    Not updating at midnight...
    24 Posts 3 Posters 4.8k Views 3 Watching
    • BKeyportB
      I think you see it backwards.
      Look at the reset variable again.
      This line calculates the difference between the current time and midnight of the next day. It does this by creating a new Date object for the next day at 00:00:00.000 (midnight) and subtracting the current time from it.
      The variable timer is then set using the reset variable, so…
      new Date(year, month, nextday, 0, 0, 0, 0).getTime() - date.getTime()
      Assuming it’s currently 6:30pm on August 8th, 2024.
      2024/8/9 0:0:0.0 - 2024/8/8 18:30:0.0
      1723186800 - 1723167000 (Dropping the milliseconds if used)
      = 19800
      then the timer is set using setInterval() to “reset” or 19800 - which would be the next midnight.
      After the first one, it should be calculating so close to midnight, it’s an non-issue.
        sdetweil @BKeyport
        @BKeyport setInterval creates a repeating timer with ONE elapsed time
        6:30pm to midnight the next day is 24+5.5
        So every 29.5 hours it will fire.
        1st correct for tomorrow night,
        it will miss tonight’s midnight
        And then be off from them on, shifting 5.5 hours later each time
        24 hours of seconds is 86400
        If you think of it as morning, then it will fire every 5.5 hours. Still not 24
        After the first one, it should be calculating so close to midnight, it’s an non-issuee
        This part is incorrect. setInterval only looks at the value ONE time.
        Sorry, computer is stupid. It has one time event setTimeout, or interval setInterval. Both use the elapsed time only once, at creation
        BKeyportB 1 Reply Last reply
        • BKeyportB
          @sdetweil The problem is that it’s not firing at all - it was working as is… Now it’s not firing, first, last, middle, or any other time.
            sdetweil @BKeyport
            @BKeyport make your own routine to be called
            this.update2()
            Prove it fires
            • BKeyportB
              @sdetweil It’s people like you that drive people out of coding. This isn’t fun anymore.
              Is there anyone other than Sam that could explain why this don’t work anymore?
                sdetweil @BKeyport
                @BKeyport that’s very disappointing to hear.
                I thought I was being helpful in giving ways to debug the problem.
                I do not KNOW why it appears to be failing. None of the changes to the mm core appear to affect updateDom
                  MMRIZE
                  How about this? not tested.
                  start: function () {
                    this.dailyTimer = null
                    const moment = new Date()
                    const midnight = new Date(moment.getFullYear(), moment.getMonth(), moment.getDate() + 1, 0, 0, 0, 0)
                    const toMidnight = midnight - moment
                    setTimeout(() => {
                      this.doSomething()
                    }, toMidnight)
                  doSomething: function () {
                    clearTimeout(this.dailyTimer)
                    // Do your job here.
                    this.dailyTimer = setTimeout(() => {
                      this.doSomething()
                    }, 24 * 60 * 60 * 1000)
                  S 2 Replies Last reply
                    sdetweil @MMRIZE
                    @MMRIZE right, thats a way without interval timer
                    I added this to compliments with the cron entries to get the interval synched to the minute
                     let minute_sync_delay = 1;
                    		// loop thru all the configured when events
                    		for (let m of Object.keys(this.config.compliments)) {
                    			// if it is a cron entry
                    			if (this.isCronEntry(m)) {
                    				// we need to synch our interval cycle to the minute
                    				minute_sync_delay = (60 - (moment().second())) * 1000;
                    				break;
                    		// Schedule update timer. sync to the minute start (if needed), so minute based events happen on the minute start
                    		setTimeout(() => {
                    			setInterval(() => {
                    				this.updateDom(this.config.fadeSpeed);
                    			}, this.config.updateInterval);
                    		minute_sync_delay);
                      sdetweil @MMRIZE
                      @MMRIZE one thing
                      You can’t clear the timer if it has triggered, as the timer has expired. The handle is no longer valid
                      • BKeyportB
                        @MMRIZE @sdetweil
                        the reporter posted this to my github:
                        I am not a javascript expert, but have some experience in C++ and
                        microcontroller programming.
                        I have had some problems with other MagicMirror calendar modules not
                        updating the day properly and they also seem to implement workarounds and
                        have issues with the DOM updating.
                        I did a little looking into this and it seems there must be some generic
                        issue with the MagicMirror software allowing modules to implement timers
                        and date/time functions in realtime.
                        And Sam - I was telling you that it previously was working and works outside of the MM ecosystem - or at least sets it up to work. that’s what got me pissed off - I had done a slew of debugging and it got down to “have you turned off and on again”
                        There’s lots of issues I’ve been having - most of them being internal MM functions, that I tend to work around by native JS code and using remote access via the Web server.
                        For example: Logging. Don’t seem to work for me. Gotta log via console, so I pull up the web server and Edge’s dev tools.
                          sdetweil @BKeyport
                          @BKeyport logging
                          There are two logs
                          Node_helper goes to npm start console
                          Modulename.js goes to the browser log
                          There are a couple modules that will send the browser log records to the console
                          MMM-Logging, mmrize has an updated version, so do I.
                          I don’t know why it worked before, or why it’s not working now.
                          We added some checking for valid position names, instead of crashing
                          We added async to some mm functions, but
                          Timeout and interval are js functions.
                          Only way to debug the browser side is to use the developer window debugger (sources tab)
                            sdetweil @BKeyport
                            @BKeyport I’d be interested in the functions that you are having trouble with, as there are very few.
                            • BKeyportB
                              I think I got it figured out - Based on research elsewhere - if I’m correct: start: function() is only called upon load, correct?
                              ASSUMING that’s the case, this seems to work better:
                                  function scheduleMidnightUpdate() {
                                      const now = new Date();
                                      const nextMidnight = new Date(now);
                                      // Set the time to midnight
                                      nextMidnight.setHours(24, 0, 0, 0);
                                      // Calculate the time remaining until the next midnight
                                      const timeUntilMidnight = nextMidnight - now;
                                      // Schedule the updateDom method to be called at midnight
                                      setTimeout(() => {
                                          this.updateDom();
                                          // Reschedule the update for the next midnight
                                          scheduleMidnightUpdate.call(this);
                                      }, timeUntilMidnight);
                                  // Call the function to start the first schedule
                              Now, This seems to work on testing - but it will fail in testing if I change the clock after starting MM.
                              Is there anyway y’all can see to improve this, or am I good?
                              M 1 Reply Last reply
                                MMRIZE @BKeyport
                                @BKeyport
                                Your DOM might not be rendered yet on “start” imo. I think manipulating DOM after “DOM_OBJECT_CREATED” notification would be safer.
                                  sdetweil @MMRIZE
                                  @MMRIZE
                                  Yes the documented flow is, as I recall on my phone,
                                  Init
                                  Getstyles
                                  Getscripts
                                  GetTemplates
                                  Start
                                  Notification received
                                  AllModulesStarted
                                  DOMobjectsCreated
                                  getDOM
                                  • BKeyportB
                                    @sdetweil @MMRIZE so, should I move the initial call somewhere else?
                                      sdetweil @BKeyport
                                      @BKeyport after the notification
                                      From the doc
                                      DOM_OBJECTS_CREATED - All dom objects are created. The system is now ready to perform visual changes.
                                      • BKeyportB
                                        @sdetweil said in Not updating at midnight...:
                                                setTimeout(() => {
                                                    this.updateDom();
                                            notificationReceived: function (notification, payload, sender) {
                                                if (notification === 'CALENDAR_EVENTS') {
                                                    this.storedEvents = JSON.parse(JSON.stringify(payload))
                                                    this.updateDom();
                                                } else if (notification === 'DOM_OBJECTS_CREATED') {
                                        This is the only source I see in the docs of that - a notification. Is that correct?
                                        Thanks for the patience after the double misunderstanding.
                                          sdetweil @BKeyport
                                          @BKeyport
                                          https://docs.magicmirror.builders/development/core-module-file.html
                                          you could have done all the initial event calculating in one function
                                          used interval for the midnights (as it’s a fixed number)
                                            @BKeyport MODULE_DOM_CREATED means YOUR getDom()/getTemplateData() has been called
