    MMM-CalendarExt3Agenda
    224 Posts 30 Posters 429.5k Views 32 Watching
      MMRIZE
      @htilburgs
      But I’m sorry, I forgot to implement that feature until now. :D.(nobody found it was not implemented )I fix it now. You can update the module and use that instanceId selector. Sorry again. :D
      htilburgsH 2 Replies Last reply Reply Quote 0
      • htilburgsH
        htilburgs @MMRIZE
        @MMRIZE
        I didn’t see it either in the documentation, my mistake. Thanks for the quick reply and fix. I’ll try when I’m at home.
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs if you have 2 instance and want different css behavior, then you need to add more entries to custom.css using another selector prefix
          you can add a fake name to the classes property (at same level as module and position) and use that name instead of .CX3A.
          note the dot in front means classname
          htilburgsH 1 Reply Last reply Reply Quote 0
          • htilburgsH
            htilburgs @sdetweil
            @sdetweil thanks Sam for the extra explanation.
              sdetweil @htilburgs
              @htilburgs so an example
              in the second instance of agenda
              add
                classes:"agenda2",
              after the
                module:"MMM-CalendarExt3Agenda",
              and in the css
              copy all the .CX3A settings you have
              and add
              .agenda2
              and a space after .agenda2
              as the start of the line w .CX3A
              .agenda2 .CX3A ....
              on all the newly duplicated lines
              leave out the ones you don’t want on the second instance of course
              • htilburgsH
                htilburgs @MMRIZE
                @MMRIZE I’ve tried, but no luck
                • htilburgsH
                  htilburgs @sdetweil
                  @sdetweil Yes! This works. Thanks
                    danny607 @ffingers6
                    @ffingers6 how do you get that view? can you post out the config.js and or relevant module JS thanks.
                      MMRIZE @danny607
                      @danny607
                      https://forum.magicmirror.builders/topic/16976/mmm-calendarext3agenda/152?_=1725781945711
                      • M MMRIZE referenced this topic on
                        Dr8ke
                        This is a great module thank you!
                        It may be something obvious but I’ve been searching without any luck. I’m trying to see how I can get more events to appear in the agenda. But I can seem to go beyond what’s in the screenshot. I’ll be using portrait mode so I have lots of room. I’ve include my config file and CSS file if that helps. Any help would be much appreciated, thank you!
                        Config.js
                        	module: 'calendar',
                        			header: "Calendar",
                        			//position: 'top_center',   *Calendar is needed for the MMM-CalendarExt3Agenda but taking away it's position hides it.
                        						wrapEvents: true,
                        						fetchInterval: 300000,
                        						maximumEntries: 100,
                        						displaySymbol: true,
                        Custom.css
                        /******** CX3-Agenda ********/
                        /*Remove CW from the miniMonth*/
                        .CX3A .miniMonth .cw {
                          display: none;
                        /*show/hide event description or location*/
                        .CX3A .agenda .event .description,
                        .CX3A .agenda .event .location {
                          display: none;
                        .CX3A .cellBody .fullday .event .headline .symbol,
                        .CX3A .cellBody .fullday .event .headline .symbol * {
                          display: inline-block;
                          color: var(--oppositeColor);
                          sdetweil @Dr8ke
                          @Dr8ke here is the full size
                          .CX3A .agenda {
                            position: relative;
                            max-height: 600px;
                            overflow-y: hidden;  // if it gets bigger, truncate and hide
                            mask-image: linear-gradient(to bottom, transparent, black 10%);
                            -webkit-mask-image: -webkit-linear-gradient(90deg, transparent, black 10%);
                            Dr8ke @sdetweil
                            Thank you very much!
                              sdetweil @Dr8ke
                              @Dr8ke that was from the module css
                                bassin12
                                Good day everyone, I just resurrect my MagicMirror and I saw so many new things and loving the new modules, got everything to work but haven’t figure out one thing with the CalendarExt3Agenda, I would like to display only today events, I tried different configurations with:
                                			startDayIndex: 0,
                                			endDayIndex: 1,
                                With this, I get today and tomorrow, and I know this is right, but when I try
                                			startDayIndex: 0,
                                			endDayIndex: 0,
                                I get a blank today without any event being display, any clue?
                                Leo
                                  MMRIZE @bassin12
                                  @bassin12
                                  I’ll look inside; maybe it was my mistake.
                                    MMRIZE @bassin12
                                    @bassin12
                                    Updated. There was a logical bug in the code. Sorry.
                                      bassin12 @MMRIZE
                                      @MMRIZE Nothing to apologize for, it is a great module.
                                      Leo
                                        shizzlesticks
                                        Hi all. I just updated to the latest release of MagicMirror code to take advantage of the fixes for recurring calendar events. Unfortunately all of my calendars with MMM-CalendarExt3Agenda are showing no events after the update. However, I do see that it’s loading them from the ical addresses in the debug logs.
                                        Anyone else having this problem?
                                          sdetweil @shizzlesticks
                                          @shizzlesticks see
                                          https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events
                                            shizzlesticks @sdetweil
                                            @sdetweil that worked, thanks!
                                            • 10
                                            • 11
                                            • 12
                                            • 9 / 12
