    Module MMM-OpenWeatherMapForecast is not running
    9 Posts 3 Posters 891 Views 3 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Klinge
      @Klinge Just tested the module and it is working fine for me. The module requires a language in the config but it is not in the sample. So you may want to check that. As for the error you are getting, Have you changed anything in line one of the node_helper? The comment section.
      • K Offline
        Klinge @sdetweil
        @sdetweil Ok, I did “git diff” and got the following result
        pi@raspberrypi:~/MagicMirror/modules/MMM-OpenWeatherMapForecast $ git diff
        diff --git a/node_helper.js b/node_helper.js
        index 74c92ae..620e2b5 100644
        --- a/node_helper.js
        +++ b/node_helper.js
        @@ -1,4 +1,4 @@
           Node Helper for MMM-OpenWeatherMapForecast.
        @@ -60,7 +60,7 @@ module.exports = NodeHelper.create({
                                 self.sendSocketNotification("OPENWEATHER_ONE_CALL_FORECAST_DATA", resp);
                             } else {
        -                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error);
        +                        console.log("[MMM-OpenWeatherMapForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + response.statusCode);
        diff --git a/package-lock.json b/package-lock.json
        index e597610..5fdbf9f 100644
        --- a/package-lock.json
        +++ b/package-lock.json
        @@ -1,51 +1,72 @@
             "name": "mmm-openweathermapforecast",
             "version": "1.0.0",
        -    "lockfileVersion": 1,
        +    "lockfileVersion": 3,
             "requires": true,
        -    "dependencies": {
        -        "debug": {
        +    "packages": {
        +            "name": "mmm-openweathermapforecast",
        +            "version": "1.0.0",
        +            "license": "MIT",
        +            "dependencies": {
        +                "moment": "^2.28.0",
        +                "needle": "^2.5.2"
        +        "node_modules/debug": {
                     "version": "3.2.7",
                     "resolved": "https://registry.npmjs.org/debug/-/debug-3.2.7.tgz",
                     "integrity": "sha512-CFjzYYAi4ThfiQvizrFQevTTXHtnCqWfe7x1AhgEscTz6ZbLbfoLRLPugTQyBth6f8ZERVUSyWHFD/7Wu4t1XQ==",
        -            "requires": {
        +            "dependencies": {
                         "ms": "^2.1.1"
        -        "iconv-lite": {
        +        "node_modules/iconv-lite": {
                     "version": "0.4.24",
                     "resolved": "https://registry.npmjs.org/iconv-lite/-/iconv-lite-0.4.24.tgz",
                     "integrity": "sha512-v3MXnZAcvnywkTUEZomIActle7RXXeedOR31wwl7VlyoXO4Qi9arvSenNQWne1TcRwhCL1HwLI21bEqdpj8/rA==",
        -            "requires": {
        +            "dependencies": {
                         "safer-buffer": ">= 2.1.2 < 3"
        +            "engines": {
        +                "node": ">=0.10.0"
        -        "moment": {
        +        "node_modules/moment": {
                     "version": "2.29.1",
                     "resolved": "https://registry.npmjs.org/moment/-/moment-2.29.1.tgz",
        -            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ=="
        +            "integrity": "sha512-kHmoybcPV8Sqy59DwNDY3Jefr64lK/by/da0ViFcuA4DH0vQg5Q6Ze5VimxkfQNSC+Mls/Kx53s7TjP1RhFEDQ==",
        +            "engines": {
        +                "node": "*"
        -        "ms": {
        +        "node_modules/ms": {
                     "version": "2.1.3",
                     "resolved": "https://registry.npmjs.org/ms/-/ms-2.1.3.tgz",
                     "integrity": "sha512-6FlzubTLZG3J2a/NVCAleEhjzq5oxgHyaCU9yYXvcLsvoVaHJq/s5xXI6/XXP6tz7R9xAOtHnSO/tXtF3WRTlA=="
        -        "needle": {
        +        "node_modules/needle": {
                     "version": "2.5.2",
                     "resolved": "https://registry.npmjs.org/needle/-/needle-2.5.2.tgz",
                     "integrity": "sha512-LbRIwS9BfkPvNwNHlsA41Q29kL2L/6VaOJ0qisM5lLWsTV3nP15abO5ITL6L81zqFhzjRKDAYjpcBcwM0AVvLQ==",
        -            "requires": {
        +            "dependencies": {
                         "debug": "^3.2.6",
                         "iconv-lite": "^0.4.4",
                         "sax": "^1.2.4"
        +            "bin": {
        +                "needle": "bin/needle"
        +            "engines": {
        +                "node": ">= 4.4.x"
        -        "safer-buffer": {
        +        "node_modules/safer-buffer": {
                     "version": "2.1.2",
                     "resolved": "https://registry.npmjs.org/safer-buffer/-/safer-buffer-2.1.2.tgz",
                     "integrity": "sha512-YZo3K82SD7Riyi0E1EQPojLz7kpepnSQI9IyPbHHg1XXXevb5dJI7tpyN2ADxGcQbHG7vcyRHk0cbwqcQriUtg=="
        -        "sax": {
        +        "node_modules/sax": {
                     "version": "1.2.4",
                     "resolved": "https://registry.npmjs.org/sax/-/sax-1.2.4.tgz",
                     "integrity": "sha512-NqVDv9TpANUjFm0N8uM5GxL36UgKi9/atZw+x7YFnQ8ckwFGKrl4xX4yWtrey3UJm5nP1kUbnYgLopqWNSRhWw=="
        Because the colours of the result could be important, I have also included a screenshot as an attachment.
        • K Offline
          Klinge @mumblebaj
          @mumblebaj Thank you for your advice. I configured the following line in my config
          language: "de",
          and I changed the node.helper as @sdetweil had advised
            sdetweil @Klinge
            @Klinge yes, line 1 you accidentally added an extra / to the beginning
            this makes it a single line comment and the next line becomes active
            in a diff, red is old, green is new
            • K Offline
              Klinge @sdetweil
              @sdetweil Now I corrected the first line and then I tried to update the module again.
              What should I say. Now the MMM is running.
              But now I have on my second mirror another problem. I will open a new post for it.
              Thank you all for your help :-)
              • K Klinge has marked this topic as solved on
