    MagicMirror Failing on Raspberry Pi Zero W Rev 1.1
    43 Posts 3 Posters 14.4k Views 3 Watching
      sdetweil @davidgagne
      @davidgagne the log is empty cause the pm2 app name is used for file names
      D 1 Reply Last reply
        davidgagne @sdetweil
        @sdetweil Hm. I do have a file /.pm2/pm2.log that’s filled with thousands of these:
        2024-08-04T00:35:12: PM2 log: App [MagicMirror:1] exited with code [1] via signal [SIGINT]
        2024-08-04T00:35:13: PM2 log: App [MagicMirror:1] starting in -fork mode-
        2024-08-04T00:35:13: PM2 log: App [MagicMirror:1] online
        2024-08-04T00:35:19: PM2 log: App [MagicMirror:1] exited with code [1] via signal [SIGINT]
        2024-08-04T00:35:19: PM2 log: App [MagicMirror:1] starting in -fork mode-
        2024-08-04T00:35:19: PM2 log: App [MagicMirror:1] online
        2024-08-04T00:35:25: PM2 log: App [MagicMirror:1] exited with code [1] via signal [SIGINT]
        2024-08-04T00:35:25: PM2 log: App [MagicMirror:1] starting in -fork mode-
        2024-08-04T00:35:25: PM2 log: App [MagicMirror:1] online
        The last entry in that file is from 2024-08-04T21:22:04, which is around/about the last time I rebooted the Pi.
        The tail of that log file looks like this:
        2024-08-04T21:16:54: PM2 log: pid=3352 msg=failed to kill - retrying in 100ms
        2024-08-04T21:16:54: PM2 log: Process with pid 3352 still alive after 1600ms, sending it SIGKILL now...
        2024-08-04T21:16:55: PM2 log: App [pm2:0] exited with code [0] via signal [SIGKILL]
        2024-08-04T21:16:55: PM2 log: pid=3352 msg=process killed
        2024-08-04T21:16:56: PM2 log: PM2 successfully stopped
        2024-08-04T21:22:02: PM2 log: ===============================================================================
        2024-08-04T21:22:02: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
        2024-08-04T21:22:02: PM2 log: Time                 : Sun Aug 04 2024 21:22:02 GMT-0400 (Eastern Daylight Time)
        2024-08-04T21:22:02: PM2 log: PM2 version          : 5.4.2
        2024-08-04T21:22:02: PM2 log: Node.js version      : 20.9.0
        2024-08-04T21:22:02: PM2 log: Current arch         : arm
        2024-08-04T21:22:02: PM2 log: PM2 home             : /home/dvg/.pm2
        2024-08-04T21:22:02: PM2 log: PM2 PID file         : /home/dvg/.pm2/pm2.pid
        2024-08-04T21:22:02: PM2 log: RPC socket file      : /home/dvg/.pm2/rpc.sock
        2024-08-04T21:22:02: PM2 log: BUS socket file      : /home/dvg/.pm2/pub.sock
        2024-08-04T21:22:02: PM2 log: Application log path : /home/dvg/.pm2/logs
        2024-08-04T21:22:02: PM2 log: Worker Interval      : 30000
        2024-08-04T21:22:02: PM2 log: Process dump file    : /home/dvg/.pm2/dump.pm2
        2024-08-04T21:22:02: PM2 log: Concurrent actions   : 2
        2024-08-04T21:22:02: PM2 log: SIGTERM timeout      : 1600
        2024-08-04T21:22:04: PM2 log: [Watch] Start watching pm2
        2024-08-04T21:22:04: PM2 log: App [pm2:0] starting in -fork mode-
        2024-08-04T21:22:04: PM2 log: App [pm2:0] online
        And in the /.pm2/logs/ directory I have MagicMirror-error.log, MagicMirror-out.log, pm2-error.log, and pm2-out.log.
        That last one appears to contain what I would have expected to see in the MM-out.log.
        I am not opposed to flashing the drive and starting from scratch if you think I should.
          @davidgagne I really have no idea where you are.
          Flash the legacy image
          Boot , don’t update
          Run my install script
          • butchkemperB
            butchkemper @davidgagne
            @davidgagne The Pi Zero has 512KB memory, the default swapfile size setting is 100KB, and the swapfile is located on the SDcard which is not very fast.
            I would suggest changing the swapfile size to 2048KB by editing /etc/dphys-swapfile and changing CONF_SWAPSIZE=100 to CONF_SWAPSIZE=2048.
            You might consider moving from the SDcard to an SSD which will provide quicker data access and improved security against SDcard failure.
            Lastly, you might consider changing from a Pi Zero to a Pi Zero 2 or something with more processing power. I use a Pi 3 Model A+ with a USB attached SSD and 2048GB swapfile size.
            Butch
            Resistance is not Futile!
            It is voltage divided by current.
            S D 2 Replies Last reply
              sdetweil @butchkemper
              @butchkemper my install script increases the swap file size if its small (200meg or less).
                @sdetweil @butchkemper I just checked that file and it has no CONF_SWAPSIZE variable.
                There is a SWAPSIZE variable set to 1024.
                Is there a chance that @sdetweil’s script misnamed that variable?
                  @davidgagne looks like you win the prize
                  but funny cause it worked!
                    @davidgagne @butchkemper
                    fixed
                    but do
                    free -m
                    from command lineto see how big swap is
                      @butchkemper said in MagicMirror Failing on Raspberry Pi Zero W Rev 1.1:
                      If I connect an SSD via the data port and remove the SIM, will the 0 boot from the SSD? Or is there a way to configure the SIM to have it switch to the SSD or something?
                        @davidgagne pi 0 doesnt support boot from ssd/usb
                        you can make a hybrid, boot from read only sd , run from ssd
                        see
                        https://forums.raspberrypi.com/viewtopic.php?t=251733
                        • 3 / 3
