    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 416.6k Views 32 Watching
    • Z Offline
      ZiggidyZ
      Thank you so much for the awesome module!! I am enjoying both the EXT3 view for a 3 week peek, and use the Agenda for only the events for the current day.
      Does this module allow for symbols to be used on full day events? I have the full day events with symbol without issue on the EXT3 calendar, as well as 3 vanilla calendars I use to note what upcoming birthdays, anniversaries, and holidays there are, and it works there as well. The symbols DO work in Agenda for events that have a begin and end time.
      In looking at the css files for both modules, I noticed that there are more configurations for symbols in the EXT3 versus the EXT3A css. Is there something that I am missing that I need to do in order to enable them specifically for the Agenda module?
      From the module .css file for MMM-CalendarExt3:
      .CX3 .event .headline .symbol {
        order: 1;
      .CX3 .event.singleday .headline:not(.useSymbol)::before,
      .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
        content: "⬤";
        color: var(--calendarColor);
        display: inline-block;
        padding-right: 2px;
        font-size: 75%;
      .CX3 .event .headline:not(.useSymbol) .symbol {
        display: none;
      .CX3 .event .headline.useSymbol .symbol {
        padding-right: 2px;
        font-size: 75%;
        align-self: center;
      .CX3 .event.singleday .headline.useSymbol .symbol {
      From the module .css file for MMM-CalendarExt3Agenda:
      .CX3A .event .headline .symbol {
        font-size: 75%;
        vertical-align: text-bottom;
      .CX3A .event .headline .symbol.noSymbol::after {
        content: "⬤";
      • luisestradaL Offline
        luisestrada @MMRIZE
        @MMRIZE said in MMM-CalendarExt3Agenda:
        @luisestrada
        Done. (Released. v1.4.2)
        A new config value, relativeNamedDayOptions, is introduced. Now People can modify the option generally.
        However, for your specific purpose (en X días instead of dentro de X días), further step is needed.
        Only the Mexican locale supports en X días format with relativeNamedDayOptions: {style : 'short' }, other Spanish-locales don’t.
        So to get en X días, you have to use locale: 'es-MX' regardless of which country you live.
        locale: "es-MX",
        	style: "short",
        If you are living in Mexico, there would be no issue. But in other countries where the week starts on Monday, 2 more configuration is needed.
        locale: "es-MX",
        	style: "short",
        firstDayOfWeek: 1,
        minimalDaysOfNewYear: 4,
        Of course, if you don’t care dentro de 3 días, You can use any locale under which you live.
        locale: "es-ES",
        Thank you so much, it’s working perfectly. I had Spanish Colombia but I ended up switching to Mexico to make it work.
          MMRIZE @ZiggidyZ
          @ZiggidyZ
          Sorry for late reply.
          /* In your custom.css */
          .CX3A .cellBody .fullday .event .headline .symbol,
          .CX3A .cellBody .fullday .event .headline .symbol * {
            color: var(--oppositeColor);
            jimmy_382837
            1.4.2 looks great, thanks for the update!
            i wanted to change the color of the weekend days from dodgerblue and crimson to a diff color. i had the below in my custom.css file from the previous version of the module, but it doesn’t seem to work any longer.
            any suggestions?
            .CX3A {
              font-size: 16px;
              min-width: 300px;
              max-width: 400px;
              text-align: left;
              color: lightgray;
              --saturdayColor: rgb(147, 112, 219);
              --sundayColor: rgb(147, 112, 219);
              --todayColor: rgb(210,105,30);
              --weekend_1_color: rgb(147, 112, 219);
              --weekend_2_color: rgb(147, 112, 219);
            • F Offline
              ffingers6
              I was curious if it was possible to get a row view similar to the way MMM-CalendarExt2 worked. I have a good setup that works well for our use case, but want to move to CX3 if possible for some additional features and the reliance on the default calendar module for parsing.
              This is my current setup…is it possible to adjust agenda to look like this? I can deal with the styling, but changing to a row format is the big question for me.
              M D 3 Replies Last reply Reply Quote 0
                MMRIZE @ffingers6
                @ffingers6
                I’ll try soon.
                  MMRIZE @ffingers6
                  @ffingers6
                  /* config/config.js */
                      broadcastEvents: true,
                      defaultSymbolClassName: "", // This is needed to use the iconify icons instead of the font-awesome icons
                            symbol: "noto:calendar",
                            url: "...",
                            color: "violet",
                    module: "MMM-CalendarExt3Agenda",
                    position: "bottom_bar",
                      showMiniMonthCalendar: false,
                      locale: "en-US",
                      startDayIndex: 0,
                      endDayIndex: 2,
                      useIconify: true,
                  /* css/custom.css */
                  .CX3A {
                    max-width: 100%;
                  .CX3A .agenda {
                    display: flex;
                    flex-flow: row nowrap;
                    justify-content: space-between;
                    gap: 10px;
                    mask-image: none;
                  .CX3A .agenda .cell {
                    flex-grow: 1;
                    flex-basis: 0;
                    border-bottom: none;
                  .CX3A .agenda .cell .cellHeader {
                    border-bottom: 2px solid gray;
                    margin-bottom: 5px;
                  .CX3A .agenda .cell .cellHeaderMain {
                    flex-grow: 1;
                    padding: 5px;
                  .CX3A .event.singleday {
                    border-left: 2px solid var(--calendarColor);
                    padding-left: 3px;
                    margin-bottom: 1px;
                    background-color: color-mix(in srgb, var(--calendarColor), transparent 75%);
                  .CX3A .event .time {
                    order: 2;
                  .CX3A .event .title {
                    flex-grow: 2;
                  .CX3A .cellBody {
                    line-height: 120%;
                  .CX3A .cellBody .fullday {
                    padding-bottom: 5px;
                  .CX3A .cellBody .fullday .event {
                    max-width: 100%;
                  For the size, you may need some manual adjustment for your view.
                    cyberphox @MMRIZE
                    Got tired of looking at the update notification today. Did a git pull and npm install…module isn’t showing at all now…
                    Should have left it alone…sigh
                      MMRIZE @cyberphox
                      @cyberphox share me your config.(eouia0819@gmail.com)
                        cyberphox @MMRIZE
                        @MMRIZE sent! thanks for having a look!
                        • htilburgsH Offline
                          htilburgs
                          Is there a way to hide (not show) Yesterday, Today, Tomorrow, etc. and just show the day and date?
                          (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                          htilburgsH 1 Reply Last reply Reply Quote 0
                            htilburgs @htilburgs
                            @htilburgs said in MMM-CalendarExt3Agenda:
                            Found it:
                            in custom.css change
                            .CX3A .relativeDay {
                            display: none;
                              htilburgs
                              Is there a way to only show MiniMonthCalendar and no calendars? I would like to run 2 instances of MMM-CalendarExt3 Agenda
                              1. only show MiniMonthCalendar
                              2. only show Calendar (no problem)
                                MMRIZE @htilburgs
                                @htilburgs
                                  htilburgs @MMRIZE
                                  @MMRIZE
                                  I know this, but I like to have 2 instances running.
                                  1 Calendar on the left and 1 MiniMonth on the right.
                                  On this way the CSS wil override the Calendar part of both parts.
                                  M S 2 Replies Last reply Reply Quote 0
                                    MMRIZE @htilburgs
                                    @htilburgs
                                    You can give instanceId for each instance. Then you can specify CSS selector with that instanceId.
                                    module: 'MMM-CalendarExt3Agenda',
                                    position: 'top_left',
                                      instanceId: 'mymodule1',
                                    .CX3A_mymodule1 .agenda { // You can select a specific instance like this.
                                      display: none;
                                      MMRIZE
                                      @htilburgs
                                      But I’m sorry, I forgot to implement that feature until now. :D.(nobody found it was not implemented )I fix it now. You can update the module and use that instanceId selector. Sorry again. :D
                                      htilburgsH 2 Replies Last reply Reply Quote 0
                                        htilburgs @MMRIZE
                                        @MMRIZE
                                        I didn’t see it either in the documentation, my mistake. Thanks for the quick reply and fix. I’ll try when I’m at home.
                                          sdetweil @htilburgs
                                          @htilburgs if you have 2 instance and want different css behavior, then you need to add more entries to custom.css using another selector prefix
                                          you can add a fake name to the classes property (at same level as module and position) and use that name instead of .CX3A.
                                          note the dot in front means classname
                                            htilburgs @sdetweil
                                            @sdetweil thanks Sam for the extra explanation.
                                            • 10
                                            • 11
                                            • 12
                                            • 8 / 12
