    Module MMM-OpenWeatherMapForecast is not running
    9 Posts 3 Posters 1.1k Views 3 Watching
    • K Offline
      Klinge
      since some days the module MMM-OpenWeatherMapForecast is not running.
      When I start my MMM with display:0 I got the following messages
      [2024-09-05 08:23:20.846] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast
      [2024-09-05 08:23:20.851] [LOG]   ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
      and
      [2024-09-05 08:23:32.054] [LOG]   [MMM-OpenWeatherMapForecast] 5-Sep-24 08:23 ** ERROR ** null
      In my pm2 error logs I can´t find any error messages
      It would be great if someone had a hint as to why the module is no longer running.
      Thank you in advance.
      Klinge
        sdetweil @Klinge
        @Klinge yeh, that error handler
        do this
        cd to the module folder
        nano node_helper.js
        change line 63 from
        ERROR ** " + error);
        to
        ERROR ** " + response.statusCode);
        then rerun MagicMirror and look at the stdout content in the pm2 logs
        • K Offline
          Klinge @sdetweil
          @sdetweil Thank you for your response.
          When I change the line 63 I got the following error when I start my MMM
          [2024-09-07 09:56:11.233] [ERROR] (node:3736) UnhandledPromiseRejectionWarning: /home/pi/MagicMirror/modules/MMM-OpenWeatherMapForecast/node_helper.js:3
            Node Helper for MMM-OpenWeatherMapForecast.
          SyntaxError: Unexpected identifier 'Helper'
              at internalCompileFunction (node:internal/vm:73:18)
              at wrapSafe (node:internal/modules/cjs/loader:1160:20)
              at Module._compile (node:internal/modules/cjs/loader:1212:27)
              at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
              at Module.load (node:internal/modules/cjs/loader:1098:32)
              at Module._load (node:internal/modules/cjs/loader:945:12)
              at c._load (node:electron/js2c/node_init:2:13672)
              at Module.require (node:internal/modules/cjs/loader:1122:19)
              at require (node:internal/modules/helpers:130:18)
              at loadModule (/home/pi/MagicMirror/js/app.js:187:19)
              at loadModules (/home/pi/MagicMirror/js/app.js:217:10)
              at async App.start (/home/pi/MagicMirror/js/app.js:272:3)
          (Use `electron --trace-warnings ...` to show where the warning was created)
          [2024-09-07 09:56:11.240] [ERROR] (node:3736) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          I checked the line a few times to make sure I hadn’t mistyped it.
          S mumblebajM 2 Replies Last reply Reply Quote 0
            sdetweil @Klinge
            @Klinge looks like you must have have changed something else
            in the module folder do
            git diff
            to see the changes
            • mumblebajM Offline
              mumblebaj Module Developer @Klinge
              @Klinge Just tested the module and it is working fine for me. The module requires a language in the config but it is not in the sample. So you may want to check that. As for the error you are getting, Have you changed anything in line one of the node_helper? The comment section.
              • K Offline
                Klinge @sdetweil
                @sdetweil Ok, I did “git diff” and got the following result
                pi@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherMapForecast $ git diff
                diff --git a/node_helper.js b/node_helper.js
                index 74c92ae..620e2b5 100644
                --- a/node_helper.js
                +++ b/node_helper.js
                @@ -1,4 +1,4 @@
                @@ -60,7 +60,7 @@ module.exports = NodeHelper.create({
                                         self.sendSocketNotification("OPENWEATHER_ONE_CALL_FORECAST_DATA", resp);
                                     } else {
                -                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
                +                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + response.statusCode);
                diff --git a/package-lock.json b/package-lock.json
                index e597610..5fdbf9f 100644
                --- a/package-lock.json
                +++ b/package-lock.json
                @@ -1,51 +1,72 @@
                     "name": "mmm-openweathermapforecast",
                     "version": "1.0.0",
                -    "lockfileVersion": 1,
                +    "lockfileVersion": 3,
                     "requires": true,
                -    "dependencies": {
                -        "debug": {
                +    "packages": {
                +            "name": "mmm-openweathermapforecast",
                +            "version": "1.0.0",
                +            "license": "MIT",
                +            "dependencies": {
                +                "moment": "^2.28.0",
                +                "needle": "^2.5.2"
                +        "node_modules/debug": {
                             "version": "3.2.7",
                             "resolved": "https://registry.npmjs.org/debug/-/debug-3.2.7.tgz",
                             "integrity": "sha512-CFjzYYAi4ThfiQvizrFQevTTXHtnCqWfe7x1AhgEscTz6ZbLbfoLRLPugTQyBth6f8ZERVUSyWHFD/7Wu4t1XQ==",
                -            "requires": {
                +            "dependencies": {
                                 "ms": "^2.1.1"
                -        "iconv-lite": {
                +        "node_modules/iconv-lite": {
                             "version": "0.4.24",
                             "resolved": "https://registry.npmjs.org/iconv-lite/-/iconv-lite-0.4.24.tgz",
                             "integrity": "sha512-v3MXnZAcvnywkTUEZomIActle7RXXeedOR31wwl7VlyoXO4Qi9arvSenNQWne1TcRwhCL1HwLI21bEqdpj8/rA==",
                -            "requires": {
                +            "dependencies": {
                                 "safer-buffer": ">= 2.1.2 < 3"
                +            "engines": {
                +                "node": ">=0.10.0"
                -        "moment": {
                +        "node_modules/moment": {
                             "version": "2.29.1",
                             "resolved": "https://registry.npmjs.org/moment/-/moment-2.29.1.tgz",
                -            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ=="
                +            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ==",
                +            "engines": {
                +                "node": "*"
                -        "ms": {
                +        "node_modules/ms": {
                             "version": "2.1.3",
                             "resolved": "https://registry.npmjs.org/ms/-/ms-2.1.3.tgz",
                             "integrity": "sha512-6FlzubTLZG3J2a/NVCAleEhjzq5oxgHyaCU9yYXvcLsvoVaHJq/s5xXI6/XXP6tz7R9xAOtHnSO/tXtF3WRTlA=="
                -        "needle": {
                +        "node_modules/needle": {
                             "version": "2.5.2",
                             "resolved": "https://registry.npmjs.org/needle/-/needle-2.5.2.tgz",
                             "integrity": "sha512-LbRIwS9BfkPvNwNHlsA41Q29kL2L/6VaOJ0qisM5lLWsTV3nP15abO5ITL6L81zqFhzjRKDAYjpcBcwM0AVvLQ==",
                -            "requires": {
                +            "dependencies": {
                                 "debug": "^3.2.6",
                                 "iconv-lite": "^0.4.4",
                                 "sax": "^1.2.4"
                +            "bin": {
                +                "needle": "bin/needle"
                +            "engines": {
                +                "node": ">= 4.4.x"
                -        "safer-buffer": {
                +        "node_modules/safer-buffer": {
                             "version": "2.1.2",
                             "resolved": "https://registry.npmjs.org/safer-buffer/-/safer-buffer-2.1.2.tgz",
                             "integrity": "sha512-YZo3K82SD7Riyi0E1EQPojLz7kpepnSQI9IyPbHHg1XXXevb5dJI7tpyN2ADxGcQbHG7vcyRHk0cbwqcQriUtg=="
                -        "sax": {
                +        "node_modules/sax": {
                             "version": "1.2.4",
                             "resolved": "https://registry.npmjs.org/sax/-/sax-1.2.4.tgz",
                             "integrity": "sha512-NqVDv9TpANUjFm0N8uM5GxL36UgKi9/atZw+x7YFnQ8ckwFGKrl4xX4yWtrey3UJm5nP1kUbnYgLopqWNSRhWw=="
                Because the colours of the result could be important, I have also included a screenshot as an attachment.
                • K Offline
                  Klinge @mumblebaj
                  @mumblebaj Thank you for your advice. I configured the following line in my config
                  language: "de",
                  and I changed the node.helper as @sdetweil had advised
                    sdetweil @Klinge
                    @Klinge yes, line 1 you accidentally added an extra / to the beginning
                    this makes it a single line comment and the next line becomes active
                    in a diff, red is old, green is new
                    • K Offline
                      Klinge @sdetweil
                      @sdetweil Now I corrected the first line and then I tried to update the module again.
                      What should I say. Now the MMM is running.
                      But now I have on my second mirror another problem. I will open a new post for it.
                      Thank you all for your help :-)
                      • K Klinge has marked this topic as solved on
