    Not updating at midnight...
    24 Posts 3 Posters 4.8k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE right, thats a way without interval timer
      I added this to compliments with the cron entries to get the interval synched to the minute
       let minute_sync_delay = 1;
      		// loop thru all the configured when events
      		for (let m of Object.keys(this.config.compliments)) {
      			// if it is a cron entry
      			if (this.isCronEntry(m)) {
      				// we need to synch our interval cycle to the minute
      				minute_sync_delay = (60 - (moment().second())) * 1000;
      				break;
      		// Schedule update timer. sync to the minute start (if needed), so minute based events happen on the minute start
      		setTimeout(() => {
      			setInterval(() => {
      				this.updateDom(this.config.fadeSpeed);
      			}, this.config.updateInterval);
      		minute_sync_delay);
        sdetweil @MMRIZE
        @MMRIZE one thing
        You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @MMRIZE @sdetweil
          the reporter posted this to my github:
          I am not a javascript expert, but have some experience in C++ and
          microcontroller programming.
          I have had some problems with other MagicMirror calendar modules not
          updating the day properly and they also seem to implement workarounds and
          have issues with the DOM updating.
          I did a little looking into this and it seems there must be some generic
          issue with the MagicMirror software allowing modules to implement timers
          and date/time functions in realtime.
          And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
          There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
          For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
          S 2 Replies Last reply
            sdetweil @BKeyport
            @BKeyport logging
            There are two logs
            Node_helper goes to npm start console
            Modulename.js goes to the browser log
            There are a couple modules that will send the browser log records to the console
            MMM-Logging, mmrize has an updated version, so do I.
            I don’t know why it worked before, or why it’s not working now.
            We added some checking for valid position names, instead of crashing
            We added async to some mm functions, but
            Timeout and interval are js functions.
            Only way to debug the browser side is to use the developer window debugger (sources tab)
              sdetweil @BKeyport
              @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
              • BKeyportB
                I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
                ASSUMING that’s the case, this seems to work better:
                start: function () {
                    function scheduleMidnightUpdate() {
                        const now = new Date();
                        const nextMidnight = new Date(now);
                        // Set the time to midnight
                        nextMidnight.setHours(24, 0, 0, 0);
                        // Calculate the time remaining until the next midnight
                        const timeUntilMidnight = nextMidnight - now;
                        // Schedule the updateDom method to be called at midnight
                        setTimeout(() => {
                            this.updateDom();
                            // Reschedule the update for the next midnight
                            scheduleMidnightUpdate.call(this);
                        }, timeUntilMidnight);
                    // Call the function to start the first schedule
                Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
                Is there anyway y’all can see to improve this, or am I good?
                M 1 Reply Last reply
                  MMRIZE @BKeyport
                  @BKeyport
                  Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                    sdetweil @MMRIZE
                    @MMRIZE
                    Yes the documented flow is, as I recall on my phone,
                    Init
                    Getstyles
                    Getscripts
                    GetTemplates
                    Start
                    Notification received
                    AllModulesStarted
                    DOMobjectsCreated
                    getDOM
                    • BKeyportB
                      @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                        sdetweil @BKeyport
                        @BKeyport after the notification
                        From the doc
                        DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                        • BKeyportB
                          @sdetweil said in Not updating at midnight...:
                                  setTimeout(() => {
                                      this.updateDom();
                              notificationReceived: function (notification, payload, sender) {
                                  if (notification === 'CALENDAR_EVENTS') {
                                      this.storedEvents = JSON.parse(JSON.stringify(payload))
                                      this.updateDom();
                                  } else if (notification === 'DOM_OBJECTS_CREATED') {
                          This is the only source I see in the docs of that - a notification. Is that correct?
                          Thanks for the patience after the double misunderstanding.
                            sdetweil @BKeyport
                            @BKeyport
                            https://docs.magicmirror.builders/development/core-module-file.html
                            you could have done all the initial event calculating in one function
                            used interval for the midnights (as it’s a fixed number)
                              @BKeyport MODULE_DOM_CREATED means YOUR getDom()/getTemplateData() has been called
                              • BKeyportB
                                @sdetweil yeah, doing it that way just throws headers with “Undefined” until it triggers. I’m not gonna go down that rabbit hole. It seems to work as is, so I’m gonna release for now.
                                  sdetweil @BKeyport
                                  @BKeyport said in Not updating at midnight...:
                                      setTimeout(() => {
                                          this.updateDom();
                                  I would do it like this , much more straight forward
                                           setTimeout(() => {
                                               // trigger first update on next midnight change
                                               this.updateDom();
                                              // start Recurring midnight change
                                               setInterval(()=>{
                                                   this.updateDom()
                                               }, 24*60*60*1000 ) // 24 hours * 60 minutes * 60 seconds * 1000 milliseconds (1 day elapsed in ms)  setInterval delay
                                           }, timeUntilMidnight);  // setTimeout delay
                                  then the system triggers every midnight… not your code
