    Need help for rewrite node_helper.js from 'request' to 'got'
    19 Posts 2 Posters 2.4k Views 2 Watching
    • htilburgsH Offline
      htilburgs @sdetweil
      As far as I can see this works the correct way.
      Do you agree?
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        sdetweil @htilburgs
        @htilburgs depends on what you mean by correct.
        it returns the parsed text as an object
        not text.
        htilburgsH S 2 Replies Last reply Reply Quote 0
          htilburgs @sdetweil
          That I don’t understand.
          Is this a problem? What would be better?
            sdetweil @htilburgs
            @htilburgs the response.json() function returns a js object already parsed.
            thst is what yiy were going to fo w JSON.parse(). but don’t need to.
            I don’t know if the CONTENT of the object is correct, but it should be for the same request
            htilburgsH 1 Reply Last reply Reply Quote 0
              htilburgs @sdetweil
              In the previous version with ‘request’ I used JSON.parse() and got the same results.
              The module works, but I didn’t know for sure if I used the correct approach.
                sdetweil @htilburgs
                @htilburgs if you push the repo I’ll look at it… you can do it on a separate branch to not disturb the existing
                  htilburgs @sdetweil
                  @sdetweil published it. Didn’t know how than on Master.
                    sdetweil @htilburgs
                    @htilburgs ok, I’ll look at it first thing in the morning
                      @htilburgs I made a couple changes to the Js and added comments to the node_helper, but all looks ok …
                        htilburgs @sdetweil
                        Hi Sam, thanks in advance. I’m not at home right now and I only have my smartphone. I cannot test, but I’ll try it in a day.
                        I’ll let you know!!
