    Update needed
    5 Posts 4 Posters 1.3k Views 4 Watching
      Bungle68
      Hi all
      It’s been a long time since I was last here.
      I’ve not used my MM for over a year.
      I’ve just booted it up and I need to update the MM software, as it’s 219 comments behind.
      Will I just be better off with a fresh install?
      I can’t even remember how to upgrade it.
      Any help would be appreciated 🙏
      S BKeyportB M 3 Replies Last reply Reply Quote 0
        sdetweil @Bungle68
        @Bungle68 what OS level are you on?
        do
        lsb_releaee -a
        if it’s buster, the latest release won’t run there.
        to help migrate , back up your config and modules list
        use my backup/restore
        https://github.com/sdetweil/MagicMirror-backup-restore
        and to install or upgrade, use my scripts
        all of the scripts can be run directly from github.
        • BKeyportB Offline
          BKeyport Module Developer @Bungle68
          @Bungle68 Personally, I’d just start over.
            MMRIZE @Bungle68
            @Bungle68
            If you don’t need, you don’t have to update.
            You don’t know whether it will be better to do update, you don’t have to.
            If you decide to do update, I recommend to start over from formatting SD card. It will be easier.
              Bungle68 @MMRIZE
              @MMRIZE I’m thinking that probably going to be the easier option.
              Just need to make time to get it done. 👍
