    Not updating at midnight...
    24 Posts 3 Posters 4.4k Views 3 Watching
      MMRIZE
      How about this? not tested.
      start: function () {
        this.dailyTimer = null
        const moment = new Date()
        const midnight = new Date(moment.getFullYear(), moment.getMonth(), moment.getDate() + 1, 0, 0, 0, 0)
        const toMidnight = midnight - moment
        setTimeout(() => {
          this.doSomething()
        }, toMidnight)
      doSomething: function () {
        clearTimeout(this.dailyTimer)
        // Do your job here.
        this.dailyTimer = setTimeout(() => {
          this.doSomething()
        }, 24 * 60 * 60 * 1000)
        sdetweil @MMRIZE
        @MMRIZE right, thats a way without interval timer
        I added this to compliments with the cron entries to get the interval synched to the minute
         let minute_sync_delay = 1;
        		// loop thru all the configured when events
        		for (let m of Object.keys(this.config.compliments)) {
        			// if it is a cron entry
        			if (this.isCronEntry(m)) {
        				// we need to synch our interval cycle to the minute
        				minute_sync_delay = (60 - (moment().second())) * 1000;
        				break;
        		// Schedule update timer. sync to the minute start (if needed), so minute based events happen on the minute start
        		setTimeout(() => {
        			setInterval(() => {
        				this.updateDom(this.config.fadeSpeed);
        			}, this.config.updateInterval);
        		minute_sync_delay);
          sdetweil @MMRIZE
          @MMRIZE one thing
          You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
          • BKeyportB Offline
            @MMRIZE @sdetweil
            the reporter posted this to my github:
            I am not a javascript expert, but have some experience in C++ and
            microcontroller programming.
            I have had some problems with other MagicMirror calendar modules not
            updating the day properly and they also seem to implement workarounds and
            have issues with the DOM updating.
            I did a little looking into this and it seems there must be some generic
            issue with the MagicMirror software allowing modules to implement timers
            and date/time functions in realtime.
            And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
            There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
            For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
              sdetweil @BKeyport
              @BKeyport logging
              There are two logs
              Node_helper goes to npm start console
              Modulename.js goes to the browser log
              There are a couple modules that will send the browser log records to the console
              MMM-Logging, mmrize has an updated version, so do I.
              I don’t know why it worked before, or why it’s not working now.
              We added some checking for valid position names, instead of crashing
              We added async to some mm functions, but
              Timeout and interval are js functions.
              Only way to debug the browser side is to use the developer window debugger (sources tab)
                sdetweil @BKeyport
                @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
                • BKeyportB Offline
                  I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
                  ASSUMING that’s the case, this seems to work better:
                      function scheduleMidnightUpdate() {
                          const now = new Date();
                          const nextMidnight = new Date(now);
                          // Set the time to midnight
                          nextMidnight.setHours(24, 0, 0, 0);
                          // Calculate the time remaining until the next midnight
                          const timeUntilMidnight = nextMidnight - now;
                          // Schedule the updateDom method to be called at midnight
                          setTimeout(() => {
                              this.updateDom();
                              // Reschedule the update for the next midnight
                              scheduleMidnightUpdate.call(this);
                          }, timeUntilMidnight);
                      // Call the function to start the first schedule
                  Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
                  Is there anyway y’all can see to improve this, or am I good?
                    MMRIZE @BKeyport
                    @BKeyport
                    Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                      sdetweil @MMRIZE
                      @MMRIZE
                      Yes the documented flow is, as I recall on my phone,
                      Init
                      Getstyles
                      Getscripts
                      GetTemplates
                      Start
                      Notification received
                      AllModulesStarted
                      DOMobjectsCreated
                      getDOM
                      • BKeyportB Offline
                        @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                          sdetweil @BKeyport
                          @BKeyport after the notification
                          From the doc
                          DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                          • BKeyportB Offline
                            @sdetweil said in Not updating at midnight...:
                                    setTimeout(() => {
                                        this.updateDom();
                                notificationReceived: function (notification, payload, sender) {
                                    if (notification === 'CALENDAR_EVENTS') {
                                        this.storedEvents = JSON.parse(JSON.stringify(payload))
                                        this.updateDom();
                                    } else if (notification === 'DOM_OBJECTS_CREATED') {
                            This is the only source I see in the docs of that - a notification. Is that correct?
                            Thanks for the patience after the double misunderstanding.
                              sdetweil @BKeyport
                              @BKeyport
                              https://docs.magicmirror.builders/development/core-module-file.html
                              you could have done all the initial event calculating in one function
                              used interval for the midnights (as it’s a fixed number)
                                @BKeyport MODULE_DOM_CREATED means YOUR getDom()/getTemplateData() has been called
                                • BKeyportB Offline
                                  @sdetweil yeah, doing it that way just throws headers with “Undefined” until it triggers. I’m not gonna go down that rabbit hole. It seems to work as is, so I’m gonna release for now.
                                    sdetweil @BKeyport
                                    @BKeyport said in Not updating at midnight...:
                                        setTimeout(() => {
                                            this.updateDom();
                                    I would do it like this , much more straight forward
                                             setTimeout(() => {
                                                 // trigger first update on next midnight change
                                                 this.updateDom();
                                                // start Recurring midnight change
                                                 setInterval(()=>{
                                                     this.updateDom()
                                                 }, 24*60*60*1000 ) // 24 hours * 60 minutes * 60 seconds * 1000 milliseconds (1 day elapsed in ms)  setInterval delay
                                             }, timeUntilMidnight);  // setTimeout delay
                                    then the system triggers every midnight… not your code
