    MMM-MyScoreboard
    277 Posts 60 Posters 634.4k Views 63 Watching
      sdetweil @1a2a3a
      @1a2a3a I was specifying the logic of you selector clause
      . means class
      if there are multiple . in a string with no spaces it means
      all these classes MUST be specified on the element explicitly
      so you have some weak ands (with spaces)
      .MMM-MyScoreboard (weak and) .box-score.stackedWithLogos.home-team-first (weak and) .score.visitor
      and some ABSOLUTE ands
      .box-score(ABSOLUTE and).stackedWithLogos(ABSOLUTE and).home-team-first
      all these classes MUST be on the same element
      class=“box-score stackedWithLogos home-team-first”
      and
      .score(ABSOLUTE and).visitor
      class=“score visitor”
      1 1 Reply Last reply Reply Quote 0
      • 1 Offline
        1a2a3a @sdetweil
        weak? absolute?
          sdetweil @1a2a3a
          @1a2a3a
            <div class="MMM-MyScoreboard">
               <div class="box-score">
                     <div class="stackedWithLogos home-team-first">
                           <div >some text </div>
               <div class="box-score stackedWithLogos home-team-first>hit the jackpot</div>
           </div>
          because your second part of the selector clause has no spaces,
          ALL THREE classes MUST appear in the class= of the element (absolute AND)
          so the element with ‘some text’ will NOT be selectable
          but element WITH all three, hit the jackpot, WILL BE selectable
          (selectable depending on the next 2 classes, which I didn’t show)
          S 1 2 Replies Last reply Reply Quote 0
            SirFM @sdetweil
            I haven’t dove into the code but do you know if the W-L record of the teams could easily be displayed?
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil I can’t Sam, I really can’t. Spent 3 days trying to get this and cron job for schedule on off on Wayland. Managed to get cron to work finally, but no dice on this.
                sdetweil @1a2a3a
                @1a2a3a i understand… open the developers window on the MM browser (best to use the PC browser)
                ctrl-shift-i
                select the elements tab
                select the pointer in the top left of the elements tab
                move the mouse pointer over the MM web page contents to you get to the MMM-MyScoreboard module, all the content should be highlighted
                click mouse
                in the developers window, the (selected by click) module content will be shown
                with all the classes and explicit attributes attached…
                see this topic with screen shots to help see my post here
                https://forum.magicmirror.builders/post/90135
                • 1 Offline
                  1a2a3a
                  anyone having issue with the module? its not showing anything now despite games being on.
                  getting something like this in the dev mode
                  M-MyScoreboard] Updating Scores
                  module.js:367 Parameter mismatch in module.hide: callback is not an optional parameter!
                  main.js:671 module tries to update the DOM without being displayed.
                    crcowan
                    It appears that the SportsNet feed is not updating during the day. It shows a scores of zero all day.
                      Dysantic @crcowan
                      @crcowan
                      Sportsnet made a change to the hostname for the API, yet their old hostname (and the one this module uses) still has access to the “pre-game” data, which is why we still see the game time, but no live updates or post-game scores.
                      A quick fix is to go into the “SNET.js” file, and look for:
                      var url = "https://mobile-statsv2.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                      Update the hostname from “mobile-statsv2.sportsnet.ca” to “stats-api.sportsnet.ca” like so:
                      var url = "https://stats-api.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                      The API output is still formatted as the module expects, and all should work again.
                      I’ve submitted a pull request, and hopefully I did this correctly… it’s my first time submitting an update via GitHub:
                      https://github.com/jclarke0000/MMM-MyScoreboard/pull/91
                      W blake_northrupB 2 Replies Last reply Reply Quote 1
                      • W Offline
                        wyovino @Dysantic
                        I’d like to increase the size of the start time for an upcoming game. Which element in the CSS file would that be?
                          sdetweil @wyovino
                          @wyovino I do not know
                          you can look at the css provided by the module in the module folder. it may give you info about that content style
                          you can also use the developer window to examine and change styles to determine how to set custom.css
                          see this post
                          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues/2?_=1720443608424
                          W 1 Reply Last reply Reply Quote 1
                          • E Offline
                            ericsprime18
                            • W Offline
                              wyovino @sdetweil
                              For anyone else interested, I changed the following in the MMM-MyScoreboard.css file:
                              In the "MMM-MyScoreboard .box-score .status " section
                              font-size: 20px;
                              font-weight: 400;
                              To:
                              font-sze: 30px;
                              font-weight: bold;l
                              • blake_northrupB Offline
                                blake_northrup @Dysantic
                                @Dysantic Thank you for this fix @Dysantic! Works like a charm!
                                • O Offline
                                  ogunn
                                  @blake_northrup can you post your config code for your scoreboard because I still can’t get it to load. Thanks,
                                    dathbe @ogunn
                                    FYI, i have taken over maintaining this module and have made some updates. anyone interested can check out at https://github.com/dathbe/MMM-MyScoreboard .
                                    open an issue if you have problems or a suggestion.
                                    BKeyportB 1 Reply Last reply Reply Quote 1
                                    • BKeyportB Offline
                                      BKeyport Module Developer @dathbe
                                      @dathbe Thank you. I’ve wanted to install this module again, but I have worries about longevity.
                                        dathbe @BKeyport
                                        @BKeyport Awesome. Unrelated, but I love your MMM-Multimonth.
                                        • 10
                                        • 11
                                        • 12
                                        • 13
                                        • 14
                                        • 14 / 14
