    Easier Custom region work...
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    2 Posts 2 Posters 2.2k Views 3 Watching
    • BKeyportB
      BKeyport Module Developer
      Would it be possible to change the core in such a way to create a customizable region work easier?
      What I’d like to see is the index.html and css work together better so to allow the user via another config file/css file/whatever to define their own regions, overriding the regions defined within the base.
      This would be able to allow us, for example, set up 5 vertical/3 horizontals, or whatever - making the most of the space of our monitors - and/or making portrait mode a ton easier to work with.
      As it is now, I do believe the index.html has to be modified along with the CSS and a bunch of other tweaks… seems too complex for most.
        sdetweil @BKeyport
        @BKeyport I just pushed some changes for the next release to autodetect the custom regions in index.html and use those for validating and using in config.js
        (and npm run check:config)
