    UPDATE: Replaced my PIR-Sensor with a Doppler Microwave Sensor.
    103 Posts 17 Posters 129.2k Views 25 Watching
    • kayakbabeK Offline
      kayakbabe @Lipax
      @Lipax try dialing down the sensitivity, it’s probably picking up dust or something small you can’t see.
      • L Offline
        Lipax
        thanks for the help, but i doubt its some kind of movement since its exactly every minute. i tried a different room and its the same.
          sdetweil @Lipax
          @Lipax please don’t submit duplicate posts…
          all users with reputation below 2 have their posts reviewed… this eliminates all the porn, advertising and trash posts from the forum.
          it just takes time for (me) to get to review the posts…
          • uros76U Offline
            uros76
            Can you share your python code? Perhaps there’s something there
            • L Offline
              Lipax @sdetweil
              @sdetweil sry about that
              @uros76 i hope thats not the problem
              import RPi.GPIO as GPIO
              import time
              import datetime
              switch=11
              GPIO.setmode(GPIO.BOARD)
              GPIO.setup(switch, GPIO.IN)
              try:
                  while True:
                      if GPIO.input(switch) == 1:
                          now = datetime.datetime.now()
                          print(now.strftime("%Y-%m-%d %H:%M:%S"), "something")
                      time.sleep(5)
              except KeyboardInterrupt:
                  print("Bye Bye")
              finally:
                  GPIO.cleanup()
              thanks for the help
              uros76U 1 Reply Last reply Reply Quote 0
              • uros76U Offline
                uros76 @Lipax
                @Lipax try different gpio pin, like a pin 18 which is a GPIO 5. It’s default set to input function. Don’t forget to adjust the python code, change switch to 18.
                You might check the GPIO 0 (your pin 11) if it is set to input. Use command: raspi-gpio get 0 or raspi-gpio get to check all GPIO’s.
                Also, use a multimeter to measure the voltage coming out from sensor. It should be around 3.3V for few seconds when sensing detected. This way you can monitor if actual detection / voltage is coming from sensor.
                • L Offline
                  Lipax @uros76
                  @uros76
                  i forget to mention i already changed the pin, i first tried pin 7 before
                  according to pinout.xyz my pin 11 is gpio 17
                  GPIO 17: level=0 fsel=0 func=INPUT
                  thank you very much for helping me, i dont have a multi meter but ill ask my father to do that. u think its not the sensor sending the signal? maybe it picks up something with the wire along the way? i dont have a engineering background.
                  • uros76U Offline
                    uros76 @Lipax
                    @Lipax you need to be sure that sensor is not the cause.
                    Measuring it’s sensing, output voltage and duration is a good way of confirming if sensor works ok.
                    • L Offline
                      Lipax @uros76
                      it took a long time but i tested the voltage, i can upload a video somewhere if u want. the wrong positive and the regular ones look the same for me. it kinda spikes to ~5v and then instantly goes to 3.3 and stabilizes
                      • uros76U Offline
                        uros76 @Lipax
                        @Lipax there you go, nothing wrong with the software code. It’s the PIR sensor giving false positives. Nothing you can really do about that. Perhaps a different brand/quality of PIR sensor if it will help but I doubt.
                        As mentioned before, due to exact same problem I gave up on PIR sensor completely and moved to the microwave. This works for me now over 3 years. without false positives.
                        • L Offline
                          Lipax @uros76
                          @uros76 ty ill maybe try to find another microwave sensor. pir i find really ugly try to stay away from them. really sad i didnt get the microwave sensor working. thanks for the help
                          • 6 / 6
