    MMM-WifiPassword, oudated ?
    25 Posts 2 Posters 1.6k Views 2 Watching
      sdetweil @Jben1969
      @Jben1969 can you show me the git clone command string you are using
        Jben1969 @sdetweil
        First I try this
        git clone https://github.com/TeraTech/MMM-WiFiPassword.git
        The download starts, but short after the download there is the question about the username and after that the password.
        The same when I tried the second method
        git clone git@github.com:TeraTech/MMM-WiFiPassword.git
        Can you try it on your raspberry / magicmirror?
        Thx
        Jochen
          sdetweil @Jben1969
          @Jben1969 i tried it without problems
          can you login to github before trying the git clone
            Jben1969 @sdetweil
            @sdetweil Hello, many thanks. I tried it and now I have no Problems with the download. The module runs. Whatever I have made a mistake.
            Thank you
            Jochen
              sdetweil @Jben1969
              @Jben1969 said in MMM-WifiPassword, oudated ?:
              Thank you
              Jochen
              mistake?
                Jben1969 @sdetweil
                @sdetweil I don’t know the mistake I made when I install the module, but now I have another problem, the instalation was alright, but I can’t see the QR Code anywhere. I have no special characters or something in my password or SSID. I copied the array from the README.md into my config.
                Any idea ?
                Jochen
                  sdetweil @Jben1969
                  @Jben1969 can you show me that part of your config.js
                    Jben1969
                    		module: 'MMM-WiFiPassword',
                        //See 'Configuration options' for more information.
                        network: "FRITZBoxGzugang",
                        password: "Xxxxxxxxxxx",
                    		*this I tried before*
                    // module: “MMM-WiFiPassword”,
                    // position: “top_right”,
                    // header: “Gastzugang”,
                    // config: {
                    // qrSize : 100,
                    // authType: “WPA”,
                    // network: “FRITZBoxGzugang”,
                    // password: “Xxxxxxxxxxx”,
                    // debug: true,
                      sdetweil @Jben1969
                      @Jben1969 I used your config above and see this
                      one question… each area is a stack, top down,
                      if there are too many modules in a position, it will be clipped at the bottom of the screen
                      I put the module as the first in the modules list. try that
                        Jben1969 @sdetweil
                        @sdetweil well, I tried, your suggestion but the Wifi QR won´t appear, can you help me to debug the config, or can you tell me where I can find the debug protocol ?
                        Jochen
