    Recommend a Word of the Day module? (English)
    12 Posts 4 Posters 3.2k Views 4 Watching
      sdetweil @mcgroo
      @mcgroo maybe
      https://github.com/jmwyds/MMM-WordOfTheDay
      • mumblebajM
        mumblebaj Module Developer @mcgroo
        @mcgroo Have a look at this one.
        https://github.com/mumblebaj/MMM-WOTD
        has multiple language support etc.
        B 1 Reply Last reply
          brentmatthews @mumblebaj
          @mumblebaj, is there a way to resize your WOTD module?
          I would like to put it in the bottom bar centre across the entire screen and large enough to be seen from a distance.
          I notice there isn’t a css file, would this be the only way to do it?
          mumblebajM 1 Reply Last reply
          • mumblebajM
            mumblebaj Module Developer @brentmatthews
            @brentmatthews Hi, yes, I did not require a css file for the module. You are welcome to add and submit a pr if you like.
              @mumblebaj thank you. I have very little experience in actually creating a css, let alone doing a pull request.
              I’ll have to do some research and see if I can work it out.
                sdetweil @brentmatthews
                @brentmatthews see this post
                https://forum.magicmirror.builders/post/90135
                  brentmatthews @sdetweil
                  @sdetweil Thank you. I had seen that in passing when first on this forum, but certainly have a bit more understanding on that post now so I shall utilise it as best I can.
                    @brentmatthews ask questions when needed
                    B 2 Replies Last reply
                      @sdetweil I just found the scaling code for css and did it that way with a few position adjustments. Going to play with the fonts a little to maybe make it a touch cleaner looking and not all bold. Photo included.
                      Still playing around with the weather module at the top to get it exactly how I want it also. This css is fun.
                        20240811_013320.jpg I
                        Reply Quote 2
                          @brentmatthews said in Recommend a Word of the Day module? (English):
                          This css is fun
                          lol… not many of us think that!.. (including me)
                          glad you are making progress
