    Not updating at midnight...
    24 Posts 3 Posters 4.5k Views 3 Watching
    • BKeyportB
      @sdetweil The problem is that it’s not firing at all - it was working as is… Now it’s not firing, first, last, middle, or any other time.
        sdetweil @BKeyport
        @BKeyport make your own routine to be called
        this.update2()
        Prove it fires
        • BKeyportB
          @sdetweil It’s people like you that drive people out of coding. This isn’t fun anymore.
          Is there anyone other than Sam that could explain why this don’t work anymore?
            sdetweil @BKeyport
            @BKeyport that’s very disappointing to hear.
            I thought I was being helpful in giving ways to debug the problem.
            I do not KNOW why it appears to be failing. None of the changes to the mm core appear to affect updateDom
              MMRIZE
              How about this? not tested.
              start: function () {
                this.dailyTimer = null
                const moment = new Date()
                const midnight = new Date(moment.getFullYear(), moment.getMonth(), moment.getDate() + 1, 0, 0, 0, 0)
                const toMidnight = midnight - moment
                setTimeout(() => {
                  this.doSomething()
                }, toMidnight)
              doSomething: function () {
                clearTimeout(this.dailyTimer)
                // Do your job here.
                this.dailyTimer = setTimeout(() => {
                  this.doSomething()
                }, 24 * 60 * 60 * 1000)
                sdetweil @MMRIZE
                @MMRIZE right, thats a way without interval timer
                I added this to compliments with the cron entries to get the interval synched to the minute
                 let minute_sync_delay = 1;
                		// loop thru all the configured when events
                		for (let m of Object.keys(this.config.compliments)) {
                			// if it is a cron entry
                			if (this.isCronEntry(m)) {
                				// we need to synch our interval cycle to the minute
                				minute_sync_delay = (60 - (moment().second())) * 1000;
                				break;
                		// Schedule update timer. sync to the minute start (if needed), so minute based events happen on the minute start
                		setTimeout(() => {
                			setInterval(() => {
                				this.updateDom(this.config.fadeSpeed);
                			}, this.config.updateInterval);
                		minute_sync_delay);
                  sdetweil @MMRIZE
                  @MMRIZE one thing
                  You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
                  • BKeyportB
                    @MMRIZE @sdetweil
                    the reporter posted this to my github:
                    I am not a javascript expert, but have some experience in C++ and
                    microcontroller programming.
                    I have had some problems with other MagicMirror calendar modules not
                    updating the day properly and they also seem to implement workarounds and
                    have issues with the DOM updating.
                    I did a little looking into this and it seems there must be some generic
                    issue with the MagicMirror software allowing modules to implement timers
                    and date/time functions in realtime.
                    And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
                    There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
                    For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
                      sdetweil @BKeyport
                      @BKeyport logging
                      There are two logs
                      Node_helper goes to npm start console
                      Modulename.js goes to the browser log
                      There are a couple modules that will send the browser log records to the console
                      MMM-Logging, mmrize has an updated version, so do I.
                      I don’t know why it worked before, or why it’s not working now.
                      We added some checking for valid position names, instead of crashing
                      We added async to some mm functions, but
                      Timeout and interval are js functions.
                      Only way to debug the browser side is to use the developer window debugger (sources tab)
                        sdetweil @BKeyport
                        @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
                        • BKeyportB
                          I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
                          ASSUMING that’s the case, this seems to work better:
                              function scheduleMidnightUpdate() {
                                  const now = new Date();
                                  const nextMidnight = new Date(now);
                                  // Set the time to midnight
                                  nextMidnight.setHours(24, 0, 0, 0);
                                  // Calculate the time remaining until the next midnight
                                  const timeUntilMidnight = nextMidnight - now;
                                  // Schedule the updateDom method to be called at midnight
                                  setTimeout(() => {
                                      this.updateDom();
                                      // Reschedule the update for the next midnight
                                      scheduleMidnightUpdate.call(this);
                                  }, timeUntilMidnight);
                              // Call the function to start the first schedule
                          Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
                          Is there anyway y’all can see to improve this, or am I good?
                            MMRIZE @BKeyport
                            @BKeyport
                            Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                              sdetweil @MMRIZE
                              @MMRIZE
                              Yes the documented flow is, as I recall on my phone,
                              Init
                              Getstyles
                              Getscripts
                              GetTemplates
                              Start
                              Notification received
                              AllModulesStarted
                              DOMobjectsCreated
                              getDOM
                              • BKeyportB
                                @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                                  sdetweil @BKeyport
                                  @BKeyport after the notification
                                  From the doc
                                  DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                                  • BKeyportB
                                    @sdetweil said in Not updating at midnight...:
                                            setTimeout(() => {
                                                this.updateDom();
                                        notificationReceived: function (notification, payload, sender) {
                                            if (notification === 'CALENDAR_EVENTS') {
                                                this.storedEvents = JSON.parse(JSON.stringify(payload))
                                                this.updateDom();
                                            } else if (notification === 'DOM_OBJECTS_CREATED') {
                                    This is the only source I see in the docs of that - a notification. Is that correct?
                                    Thanks for the patience after the double misunderstanding.
                                      sdetweil @BKeyport
                                      @BKeyport
                                      https://docs.magicmirror.builders/development/core-module-file.html
                                      you could have done all the initial event calculating in one function
                                      used interval for the midnights (as it’s a fixed number)
                                        @BKeyport MODULE_DOM_CREATED means YOUR getDom()/getTemplateData() has been called
                                        • BKeyportB
                                          @sdetweil yeah, doing it that way just throws headers with “Undefined” until it triggers. I’m not gonna go down that rabbit hole. It seems to work as is, so I’m gonna release for now.
                                            sdetweil @BKeyport
                                            @BKeyport said in Not updating at midnight...:
                                                setTimeout(() => {
                                                    this.updateDom();
                                            I would do it like this , much more straight forward
                                                     setTimeout(() => {
                                                         // trigger first update on next midnight change
                                                         this.updateDom();
                                                        // start Recurring midnight change
                                                         setInterval(()=>{
                                                             this.updateDom()
                                                         }, 24*60*60*1000 ) // 24 hours * 60 minutes * 60 seconds * 1000 milliseconds (1 day elapsed in ms)  setInterval delay
                                                     }, timeUntilMidnight);  // setTimeout delay
                                            then the system triggers every midnight… not your code
