    Need help for rewrite node_helper.js from 'request' to 'got'
    19 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @htilburgs
      @htilpburgs I was going to say the result of json() is passed already
      htilburgsH 1 Reply Last reply Reply Quote 0
      • htilburgsH Offline
        htilburgs @sdetweil
        As far as I can see this works the correct way.
        Do you agree?
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs depends on what you mean by correct.
          it returns the parsed text as an object
          not text.
          htilburgsH S 2 Replies Last reply Reply Quote 0
            htilburgs @sdetweil
            That I don’t understand.
            Is this a problem? What would be better?
              sdetweil @htilburgs
              @htilburgs the response.json() function returns a js object already parsed.
              thst is what yiy were going to fo w JSON.parse(). but don’t need to.
              I don’t know if the CONTENT of the object is correct, but it should be for the same request
                htilburgs @sdetweil
                In the previous version with ‘request’ I used JSON.parse() and got the same results.
                The module works, but I didn’t know for sure if I used the correct approach.
                  sdetweil @htilburgs
                  @htilburgs if you push the repo I’ll look at it… you can do it on a separate branch to not disturb the existing
                    htilburgs @sdetweil
                    @sdetweil published it. Didn’t know how than on Master.
                      sdetweil @htilburgs
                      @htilburgs ok, I’ll look at it first thing in the morning
                        @htilburgs I made a couple changes to the Js and added comments to the node_helper, but all looks ok …
