    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 412.0k Views 32 Watching
      cyberphox @MMRIZE
      Got tired of looking at the update notification today. Did a git pull and npm install…module isn’t showing at all now…
      Should have left it alone…sigh
        MMRIZE @cyberphox
        @cyberphox share me your config.(eouia0819@gmail.com)
          cyberphox @MMRIZE
          @MMRIZE sent! thanks for having a look!
          • htilburgsH Offline
            htilburgs
            Is there a way to hide (not show) Yesterday, Today, Tomorrow, etc. and just show the day and date?
            (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
            htilburgsH 1 Reply Last reply Reply Quote 0
              htilburgs @htilburgs
              @htilburgs said in MMM-CalendarExt3Agenda:
              Found it:
              in custom.css change
              .CX3A .relativeDay {
              display: none;
                htilburgs
                Is there a way to only show MiniMonthCalendar and no calendars? I would like to run 2 instances of MMM-CalendarExt3 Agenda
                1. only show MiniMonthCalendar
                2. only show Calendar (no problem)
                  MMRIZE @htilburgs
                  @htilburgs
                    htilburgs @MMRIZE
                    @MMRIZE
                    I know this, but I like to have 2 instances running.
                    1 Calendar on the left and 1 MiniMonth on the right.
                    On this way the CSS wil override the Calendar part of both parts.
                    M S 2 Replies Last reply Reply Quote 0
                      MMRIZE @htilburgs
                      @htilburgs
                      You can give instanceId for each instance. Then you can specify CSS selector with that instanceId.
                      /* config/config.js */
                      module: 'MMM-CalendarExt3Agenda',
                      position: 'top_left',
                        instanceId: 'mymodule1',
                      /* css/custom.css */
                      .CX3A_mymodule1 .agenda { // You can select a specific instance like this.
                        display: none;
                        MMRIZE
                        @htilburgs
                        But I’m sorry, I forgot to implement that feature until now. :D.(nobody found it was not implemented )I fix it now. You can update the module and use that instanceId selector. Sorry again. :D
                        htilburgsH 2 Replies Last reply Reply Quote 0
                          htilburgs @MMRIZE
                          @MMRIZE
                          I didn’t see it either in the documentation, my mistake. Thanks for the quick reply and fix. I’ll try when I’m at home.
                            sdetweil @htilburgs
                            @htilburgs if you have 2 instance and want different css behavior, then you need to add more entries to custom.css using another selector prefix
                            you can add a fake name to the classes property (at same level as module and position) and use that name instead of .CX3A.
                            note the dot in front means classname
                              htilburgs @sdetweil
                              @sdetweil thanks Sam for the extra explanation.
                                sdetweil @htilburgs
                                @htilburgs so an example
                                in the second instance of agenda
                                add
                                  classes:"agenda2",
                                after the
                                  module:"MMM-CalendarExt3Agenda",
                                and in the css
                                copy all the .CX3A settings you have
                                and add
                                .agenda2
                                and a space after .agenda2
                                as the start of the line w .CX3A
                                .agenda2 .CX3A ....
                                on all the newly duplicated lines
                                leave out the ones you don’t want on the second instance of course
                                  htilburgs @MMRIZE
                                  @MMRIZE I’ve tried, but no luck
                                    htilburgs @sdetweil
                                    @sdetweil Yes! This works. Thanks
                                      danny607 @ffingers6
                                      @ffingers6 how do you get that view? can you post out the config.js and or relevant module JS thanks.
                                        MMRIZE @danny607
                                        @danny607
                                        https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/152?_=1725781945711
                                        • M MMRIZE referenced this topic on
                                          Dr8ke
                                          This is a great module thank you!
                                          It may be something obvious but I’ve been searching without any luck. I’m trying to see how I can get more events to appear in the agenda. But I can seem to go beyond what’s in the screenshot. I’ll be using portrait mode so I have lots of room. I’ve include my config file and CSS file if that helps. Any help would be much appreciated, thank you!
                                          Config.js
                                          	module: 'calendar',
                                          			header: "Calendar",
                                          			//position: 'top_center',   *Calendar is needed for the MMM-CalendarExt3Agenda but taking away it's position hides it.
                                          						wrapEvents: true,
                                          						fetchInterval: 300000,
                                          						maximumEntries: 100,
                                          						displaySymbol: true,
                                          Custom.css
                                          /******** CX3-Agenda ********/
                                          /*Remove CW from the miniMonth*/
                                          .CX3A .miniMonth .cw {
                                            display: none;
                                          /*show/hide event description or location*/
                                          .CX3A .agenda .event .description,
                                          .CX3A .agenda .event .location {
                                            display: none;
                                          .CX3A .cellBody .fullday .event .headline .symbol,
                                          .CX3A .cellBody .fullday .event .headline .symbol * {
                                            display: inline-block;
                                            color: var(--oppositeColor);
                                            sdetweil @Dr8ke
                                            @Dr8ke here is the full size
                                            .CX3A .agenda {
                                              position: relative;
                                              max-height: 600px;
                                              overflow-y: hidden;  // if it gets bigger, truncate and hide
                                              mask-image: linear-gradient(to bottom, transparent, black 10%);
                                              -webkit-mask-image: -webkit-linear-gradient(90deg, transparent, black 10%);
                                            • 10
                                            • 11
                                            • 12
                                            • 9 / 12
