    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 418.2k Views 32 Watching
      MMRIZE @CDT
      @CDT
      I’ve fixed it. Thanks for reporting it.
      • luisestradaL Offline
        luisestrada @CDT
        @CDT said in MMM-CalendarExt3Agenda:
        Possible bug here. The Agenda doesn’t show scheduled events on the final day as set by the endDateIndex.
        I’m trying to get the Ext3Agenda to show me just a single day. Using startDayIndex:0, endDateIndex:0. When doing this, it only shows full-day events, not events scheduled a specific time.
        If I change endDateIndex:1, then I get the proper items appearing, but also a header for day 2.
        I notice that not matter what the endDateIndex is listed, it doesn’t seem to show sheduled events the last day. Only the header and any full-day events.
        I think you are referring to the same issue I posted a while ago but unfortunately I was not able to make myself clear.
        • luisestradaL luisestrada referenced this topic on
          CDT @MMRIZE
          @MMRIZE
          Works perfectly now, thanks!
          luisestradaL 1 Reply Last reply Reply Quote 1
            luisestrada @CDT
            Happy new year everyone!
            Indeed the fix works now. Thank you @MMRIZE
            Another comment, even though “dentro de X días” is correct in Spanish it’s also long. It could also be said “En X días” and it will be also correct. Not an issue but a suggestion.
            • BKeyportB Offline
              BKeyport Module Developer @luisestrada
              @luisestrada I believe that’s a translation error - and may not even be “our” fault…
              luisestradaL 2 Replies Last reply Reply Quote 0
                luisestrada @BKeyport
                @BKeyport I tried to find the source but no idea where this comes from.
                  @BKeyport said in MMM-CalendarExt3Agenda:
                  I see there’s nothing we can do, with my limited programming skills I was able to get to row 271 in MMM-CalendarExt3Agenda.js
                  let p = new Intl.RelativeTimeFormat(options.locale, { numeric: "auto", style: "long" })
                  and I found out that Intl​.Relative​Time​Format is written like that, for Spanish locale settings.
                  As I said before it’s not wrong but they could have said “en 3 días” instead of “dentro de 3 días”. It’s like in English when you say “in 3 days” and “within 3 days”.
                  https://hpneo.dev/2019/05/13/apis-internacionalizacion.html#:~:text=Intl​.,-Relative​Time&text=Relative​Time​Format es una API interesante que,podemos hacerlo con esta API.
                  M 3 Replies Last reply Reply Quote 0
                    MMRIZE @luisestrada
                    @luisestrada
                    I’ll prepare how to customize it soon. I’m on travel abroad now and will return to next week. Plz wait a while. Until then, you can hide it with css.
                      MMRIZE @luisestrada
                      @luisestrada
                      Almost done (not yet released).
                      By the way, which locale did you use and which country are you living?
                        MMRIZE @luisestrada
                        @luisestrada
                        Done. (Released. v1.4.2)
                        A new config value, relativeNamedDayOptions, is introduced. Now People can modify the option generally.
                        However, for your specific purpose (en X días instead of dentro de X días), further step is needed.
                        Only the Mexican locale supports en X días format with relativeNamedDayOptions: {style : 'short' }, other Spanish-locales don’t.
                        So to get en X días, you have to use locale: 'es-MX' regardless of which country you live.
                        locale: "es-MX",
                        	style: "short",
                        If you are living in Mexico, there would be no issue. But in other countries where the week starts on Monday, 2 more configuration is needed.
                        locale: "es-MX",
                        	style: "short",
                        firstDayOfWeek: 1,
                        minimalDaysOfNewYear: 4,
                        Of course, if you don’t care dentro de 3 días, You can use any locale under which you live.
                        locale: "es-ES",
                        luisestradaL 1 Reply Last reply Reply Quote 0
                        • Z Offline
                          ZiggidyZ
                          Thank you so much for the awesome module!! I am enjoying both the EXT3 view for a 3 week peek, and use the Agenda for only the events for the current day.
                          Does this module allow for symbols to be used on full day events? I have the full day events with symbol without issue on the EXT3 calendar, as well as 3 vanilla calendars I use to note what upcoming birthdays, anniversaries, and holidays there are, and it works there as well. The symbols DO work in Agenda for events that have a begin and end time.
                          In looking at the css files for both modules, I noticed that there are more configurations for symbols in the EXT3 versus the EXT3A css. Is there something that I am missing that I need to do in order to enable them specifically for the Agenda module?
                          From the module .css file for MMM-CalendarExt3:
                          .CX3 .event .headline .symbol {
                            order: 1;
                          .CX3 .event.singleday .headline:not(.useSymbol)::before,
                          .CX3 .event.singleday .headline.useSymbol .symbol.noSymbol::before {
                            content: "⬤";
                            color: var(--calendarColor);
                            display: inline-block;
                            padding-right: 2px;
                            font-size: 75%;
                          .CX3 .event .headline:not(.useSymbol) .symbol {
                            display: none;
                          .CX3 .event .headline.useSymbol .symbol {
                            padding-right: 2px;
                            font-size: 75%;
                            align-self: center;
                          .CX3 .event.singleday .headline.useSymbol .symbol {
                          From the module .css file for MMM-CalendarExt3Agenda:
                          .CX3A .event .headline .symbol {
                            font-size: 75%;
                            vertical-align: text-bottom;
                          .CX3A .event .headline .symbol.noSymbol::after {
                            content: "⬤";
                            luisestrada @MMRIZE
                            @MMRIZE said in MMM-CalendarExt3Agenda:
                            @luisestrada
                            locale: "es-MX",
                            	style: "short",
                            locale: "es-MX",
                            	style: "short",
                            firstDayOfWeek: 1,
                            locale: "es-ES",
                            Thank you so much, it’s working perfectly. I had Spanish Colombia but I ended up switching to Mexico to make it work.
                              MMRIZE @ZiggidyZ
                              @ZiggidyZ
                              Sorry for late reply.
                              /* In your custom.css */
                              .CX3A .cellBody .fullday .event .headline .symbol,
                              .CX3A .cellBody .fullday .event .headline .symbol * {
                                color: var(--oppositeColor);
                                jimmy_382837
                                1.4.2 looks great, thanks for the update!
                                i wanted to change the color of the weekend days from dodgerblue and crimson to a diff color. i had the below in my custom.css file from the previous version of the module, but it doesn’t seem to work any longer.
                                any suggestions?
                                .CX3A {
                                  font-size: 16px;
                                  min-width: 300px;
                                  max-width: 400px;
                                  text-align: left;
                                  color: lightgray;
                                  --saturdayColor: rgb(147, 112, 219);
                                  --sundayColor: rgb(147, 112, 219);
                                  --todayColor: rgb(210,105,30);
                                  --weekend_1_color: rgb(147, 112, 219);
                                  --weekend_2_color: rgb(147, 112, 219);
                                • F Offline
                                  ffingers6
                                  I was curious if it was possible to get a row view similar to the way MMM-CalendarExt2 worked. I have a good setup that works well for our use case, but want to move to CX3 if possible for some additional features and the reliance on the default calendar module for parsing.
                                  This is my current setup…is it possible to adjust agenda to look like this? I can deal with the styling, but changing to a row format is the big question for me.
                                  M D 3 Replies Last reply Reply Quote 0
                                    MMRIZE @ffingers6
                                    @ffingers6
                                    I’ll try soon.
                                      MMRIZE @ffingers6
                                      @ffingers6
                                      /* config/config.js */
                                          broadcastEvents: true,
                                          defaultSymbolClassName: "", // This is needed to use the iconify icons instead of the font-awesome icons
                                                symbol: "noto:calendar",
                                                url: "...",
                                                color: "violet",
                                        module: "MMM-CalendarExt3Agenda",
                                        position: "bottom_bar",
                                          showMiniMonthCalendar: false,
                                          locale: "en-US",
                                          startDayIndex: 0,
                                          endDayIndex: 2,
                                          useIconify: true,
                                      /* css/custom.css */
                                      .CX3A {
                                        max-width: 100%;
                                      .CX3A .agenda {
                                        display: flex;
                                        flex-flow: row nowrap;
                                        justify-content: space-between;
                                        gap: 10px;
                                        mask-image: none;
                                      .CX3A .agenda .cell {
                                        flex-grow: 1;
                                        flex-basis: 0;
                                        border-bottom: none;
                                      .CX3A .agenda .cell .cellHeader {
                                        border-bottom: 2px solid gray;
                                        margin-bottom: 5px;
                                      .CX3A .agenda .cell .cellHeaderMain {
                                        flex-grow: 1;
                                        padding: 5px;
                                      .CX3A .event.singleday {
                                        border-left: 2px solid var(--calendarColor);
                                        padding-left: 3px;
                                        margin-bottom: 1px;
                                        background-color: color-mix(in srgb, var(--calendarColor), transparent 75%);
                                      .CX3A .event .time {
                                        order: 2;
                                      .CX3A .event .title {
                                        flex-grow: 2;
                                      .CX3A .cellBody {
                                        line-height: 120%;
                                      .CX3A .cellBody .fullday {
                                        padding-bottom: 5px;
                                      .CX3A .cellBody .fullday .event {
                                        max-width: 100%;
                                      For the size, you may need some manual adjustment for your view.
                                        cyberphox @MMRIZE
                                        Got tired of looking at the update notification today. Did a git pull and npm install…module isn’t showing at all now…
                                        Should have left it alone…sigh
                                          MMRIZE @cyberphox
                                          @cyberphox share me your config.(eouia0819@gmail.com)
                                            cyberphox @MMRIZE
                                            @MMRIZE sent! thanks for having a look!
                                            • 10
                                            • 11
                                            • 12
                                            • 8 / 12
