    MMM-MyScoreboard
    277 Posts 60 Posters 650.2k Views 63 Watching
      1a2a3a
      @j-e-f-f how do you reduce the font size of the content? i maanged to reduce them in css but then when the next game appear, the entire thing is back to default.
      these are the 2 css i made but it seems like it doesnt port over to another game…
      .MMM-MyScoreboard .box-score.stackedWithLogos.home-team-first .score.home {
      left: 120px;
      font-size: 0.8rem;
      .MMM-MyScoreboard .box-score.stackedWithLogos.home-team-first .score.visitor {
      left: 120px;
      font-size: 0.8rem;
        sdetweil @1a2a3a
        @1a2a3a said in MMM-MyScoreboard:
        the logic of your css selector clause is
        elements in elements with class MMM-MyScoreboard
        AND
        elements with ALL classes specified on the same element
         classes box-score **AND** stackedWithLogos **AND** home-team-first
        AND
            .score.visitor
        classes  score   **AND** visitor
        1 1 Reply Last reply
          1a2a3a @sdetweil
          @sdetweil i dont understand sam…
          did you mean like this?
          .MMM-MyScoreboard .box-score AND stackedWithLogos AND home-team-first .score AND visitor {
          left: 120px;
          font-size: 0.8rem;
            sdetweil @1a2a3a
            @1a2a3a I was specifying the logic of you selector clause
            . means class
            if there are multiple . in a string with no spaces it means
            all these classes MUST be specified on the element explicitly
            so you have some weak ands (with spaces)
            .MMM-MyScoreboard (weak and) .box-score.stackedWithLogos.home-team-first (weak and) .score.visitor
            and some ABSOLUTE ands
            .box-score(ABSOLUTE and).stackedWithLogos(ABSOLUTE and).home-team-first
            all these classes MUST be on the same element
            class=“box-score stackedWithLogos home-team-first”
            and
            .score(ABSOLUTE and).visitor
            class=“score visitor”
              1a2a3a @sdetweil
              weak? absolute?
                sdetweil @1a2a3a
                @1a2a3a
                  <div class="MMM-MyScoreboard">
                     <div class="box-score">
                           <div class="stackedWithLogos home-team-first">
                                 <div >some text </div>
                     <div class="box-score stackedWithLogos home-team-first>hit the jackpot</div>
                 </div>
                because your second part of the selector clause has no spaces,
                ALL THREE classes MUST appear in the class= of the element (absolute AND)
                so the element with ‘some text’ will NOT be selectable
                but element WITH all three, hit the jackpot, WILL BE selectable
                (selectable depending on the next 2 classes, which I didn’t show)
                S 1 2 Replies Last reply
                  SirFM @sdetweil
                  I haven’t dove into the code but do you know if the W-L record of the teams could easily be displayed?
                    1a2a3a @sdetweil
                    @sdetweil I can’t Sam, I really can’t. Spent 3 days trying to get this and cron job for schedule on off on Wayland. Managed to get cron to work finally, but no dice on this.
                      sdetweil @1a2a3a
                      @1a2a3a i understand… open the developers window on the MM browser (best to use the PC browser)
                      ctrl-shift-i
                      select the elements tab
                      select the pointer in the top left of the elements tab
                      move the mouse pointer over the MM web page contents to you get to the MMM-MyScoreboard module, all the content should be highlighted
                      click mouse
                      in the developers window, the (selected by click) module content will be shown
                      with all the classes and explicit attributes attached…
                      see this topic with screen shots to help see my post here
                      https://forum.magicmirror.builders/post/90135
                        1a2a3a
                        anyone having issue with the module? its not showing anything now despite games being on.
                        getting something like this in the dev mode
                        M-MyScoreboard] Updating Scores
                        module.js:367 Parameter mismatch in module.hide: callback is not an optional parameter!
                        main.js:671 module tries to update the DOM without being displayed.
                          crcowan
                          It appears that the SportsNet feed is not updating during the day. It shows a scores of zero all day.
                          D 1 Reply Last reply
                            Dysantic @crcowan
                            @crcowan
                            Sportsnet made a change to the hostname for the API, yet their old hostname (and the one this module uses) still has access to the “pre-game” data, which is why we still see the game time, but no live updates or post-game scores.
                            A quick fix is to go into the “SNET.js” file, and look for:
                            var url = "https://mobile-statsv2.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                            Update the hostname from “mobile-statsv2.sportsnet.ca” to “stats-api.sportsnet.ca” like so:
                            var url = "https://stats-api.sportsnet.ca/ticker?day=" + this.gameDate.format("YYYY-MM-DD");
                            The API output is still formatted as the module expects, and all should work again.
                            I’ve submitted a pull request, and hopefully I did this correctly… it’s my first time submitting an update via GitHub:
                            https://github.com/jclarke0000/MMM-MyScoreboard/pull/91
                            W blake_northrupB 2 Replies Last reply
                            • W
                              wyovino @Dysantic
                              I’d like to increase the size of the start time for an upcoming game. Which element in the CSS file would that be?
                                sdetweil @wyovino
                                @wyovino I do not know
                                you can look at the css provided by the module in the module folder. it may give you info about that content style
                                you can also use the developer window to examine and change styles to determine how to set custom.css
                                see this post
                                https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues/2?_=1720443608424
                                W 1 Reply Last reply
                                • E
                                  ericsprime18
                                  • W
                                    wyovino @sdetweil
                                    For anyone else interested, I changed the following in the MMM-MyScoreboard.css file:
                                    In the "MMM-MyScoreboard .box-score .status " section
                                    font-size: 20px;
                                    font-weight: 400;
                                    To:
                                    font-sze: 30px;
                                    font-weight: bold;l
                                    • blake_northrupB
                                      blake_northrup @Dysantic
                                      @Dysantic Thank you for this fix @Dysantic! Works like a charm!
                                      • O
                                        ogunn
                                        @blake_northrup can you post your config code for your scoreboard because I still can’t get it to load. Thanks,
                                          dathbe @ogunn
                                          FYI, i have taken over maintaining this module and have made some updates. anyone interested can check out at https://github.com/dathbe/MMM-MyScoreboard .
                                          open an issue if you have problems or a suggestion.
                                          BKeyportB 1 Reply Last reply
                                          • BKeyportB
                                            BKeyport Module Developer @dathbe
                                            @dathbe Thank you. I’ve wanted to install this module again, but I have worries about longevity.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 14 / 14
