    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 434.5k Views 32 Watching
    • htilburgsH
      htilburgs @htilburgs
      @htilburgs said in MMM-CalendarExt3Agenda:
      Is there a way to hide (not show) Yesterday, Today, Tomorrow, etc. and just show the day and date?
      Found it:
      in custom.css change
      .CX3A .relativeDay {
      display: none;
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      • htilburgsH
        htilburgs
        Is there a way to only show MiniMonthCalendar and no calendars? I would like to run 2 instances of MMM-CalendarExt3 Agenda
        1. only show MiniMonthCalendar
        2. only show Calendar (no problem)
        M 1 Reply Last reply
          MMRIZE @htilburgs
          @htilburgs
          htilburgsH 1 Reply Last reply
          • htilburgsH
            htilburgs @MMRIZE
            @MMRIZE
            I know this, but I like to have 2 instances running.
            1 Calendar on the left and 1 MiniMonth on the right.
            On this way the CSS wil override the Calendar part of both parts.
            M S 2 Replies Last reply
              MMRIZE @htilburgs
              @htilburgs
              You can give instanceId for each instance. Then you can specify CSS selector with that instanceId.
              /* config/config.js */
              module: 'MMM-CalendarExt3Agenda',
              position: 'top_left',
                instanceId: 'mymodule1',
              /* css/custom.css */
              .CX3A_mymodule1 .agenda { // You can select a specific instance like this.
                display: none;
                MMRIZE
                @htilburgs
                But I’m sorry, I forgot to implement that feature until now. :D.(nobody found it was not implemented )I fix it now. You can update the module and use that instanceId selector. Sorry again. :D
                htilburgsH 2 Replies Last reply
                • htilburgsH
                  htilburgs @MMRIZE
                  @MMRIZE
                  I didn’t see it either in the documentation, my mistake. Thanks for the quick reply and fix. I’ll try when I’m at home.
                    sdetweil @htilburgs
                    @htilburgs if you have 2 instance and want different css behavior, then you need to add more entries to custom.css using another selector prefix
                    you can add a fake name to the classes property (at same level as module and position) and use that name instead of .CX3A.
                    note the dot in front means classname
                    • htilburgsH
                      htilburgs @sdetweil
                      @sdetweil thanks Sam for the extra explanation.
                        sdetweil @htilburgs
                        @htilburgs so an example
                        in the second instance of agenda
                        add
                          classes:"agenda2",
                        after the
                          module:"MMM-CalendarExt3Agenda",
                        and in the css
                        copy all the .CX3A settings you have
                        and add
                        .agenda2
                        and a space after .agenda2
                        as the start of the line w .CX3A
                        .agenda2 .CX3A ....
                        on all the newly duplicated lines
                        leave out the ones you don’t want on the second instance of course
                        • htilburgsH
                          htilburgs @MMRIZE
                          @MMRIZE I’ve tried, but no luck
                          • htilburgsH
                            htilburgs @sdetweil
                            @sdetweil Yes! This works. Thanks
                              danny607 @ffingers6
                              @ffingers6 how do you get that view? can you post out the config.js and or relevant module JS thanks.
                                MMRIZE @danny607
                                @danny607
                                https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/152?_=1725781945711
                                • M MMRIZE referenced this topic on
                                  Dr8ke
                                  This is a great module thank you!
                                  It may be something obvious but I’ve been searching without any luck. I’m trying to see how I can get more events to appear in the agenda. But I can seem to go beyond what’s in the screenshot. I’ll be using portrait mode so I have lots of room. I’ve include my config file and CSS file if that helps. Any help would be much appreciated, thank you!
                                  Config.js
                                  	module: 'calendar',
                                  			header: "Calendar",
                                  			//position: 'top_center',   *Calendar is needed for the MMM-CalendarExt3Agenda but taking away it's position hides it.
                                  						wrapEvents: true,
                                  						fetchInterval: 300000,
                                  						maximumEntries: 100,
                                  						displaySymbol: true,
                                  Custom.css
                                  /******** CX3-Agenda ********/
                                  /*Remove CW from the miniMonth*/
                                  .CX3A .miniMonth .cw {
                                    display: none;
                                  /*show/hide event description or location*/
                                  .CX3A .agenda .event .description,
                                  .CX3A .agenda .event .location {
                                    display: none;
                                  .CX3A .cellBody .fullday .event .headline .symbol,
                                  .CX3A .cellBody .fullday .event .headline .symbol * {
                                    display: inline-block;
                                    color: var(--oppositeColor);
                                    sdetweil @Dr8ke
                                    @Dr8ke here is the full size
                                    .CX3A .agenda {
                                      position: relative;
                                      max-height: 600px;
                                      overflow-y: hidden;  // if it gets bigger, truncate and hide
                                      mask-image: linear-gradient(to bottom, transparent, black 10%);
                                      -webkit-mask-image: -webkit-linear-gradient(90deg, transparent, black 10%);
                                    D 1 Reply Last reply
                                      Dr8ke @sdetweil
                                      Thank you very much!
                                        sdetweil @Dr8ke
                                        @Dr8ke that was from the module css
                                          bassin12
                                          Good day everyone, I just resurrect my MagicMirror and I saw so many new things and loving the new modules, got everything to work but haven’t figure out one thing with the CalendarExt3Agenda, I would like to display only today events, I tried different configurations with:
                                          			startDayIndex: 0,
                                          			endDayIndex: 1,
                                          With this, I get today and tomorrow, and I know this is right, but when I try
                                          			startDayIndex: 0,
                                          			endDayIndex: 0,
                                          I get a blank today without any event being display, any clue?
                                          Leo
                                          M 2 Replies Last reply
                                            MMRIZE @bassin12
                                            @bassin12
                                            I’ll look inside; maybe it was my mistake.
                                            • 10
                                            • 11
                                            • 12
                                            • 9 / 12
