    Module MMM-OpenWeatherMapForecast is not running
    9 Posts 3 Posters 894 Views 3 Watching
      sdetweil @Klinge
      @Klinge yeh, that error handler
      do this
      cd to the module folder
      nano node_helper.js
      change line 63 from
      ERROR ** " + error);
      to
      ERROR ** " + response.statusCode);
      then rerun MagicMirror and look at the stdout content in the pm2 logs
      • K Offline
        Klinge @sdetweil
        @sdetweil Thank you for your response.
        When I change the line 63 I got the following error when I start my MMM
        [2024-09-07 09:56:11.233] [ERROR] (node:3736) UnhandledPromiseRejectionWarning: /home/pi/MagicMirror/modules/MMM-OpenWeatherMapForecast/node_helper.js:3
          Node Helper for MMM-OpenWeatherMapForecast.
        SyntaxError: Unexpected identifier 'Helper'
            at internalCompileFunction (node:internal/vm:73:18)
            at wrapSafe (node:internal/modules/cjs/loader:1160:20)
            at Module._compile (node:internal/modules/cjs/loader:1212:27)
            at Module._extensions..js (node:internal/modules/cjs/loader:1311:10)
            at Module.load (node:internal/modules/cjs/loader:1098:32)
            at Module._load (node:internal/modules/cjs/loader:945:12)
            at c._load (node:electron/js2c/node_init:2:13672)
            at Module.require (node:internal/modules/cjs/loader:1122:19)
            at require (node:internal/modules/helpers:130:18)
            at loadModule (/home/pi/MagicMirror/js/app.js:187:19)
            at loadModules (/home/pi/MagicMirror/js/app.js:217:10)
            at async App.start (/home/pi/MagicMirror/js/app.js:272:3)
        (Use `electron --trace-warnings ...` to show where the warning was created)
        [2024-09-07 09:56:11.240] [ERROR] (node:3736) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        I checked the line a few times to make sure I hadn’t mistyped it.
        S mumblebajM 2 Replies Last reply Reply Quote 0
          sdetweil @Klinge
          @Klinge looks like you must have have changed something else
          in the module folder do
          git diff
          to see the changes
          • mumblebajM Offline
            mumblebaj Module Developer @Klinge
            @Klinge Just tested the module and it is working fine for me. The module requires a language in the config but it is not in the sample. So you may want to check that. As for the error you are getting, Have you changed anything in line one of the node_helper? The comment section.
            • K Offline
              Klinge @sdetweil
              @sdetweil Ok, I did “git diff” and got the following result
              pi@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherMapForecast $ git diff
              diff --git a/node_helper.js b/node_helper.js
              index 74c92ae..620e2b5 100644
              --- a/node_helper.js
              +++ b/node_helper.js
              @@ -1,4 +1,4 @@
              @@ -60,7 +60,7 @@ module.exports = NodeHelper.create({
                                       self.sendSocketNotification("OPENWEATHER_ONE_CALL_FORECAST_DATA", resp);
                                   } else {
              -                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
              +                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + response.statusCode);
              diff --git a/package-lock.json b/package-lock.json
              index e597610..5fdbf9f 100644
              --- a/package-lock.json
              +++ b/package-lock.json
              @@ -1,51 +1,72 @@
                   "name": "mmm-openweathermapforecast",
                   "version": "1.0.0",
              -    "lockfileVersion": 1,
              +    "lockfileVersion": 3,
                   "requires": true,
              -    "dependencies": {
              -        "debug": {
              +    "packages": {
              +            "name": "mmm-openweathermapforecast",
              +            "version": "1.0.0",
              +            "license": "MIT",
              +            "dependencies": {
              +                "moment": "^2.28.0",
              +                "needle": "^2.5.2"
              +        "node_modules/debug": {
                           "version": "3.2.7",
                           "resolved": "https://registry.npmjs.org/debug/-/debug-3.2.7.tgz",
                           "integrity": "sha512-CFjzYYAi4ThfiQvizrFQevTTXHtnCqWfe7x1AhgEscTz6ZbLbfoLRLPugTQyBth6f8ZERVUSyWHFD/7Wu4t1XQ==",
              -            "requires": {
              +            "dependencies": {
                               "ms": "^2.1.1"
              -        "iconv-lite": {
              +        "node_modules/iconv-lite": {
                           "version": "0.4.24",
                           "resolved": "https://registry.npmjs.org/iconv-lite/-/iconv-lite-0.4.24.tgz",
                           "integrity": "sha512-v3MXnZAcvnywkTUEZomIActle7RXXeedOR31wwl7VlyoXO4Qi9arvSenNQWne1TcRwhCL1HwLI21bEqdpj8/rA==",
              -            "requires": {
              +            "dependencies": {
                               "safer-buffer": ">= 2.1.2 < 3"
              +            "engines": {
              +                "node": ">=0.10.0"
              -        "moment": {
              +        "node_modules/moment": {
                           "version": "2.29.1",
                           "resolved": "https://registry.npmjs.org/moment/-/moment-2.29.1.tgz",
              -            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ=="
              +            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ==",
              +            "engines": {
              +                "node": "*"
              -        "ms": {
              +        "node_modules/ms": {
                           "version": "2.1.3",
                           "resolved": "https://registry.npmjs.org/ms/-/ms-2.1.3.tgz",
                           "integrity": "sha512-6FlzubTLZG3J2a/NVCAleEhjzq5oxgHyaCU9yYXvcLsvoVaHJq/s5xXI6/XXP6tz7R9xAOtHnSO/tXtF3WRTlA=="
              -        "needle": {
              +        "node_modules/needle": {
                           "version": "2.5.2",
                           "resolved": "https://registry.npmjs.org/needle/-/needle-2.5.2.tgz",
                           "integrity": "sha512-LbRIwS9BfkPvNwNHlsA41Q29kL2L/6VaOJ0qisM5lLWsTV3nP15abO5ITL6L81zqFhzjRKDAYjpcBcwM0AVvLQ==",
              -            "requires": {
              +            "dependencies": {
                               "debug": "^3.2.6",
                               "iconv-lite": "^0.4.4",
                               "sax": "^1.2.4"
              +            "bin": {
              +                "needle": "bin/needle"
              +            "engines": {
              +                "node": ">= 4.4.x"
              -        "safer-buffer": {
              +        "node_modules/safer-buffer": {
                           "version": "2.1.2",
                           "resolved": "https://registry.npmjs.org/safer-buffer/-/safer-buffer-2.1.2.tgz",
                           "integrity": "sha512-YZo3K82SD7Riyi0E1EQPojLz7kpepnSQI9IyPbHHg1XXXevb5dJI7tpyN2ADxGcQbHG7vcyRHk0cbwqcQriUtg=="
              -        "sax": {
              +        "node_modules/sax": {
                           "version": "1.2.4",
                           "resolved": "https://registry.npmjs.org/sax/-/sax-1.2.4.tgz",
                           "integrity": "sha512-NqVDv9TpANUjFm0N8uM5GxL36UgKi9/atZw+x7YFnQ8ckwFGKrl4xX4yWtrey3UJm5nP1kUbnYgLopqWNSRhWw=="
              Because the colours of the result could be important, I have also included a screenshot as an attachment.
              • K Offline
                Klinge @mumblebaj
                @mumblebaj Thank you for your advice. I configured the following line in my config
                language: "de",
                and I changed the node.helper as @sdetweil had advised
                  sdetweil @Klinge
                  @Klinge yes, line 1 you accidentally added an extra / to the beginning
                  this makes it a single line comment and the next line becomes active
                  in a diff, red is old, green is new
                  • K Offline
                    Klinge @sdetweil
                    @sdetweil Now I corrected the first line and then I tried to update the module again.
                    What should I say. Now the MMM is running.
                    But now I have on my second mirror another problem. I will open a new post for it.
                    Thank you all for your help :-)
                    • K Klinge has marked this topic as solved on
