    Need help for rewrite node_helper.js from 'request' to 'got'
    19 Posts 2 Posters 2.8k Views 2 Watching
    • htilburgsH Offline
      htilburgs
      As we all know, the Nodejs module “request” is deprecated.
      I like to rewrite my node_helper.js module so request is not used anymore. Instead the Nodejs module “got” will be used.
      Module: https://github.com/htilburgs/MMM-MyPrayerTimes
      Can someone help me on my way?
      I’m not a developer and just do it for fun.
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs just use the built in fetch
        no libraries needed
        fetch is in node 18 or above and electron 26 or above.
        very similar to request.
        look at the calendar fetcher js, which used request before.
        htilburgsH 2 Replies Last reply Reply Quote 0
          htilburgs @sdetweil
          Oké, made a start.
          Changed my node_helper.js to:
          MMM-MyPrayerTimes
          Copyright (C) 2019 - H. Tilburgs
          MIT License
          const NodeHelper = require('node_helper');
            start: function() {
                    console.log("Starting node_helper for: " + this.name);
           getMPT: function(url) {
                  // Make a GET request using the Fetch API
                  fetch(url)
                  .then(response => {
                  if (!response.ok) {
                    throw new Error('Network response was not ok');
                  return response.json();
              .then(result => {
              // Process the retrieved user data
              console.log(result);
              this.sendSocketNotification('MPT_RESULT', result);
            .catch(error => {
              console.error('Error:', error);
                      if (notification === 'GET_MPT') {
                      this.getMPT(payload);
          In the console I see the data:
          [2024-06-24 21:39:44.867] [LOG]   {
            code: 200,
            status: 'OK',
            data: {
              timings: {
                Fajr: '03:08',
                Sunrise: '05:21',
                Dhuhr: '13:40',
                Asr: '18:03',
                Sunset: '21:59',
                Maghrib: '21:59',
                Isha: '00:04',
                Imsak: '02:58',
                Midnight: '01:40',
                Firstthird: '00:26',
                Lastthird: '02:54'
              date: {
                readable: '24 Jun 2024',
                timestamp: '1719257984',
                hijri: [Object],
                gregorian: [Object]
              meta: {
                latitude: 51.48167,
                longitude: 5.66111,
                timezone: 'Europe/Amsterdam',
                method: [Object],
                latitudeAdjustmentMethod: 'ANGLE_BASED',
                midnightMode: 'STANDARD',
                school: 'STANDARD',
                offset: [Object]
          Only 1 problem, times are not displayed in de module
          I know it has something to do with
          var result = JSON.parse(body).data.timings;               //
          but I’m having troubles with this.
          When I replace body with result, I get an error.
          I’ve been looking for a solution for a few days now, but no result.
          Some help is appreciated ;-)
            htilburgs @sdetweil
            I kept on searching and think I’ve found it.
            I didn’t use JSON.parse(), but simply put it in the result
                this.sendSocketNotification('MPT_RESULT', result.data.timings);
            It works, but I hope this is the right way.
              sdetweil @htilburgs
              @htilpburgs I was going to say the result of json() is passed already
              htilburgsH 1 Reply Last reply Reply Quote 0
                htilburgs @sdetweil
                As far as I can see this works the correct way.
                Do you agree?
                  sdetweil @htilburgs
                  @htilburgs depends on what you mean by correct.
                  it returns the parsed text as an object
                  not text.
                  htilburgsH S 2 Replies Last reply Reply Quote 0
                    htilburgs @sdetweil
                    That I don’t understand.
                    Is this a problem? What would be better?
                      sdetweil @htilburgs
                      @htilburgs the response.json() function returns a js object already parsed.
                      thst is what yiy were going to fo w JSON.parse(). but don’t need to.
                      I don’t know if the CONTENT of the object is correct, but it should be for the same request
                        htilburgs @sdetweil
                        In the previous version with ‘request’ I used JSON.parse() and got the same results.
                        The module works, but I didn’t know for sure if I used the correct approach.
                          sdetweil @htilburgs
                          @htilburgs if you push the repo I’ll look at it… you can do it on a separate branch to not disturb the existing
                            htilburgs @sdetweil
                            @sdetweil published it. Didn’t know how than on Master.
                              sdetweil @htilburgs
                              @htilburgs ok, I’ll look at it first thing in the morning
                                @htilburgs I made a couple changes to the Js and added comments to the node_helper, but all looks ok …
                                  htilburgs @sdetweil
                                  Hi Sam, thanks in advance. I’m not at home right now and I only have my smartphone. I cannot test, but I’ll try it in a day.
                                  I’ll let you know!!
                                    sdetweil @htilburgs
                                    @htilburgs no rush at your availability.
                                      htilburgs @sdetweil
                                      Sam, you put a comment in node_helper.js.
                                      I don’t understand what you mean.
                                      // don’t need this anymore with async below
                                        sdetweil @htilburgs
                                        @htilburgs ignore. I tried async didn’t help
                                          htilburgs @sdetweil
