    I need help installing MagicMirror on a Pi Zero W
    9 Posts 4 Posters 943 Views 4 Watching
      sdetweil @davepreNJ
      @daveprenj use my up to date script
      see
      erase the mm folder, then run the installer
      • plainbrokeP Offline
        plainbroke @sdetweil
        I know this is a Very OLD thread, but, I tried putting MM on my Pi zero W
        and it runs your script but MM doesn’t load, at least not when I VNC into the Zero.
        I can use Putty and see it in a command line. So I renamed MM to MM2 and am reinstalling hoping it works this time.
          sdetweil @plainbroke
          @plainbroke AND you have to change the browser… using the external_browser env variable , documented at the end of the scripts page…
            So all I have to do is update the mm.sh file.
            then use apt to install firefox for example.
              @plainbroke yes
              pm2 stop all to make sure the dead one is stopped
              and test with
              npm start
              to make sure it works
                davidgagne
                I’ve also posted a detailed step by step guide that’s been working for me on my Pi Zero W. YMMV.
                  plainbroke @davidgagne
                  @davidgagne , @sdetweil
                  Finally got mine to actually work, dang it is slow though.
                    @plainbroke yeh they are
