    MMM-WifiPassword, oudated ?
    25 Posts 2 Posters 2.3k Views 2 Watching
      sdetweil @Jben1969
      @Jben1969 i just tested that both logged in and not
      can you show the link you are using, and describe where you got it from?
        Jben1969 @sdetweil
        I get it from github, https://github.com/TeraTech/MMM-WiFiPassword, and I follow the installation guide.
        "Installation
        In your terminal, change to your Magic Mirror module directory
        cd ~/MagicMirror/modules
        Clone this repository git clone git@github.com:TeraTech/MMM-WiFiPassword.git OR git clone https://github.com/TeraTech/MMM-WiFiPassword.git"
        Then, in terminal, I should enter username an password. I tried my github isername and password, but I think my account is not, what is recommend.
        Jochen
          sdetweil @Jben1969
          @Jben1969 can you show me the git clone command string you are using
            Jben1969 @sdetweil
            First I try this
            The download starts, but short after the download there is the question about the username and after that the password.
            The same when I tried the second method
            Can you try it on your raspberry / magicmirror?
            Thx
            Jochen
              sdetweil @Jben1969
              @Jben1969 i tried it without problems
              can you login to github before trying the git clone
                Jben1969 @sdetweil
                @sdetweil Hello, many thanks. I tried it and now I have no Problems with the download. The module runs. Whatever I have made a mistake.
                Thank you
                Jochen
                  sdetweil @Jben1969
                  @Jben1969 said in MMM-WifiPassword, oudated ?:
                  Thank you
                  Jochen
                  mistake?
                    Jben1969 @sdetweil
                    @sdetweil I don’t know the mistake I made when I install the module, but now I have another problem, the instalation was alright, but I can’t see the QR Code anywhere. I have no special characters or something in my password or SSID. I copied the array from the README.md into my config.
                    Any idea ?
                    Jochen
                      sdetweil @Jben1969
                      @Jben1969 can you show me that part of your config.js
                        Jben1969
                        		module: 'MMM-WiFiPassword',
                            //See 'Configuration options' for more information.
                            network: "FRITZBoxGzugang",
                            password: "Xxxxxxxxxxx",
                        		*this I tried before*
                        // module: “MMM-WiFiPassword”,
                        // position: “top_right”,
                        // header: “Gastzugang”,
                        // config: {
                        // qrSize : 100,
                        // authType: “WPA”,
                        // network: “FRITZBoxGzugang”,
                        // password: “Xxxxxxxxxxx”,
                        // debug: true,
                          sdetweil @Jben1969
                          @Jben1969 I used your config above and see this
                          one question… each area is a stack, top down,
                          if there are too many modules in a position, it will be clipped at the bottom of the screen
                          I put the module as the first in the modules list. try that
                            Jben1969 @sdetweil
                            @sdetweil well, I tried, your suggestion but the Wifi QR won´t appear, can you help me to debug the config, or can you tell me where I can find the debug protocol ?
                            Jochen
                              sdetweil @Jben1969
                              @Jben1969 because the module is all in browser., all the logging will be found in the browser developers console tab
                              ctrl-shift-i
                              select the console tab
                              and add some unique part of the module name to the filter field
                              wifi
                              in this case
                                Jben1969
                                Load script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
                                :8080/modules/MMM-Wi…M-WiFiPassword.js:1
                                Failed to load resource: the server responded with a status of 404 (Not Found)
                                localhost/:1 Refused to execute script from ‘http://localhost:8080/modules/MMM-WiFiPassword/MMM-WiFiPassword.js’ because its MIME type (‘text/html’) is not executable, and strict MIME type checking is enabled.
                                loader.js:168 Error on loading script: modules/MMM-WiFiPassword/MMM-WiFiPassword.js
                                  Jben1969
                                  Hi Sam,
                                  I send the message from browser in a separate post, because.
                                  It´s seems that there ios a bug in my configuration.
                                  Look at my other answer please.
                                  thanks
                                  Jochen
                                    sdetweil @Jben1969
                                    @Jben1969 very interesting. We added checks for missing files in this release, so this type error should not occur
                                    Can you do
                                    ls -laF
                                    cd MMM-WifiPassword
                                    ls -laF
                                    And post the results, maybe it’s a permissions problem
                                      Jben1969
                                      raspberry@MagicMirror2:~/MagicMirror/modules $ ls -laF
                                      insgesamt 76
                                      drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 ./
                                      drwxr-xr-x 17 raspberry raspberry 4096 27. Aug 00:23 …/
                                      drwxr-xr-x 10 raspberry raspberry 4096 4. Mai 17:58 default/
                                      drwxr-xr-x 6 raspberry raspberry 4096 4. Mai 17:10 MMM-CalendarExt3/
                                      drwxr-xr-x 5 raspberry raspberry 4096 24. Feb 2024 MMM-CalendarExt3Agenda/
                                      drwxr-xr-x 8 raspberry raspberry 4096 22. Mär 15:27 MMM-Fuel/
                                      drwxr-xr-x 13 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleAssistant/
                                      drwxr-xr-x 5 raspberry raspberry 4096 21. Mär 16:39 MMM-GoogleCalendar/
                                      drwxr-xr-x 5 raspberry raspberry 4096 10. Feb 2024 MMM-GoogleMapsTraffic/
                                      drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-GooglePhotos/
                                      drwxr-xr-x 3 raspberry raspberry 4096 27. Aug 00:12 MMM-GuestWifiQR/
                                      drwxr-xr-x 6 raspberry raspberry 4096 10. Feb 2024 MMM-MQTT/
                                      drwxr-xr-x 4 raspberry raspberry 4096 10. Feb 2024 MMM-OpenmapWeather/
                                      drwxr-xr-x 6 raspberry raspberry 4096 16. Jun 17:44 MMM-OpenWeatherMapForecast/
                                      drwxr-xr-x 10 raspberry raspberry 4096 21. Mär 17:14 MMM-Pir/
                                      drwxr-xr-x 4 raspberry raspberry 4096 23. Feb 2024 MMM-PIR-Sensor/
                                      drwxr-xr-x 10 raspberry raspberry 4096 22. Mär 17:00 MMM-soccer/
                                      drwxr-xr-x 4 raspberry raspberry 4096 18. Feb 2024 MMM-Wallpaper/
                                      drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 MMM-WifiPassword/
                                      raspberry@MagicMirror2:~/MagicMirror/modules $ cd MMM-WifiPassword
                                      raspberry@MagicMirror2:~/MagicMirror/modules/MMM-WifiPassword $ ls -laF
                                      insgesamt 80
                                      drwxr-xr-x 4 raspberry raspberry 4096 5. Sep 12:57 ./
                                      drwxr-xr-x 19 raspberry raspberry 4096 30. Aug 14:22 …/
                                      drwxr-xr-x 8 raspberry raspberry 4096 30. Aug 23:43 .git/
                                      drwxr-xr-x 3 raspberry raspberry 4096 30. Aug 14:22 .github/
                                      -rw-r–r-- 1 raspberry raspberry 6 30. Aug 14:22 .gitignore
                                      -rw-r–r-- 1 raspberry raspberry 1061 30. Aug 14:22 LICENSE
                                      -rw-r–r-- 1 raspberry raspberry 266 30. Aug 14:22 MMM-WiFiPassword.css
                                      -rw-r–r-- 1 raspberry raspberry 4482 5. Sep 12:57 MMM-WiFiPassword.js
                                      -rw-r–r-- 1 raspberry raspberry 13901 30. Aug 14:22 mm.png
                                      -rw-r–r-- 1 raspberry raspberry 19927 30. Aug 14:22 qrcode.min.js
                                      -rw-r–r-- 1 raspberry raspberry 2697 30. Aug 14:22 README.md
                                      -rw-r–r-- 1 raspberry raspberry 804 30. Aug 14:22 WifiPasswordModal.njk
                                        sdetweil @Jben1969
                                        @Jben1969 is MagicMirror running under the raspberry userid?
                                        if using pm2 do
                                        pm2 stop all
                                        then
                                        cd ~/Magicmirror
                                        npm start
                                          @Jben1969 also, what are the MM config.js settings for
                                          address:
                                          port:
                                          ipWhitelist:
                                            sdetweil @Jben1969
                                            @Jben1969 did you get this resolved
