart 0
                                          and MM should come back up
                                            @sdetweil Okay! I’m doing this right now and will keep you posted. THANK YOU AGAIN.
                                            • 2 / 4
