    Install MM on Debian 12
    11 Posts 2 Posters 3.0k Views 2 Watching
      DarrenO 0
      Hi
      I currently run MagicMirror on a Debian11 system on an Intel NUC and decided to upgrade the OS to Debian12 using apt full-upgrade.
      After rebooting the system, I am prompted to login at a Debian login screen and then presented with an option to select a “Desktop” to work from. MagicMirror is no longer automatically displayed.
      Deciding to rebuild from scratch, I flashed a USB with the Debian12 ISO and performed a clean install, selecting to enable the SSH Server option and uncheck all optional Desktops except for the base Desktop environment.
      Do I have to install a Desktop environment other than the default?
      I’ve reconfigured the system to autologin instead of prompting the user to login, but how can I set it to go direct to a Desktop instead?
      I then proceeded to install MagicMirror, but it does not display even though I opted to do so during the installation.
      Any assistance would be greatly appreciated.
        sdetweil @DarrenO 0
        @DarrenO-0 interesting.
        I have not upgraded to Debian 12 but have installed 12 without problems.
        and then my install script worked as
        before. I have tried both Wayland and x11 without issue.
        if you don’t have desktop then MagicMirror cannot display, as it is using a browser which requires desktop graphical mode.
        hmm
        maybe I installed Ubuntu 24.04
        ill try Debian tomorrow
          @DarrenO-0 I lied… I am trying it now… I’ll be awake all night otherwise…lol
          S D 2 Replies Last reply
            @DarrenO-0
            pm2 is having trouble on debian 12. I opened an issue on pm2 and wayland a few weeks ago
            https://github.com/Unitech/pm2/issues/5820
            its the same error
            0|MagicMirror  | Authorization required, but no authorization protocol specified
            0|MagicMirror  | [13888:0625/223821.984899:ERROR:ozone_platform_x11.cc(244)] Missing X server or $DISPLAY
            0|MagicMirror  | [13888:0625/223821.984944:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
            PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
            pm2 stop all
            npm start
            works fine (running in my vmware as a vm)
            D 1 Reply Last reply
              DarrenO 0 @sdetweil
              @sdetweil LOL. Thanks
              I’ll wait to hear back what you find out.
              I figured there’d have to be some sort of Desktop environment for it to work on a physical machine.
              Just didn’t/don’t know if I had to use of the various Desktop flavors available during the OS installation or if I could just use the base Debian environment.
                DarrenO 0 @sdetweil
                @sdetweil yeah, that was the error I was seeing in the pm2 logs as well
                Perhaps, I’ll have to go back to Debian 11 for the time being.
                  sdetweil @DarrenO 0
                  @DarrenO-0 there might be some way to switch back to x11. I know raspi bookworm provides that
                    DarrenO 0 @sdetweil
                    Just trying Debian12 again and ran your script.
                    It failed during the node and npm installation stage…
                    installing correct version of node and npm, please wait
                    curl: (92) HTTP/2 stream 1 was not closed cleanly: INTERNAL_ERROR (err 2)
                    xz: (stdin): Unexpected end of input
                    tar: Unexpected EOF in archive
                    tar: Error is not recoverable: exiting now
                    Error: failed to download archive for 20.8.0
                    node failed to install, exiting
                    Going back to Debian11 now to see if I can get things back up and running.
                      sdetweil @DarrenO 0
                      @DarrenO-0 that is a networking error.
                        DarrenO 0 @sdetweil
                        @sdetweil retried 3x and same result.
                        I was SSH’d into the device at the time and it had internet access at all times
                          sdetweil @DarrenO 0
                          @DarrenO-0 I just execute the curl command. I have no control over its networking code.
                          every time it’s failed due to networking there has been a real problem somewhere
