    OpenWeatherForecast (API-Key)
    6 Posts 3 Posters 753 Views 3 Watching
      Sceetch
      Hi guys,
      im using the MMM-openWeatherForeast (guess its jclarke0000 version),
      the module is running on two devices with the same API-key.
      The application has not been working for 3 days.
      The screen shows only the loading message all the time on both devices .
      I think the problem is with the API key.
      What module do you guys using now, which is working??
      I have already registered for an api 3.0 key. But i cant find any changes in my account on open weather. Do you know if create a new api key takes a while? in which subpoint can i find it?
        sdetweil @Sceetch
        @Sceetch 1 you need to move up to one of the newer forks.
        1. if you look in the output if npm start you should see a message about trouble from the module
          Sceetch
          Thanks.
          I switched te Module to hirschberger.
          It looks like working.
          Do you know there is a chance to Look how many times currently I call or use the API?
          I can’t find anything in my open weather account?
            sdetweil @Sceetch
            @Sceetch i’m not at my desk rn, but there is a usage page
              MarcLandis Module Developer @Sceetch
              @Sceetch it is under https://home.openweathermap.org/statistics/onecall_30
                Sceetch @MarcLandis
                @MarcLandis
                Thank u very much!
                Kind regards
                • S Sceetch has marked this topic as solved on
