    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 434.5k Views 32 Watching
    • htilburgsH
      htilburgs @MMRIZE
      @MMRIZE
      I know this, but I like to have 2 instances running.
      1 Calendar on the left and 1 MiniMonth on the right.
      On this way the CSS wil override the Calendar part of both parts.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
      M S 2 Replies Last reply
        MMRIZE @htilburgs
        @htilburgs
        You can give instanceId for each instance. Then you can specify CSS selector with that instanceId.
        /* config/config.js */
        module: 'MMM-CalendarExt3Agenda',
        position: 'top_left',
          instanceId: 'mymodule1',
        /* css/custom.css */
        .CX3A_mymodule1 .agenda { // You can select a specific instance like this.
          display: none;
          MMRIZE
          @htilburgs
          But I’m sorry, I forgot to implement that feature until now. :D.(nobody found it was not implemented )I fix it now. You can update the module and use that instanceId selector. Sorry again. :D
          htilburgsH 2 Replies Last reply
          • htilburgsH
            htilburgs @MMRIZE
            @MMRIZE
            I didn’t see it either in the documentation, my mistake. Thanks for the quick reply and fix. I’ll try when I’m at home.
              sdetweil @htilburgs
              @htilburgs if you have 2 instance and want different css behavior, then you need to add more entries to custom.css using another selector prefix
              you can add a fake name to the classes property (at same level as module and position) and use that name instead of .CX3A.
              note the dot in front means classname
              htilburgsH 1 Reply Last reply
              • htilburgsH
                htilburgs @sdetweil
                @sdetweil thanks Sam for the extra explanation.
                  sdetweil @htilburgs
                  @htilburgs so an example
                  in the second instance of agenda
                  add
                    classes:"agenda2",
                  after the
                    module:"MMM-CalendarExt3Agenda",
                  and in the css
                  copy all the .CX3A settings you have
                  and add
                  .agenda2
                  and a space after .agenda2
                  as the start of the line w .CX3A
                  .agenda2 .CX3A ....
                  on all the newly duplicated lines
                  leave out the ones you don’t want on the second instance of course
                  • htilburgsH
                    htilburgs @MMRIZE
                    @MMRIZE I’ve tried, but no luck
                    • htilburgsH
                      htilburgs @sdetweil
                      @sdetweil Yes! This works. Thanks
                        danny607 @ffingers6
                        @ffingers6 how do you get that view? can you post out the config.js and or relevant module JS thanks.
                        M 1 Reply Last reply
                          MMRIZE @danny607
                          @danny607
                          https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/152?_=1725781945711
                          • M MMRIZE referenced this topic on
                            Dr8ke
                            This is a great module thank you!
                            It may be something obvious but I’ve been searching without any luck. I’m trying to see how I can get more events to appear in the agenda. But I can seem to go beyond what’s in the screenshot. I’ll be using portrait mode so I have lots of room. I’ve include my config file and CSS file if that helps. Any help would be much appreciated, thank you!
                            Config.js
                            	module: 'calendar',
                            			header: "Calendar",
                            			//position: 'top_center',   *Calendar is needed for the MMM-CalendarExt3Agenda but taking away it's position hides it.
                            						wrapEvents: true,
                            						fetchInterval: 300000,
                            						maximumEntries: 100,
                            						displaySymbol: true,
                            Custom.css
                            /******** CX3-Agenda ********/
                            /*Remove CW from the miniMonth*/
                            .CX3A .miniMonth .cw {
                              display: none;
                            /*show/hide event description or location*/
                            .CX3A .agenda .event .description,
                            .CX3A .agenda .event .location {
                              display: none;
                            .CX3A .cellBody .fullday .event .headline .symbol,
                            .CX3A .cellBody .fullday .event .headline .symbol * {
                              display: inline-block;
                              color: var(--oppositeColor);
                              sdetweil @Dr8ke
                              @Dr8ke here is the full size
                              .CX3A .agenda {
                                position: relative;
                                max-height: 600px;
                                overflow-y: hidden;  // if it gets bigger, truncate and hide
                                mask-image: linear-gradient(to bottom, transparent, black 10%);
                                -webkit-mask-image: -webkit-linear-gradient(90deg, transparent, black 10%);
                              D 1 Reply Last reply
                                Dr8ke @sdetweil
                                Thank you very much!
                                  sdetweil @Dr8ke
                                  @Dr8ke that was from the module css
                                    bassin12
                                    Good day everyone, I just resurrect my MagicMirror and I saw so many new things and loving the new modules, got everything to work but haven’t figure out one thing with the CalendarExt3Agenda, I would like to display only today events, I tried different configurations with:
                                    			startDayIndex: 0,
                                    			endDayIndex: 1,
                                    With this, I get today and tomorrow, and I know this is right, but when I try
                                    			startDayIndex: 0,
                                    			endDayIndex: 0,
                                    I get a blank today without any event being display, any clue?
                                    Leo
                                    M 2 Replies Last reply
                                      MMRIZE @bassin12
                                      @bassin12
                                      I’ll look inside; maybe it was my mistake.
                                        MMRIZE @bassin12
                                        @bassin12
                                        Updated. There was a logical bug in the code. Sorry.
                                        B 1 Reply Last reply
                                          bassin12 @MMRIZE
                                          @MMRIZE Nothing to apologize for, it is a great module.
                                          Leo
                                            shizzlesticks
                                            Hi all. I just updated to the latest release of MagicMirror code to take advantage of the fixes for recurring calendar events. Unfortunately all of my calendars with MMM-CalendarExt3Agenda are showing no events after the update. However, I do see that it’s loading them from the ical addresses in the debug logs.
                                            Anyone else having this problem?
                                            • 10
                                            • 11
                                            • 12
                                            • 9 / 12
