    Install MM on Debian 12
    11 Posts 2 Posters 2.7k Views 2 Watching
      sdetweil @DarrenO 0
      @DarrenO-0 interesting.
      I have not upgraded to Debian 12 but have installed 12 without problems.
      and then my install script worked as
      before. I have tried both Wayland and x11 without issue.
      if you don’t have desktop then MagicMirror cannot display, as it is using a browser which requires desktop graphical mode.
      hmm
      maybe I installed Ubuntu 24.04
      ill try Debian tomorrow
        @DarrenO-0 I lied… I am trying it now… I’ll be awake all night otherwise…lol
        S D 2 Replies Last reply Reply Quote 0
          @DarrenO-0
          pm2 is having trouble on debian 12. I opened an issue on pm2 and wayland a few weeks ago
          https://github.com/Unitech/pm2/issues/5820
          its the same error
          0|MagicMirror  | Authorization required, but no authorization protocol specified
          0|MagicMirror  | [13888:0625/223821.984899:ERROR:ozone_platform_x11.cc(244)] Missing X server or $DISPLAY
          0|MagicMirror  | [13888:0625/223821.984944:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
          PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
          pm2 stop all
          npm start
          works fine (running in my vmware as a vm)
            DarrenO 0 @sdetweil
            @sdetweil LOL. Thanks
            I’ll wait to hear back what you find out.
            I figured there’d have to be some sort of Desktop environment for it to work on a physical machine.
            Just didn’t/don’t know if I had to use of the various Desktop flavors available during the OS installation or if I could just use the base Debian environment.
              DarrenO 0 @sdetweil
              @sdetweil yeah, that was the error I was seeing in the pm2 logs as well
              Perhaps, I’ll have to go back to Debian 11 for the time being.
                sdetweil @DarrenO 0
                @DarrenO-0 there might be some way to switch back to x11. I know raspi bookworm provides that
                  DarrenO 0 @sdetweil
                  Just trying Debian12 again and ran your script.
                  It failed during the node and npm installation stage…
                  installing correct version of node and npm, please wait
                  curl: (92) HTTP/2 stream 1 was not closed cleanly: INTERNAL_ERROR (err 2)
                  xz: (stdin): Unexpected end of input
                  tar: Unexpected EOF in archive
                  tar: Error is not recoverable: exiting now
                  Error: failed to download archive for 20.8.0
                  node failed to install, exiting
                  Going back to Debian11 now to see if I can get things back up and running.
                    sdetweil @DarrenO 0
                    @DarrenO-0 that is a networking error.
                      DarrenO 0 @sdetweil
                      @sdetweil retried 3x and same result.
                      I was SSH’d into the device at the time and it had internet access at all times
                        sdetweil @DarrenO 0
                        @DarrenO-0 I just execute the curl command. I have no control over its networking code.
                        every time it’s failed due to networking there has been a real problem somewhere
