    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 464.2k Views 31 Watching
      sdetweil @MarcLandis
      @MarcLandis great… thanks
      pushed fix to the with_unused_fix branch
      git pull
      git checkout with_unused_fix
      and run the buildschema4 test again
        MarcLandis Module Developer @sdetweil
        throws an error:
        /home/dirk/MagicMirror/modules/MMM-Config/scripts/buildschema4.js:750
        if(module_scripts[m.module] !== undefined ){
        M S 2 Replies Last reply Reply Quote 0
          MarcLandis Module Developer @MarcLandis
          @MarcLandis said in Are you tired of editing config.js, or have trouble doing it, see my new module:
          throws an error:
          fixed it myself but ran into the next exception:
          calling module data converter script for module=compliments
          /home/dirk/MagicMirror/modules/MMM-Config/schemas/compliments_converter.js:24
          		Object.keys(config_data.compliments).forEach(c =>{
          TypeError: Cannot read properties of undefined (reading 'compliments')
              at Object.converter (/home/dirk/MagicMirror/modules/MMM-Config/schemas/compliments_converter.js:24:27)
              at /home/dirk/MagicMirror/modules/MMM-Config/scripts/buildschema4.js:754:49
            @MarcLandis sorry, try again, git pull…
              throws an error:
              I f… up
              After git pull I have an exception in one of my not published modules. Going to check that first.
                @MarcLandis ok i have grandchild lunch at school, back in a couple hours
                  @MarcLandis change this
                  unused_module.module
                  to this
                  unused_module
                    @sdetweil I got the command running. There is also an issue when the default calendar module is not used. I fixed it by changing the following in buildschema4.js line 1050
                    // if the default calendar module is not used, tt will be empty and getValueObject will fail
                        if (tt !== undefined && tt.length > 0) {
                          module_properties = getValueObject(m, tt);
                    Maybe you have a better fix ready :)
                      @MarcLandis thanks git pull on the new branch again …
                      I didn’t see this particular error with the latest
                        @sdetweil the command now works. Now I need to figure out why the socket.io connection isn’t working.
                        Failed to load resource: net::ERR_CONNECTION_REFUSED
                          Wrong URL :)
                          All is working now. Thanks for the help.
                            @MarcLandis what url were you trying? that didn’t work?
                              @sdetweil /modules/MMM-Config/config.html without the port parameter that gets added when using /modules/MMM-Config/review
                                @MarcLandis got it… thx
                                  SteakExpert
                                  Any chance this is still being worked on? Read through this entire thread in hopes I’d be able to solve my problem without bugging (see what I did there?) you, but alas, I did not.
                                  Simply returning the “builder encountered a problem, see MagicMirror messages for info” when I navigate via the QR code.
                                  Would appreciate any help you might be able to supply.
                                  Thank you!
                                    sdetweil @SteakExpert
                                    @SteakExpert yes , so you need to look in the output of npm start
                                      SteakExpert @sdetweil
                                      @sdetweil The only feedback it produces is:
                                      [WARN] You're using a full whitelist configuration allow for all IPs
                                        @SteakExpert are you using pm2?
                                        if so, pm2 logs --lines=xxx
                                        xxx is the most recent lines
                                        there should be a lot more output
                                          @SteakExpert this is my startup
                                          (base) sam@sams:~/MagicMirror.old$ npm start
                                          > magicmirror@2.31.0-develop start
                                          > npm run start:x11
                                          > magicmirror@2.31.0-develop start:x11
                                          [2025-01-03 17:46:17.197] [LOG]   Starting MagicMirror: v2.31.0-develop
                                          [2025-01-03 17:46:17.209] [LOG]   Loading config ...
                                          [2025-01-03 17:46:17.209] [LOG]   config template file not exists, no envsubst
                                          [2025-01-03 17:46:17.348] [INFO]  Checking config file /home/sam/MagicMirror.old/config/config.js ...
                                          [2025-01-03 17:46:17.382] [INFO]  Your configuration file doesn't contain syntax errors :)
                                          [2025-01-03 17:46:17.382] [INFO]  Checking modules structure configuration ...
                                          [2025-01-03 17:46:17.409] [INFO]  Your modules structure configuration doesn't contain errors :)
                                          [2025-01-03 17:46:17.409] [LOG]   Loading module helpers ...
                                          [2025-01-03 17:46:17.462] [LOG]   Initializing new module helper ...
                                          [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-Wallpaper
                                          [2025-01-03 17:46:17.463] [LOG]   No helper found for module: clock.
                                          [2025-01-03 17:46:17.463] [LOG]   Initializing new module helper ...
                                          [2025-01-03 17:46:17.463] [LOG]   Module helper loaded: MMM-EmbedURL
                                          [2025-01-03 17:46:17.527] [LOG]   Initializing new module helper ...
                                          [2025-01-03 17:46:17.527] [LOG]   Module helper loaded: MMM-Config
                                          [2025-01-03 17:46:17.534] [LOG]   Initializing new module helper ...
                                          [2025-01-03 17:46:17.534] [LOG]   Module helper loaded: MMM-HomeAssistantDisplay
                                          [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-CalendarExt3.
                                          [2025-01-03 17:46:17.534] [LOG]   No helper found for module: MMM-page-indicator.
                                          [2025-01-03 17:46:17.535] [LOG]   init module helper SampleModule
                                          [2025-01-03 17:46:17.535] [LOG]   Module helper loaded: SampleModule
                                          [2025-01-03 17:46:17.535] [LOG]   No helper found for module: MMM-pages.
                                          [2025-01-03 17:46:17.572] [LOG]   Initializing new module helper ...
                                          [2025-01-03 17:46:17.572] [LOG]   Module helper loaded: calendar
                                          [2025-01-03 17:46:17.572] [LOG]   All module helpers loaded.
                                          [2025-01-03 17:46:17.574] [LOG]   Starting server on port 8090 ...
                                          [2025-01-03 17:46:17.575] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                          [2025-01-03 17:46:17.867] [LOG]   Server started ...
                                          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Wallpaper
                                          [2025-01-03 17:46:17.867] [LOG]   Starting node helper for: MMM-Wallpaper
                                          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-EmbedURL
                                          [2025-01-03 17:46:17.867] [LOG]   Connecting socket for: MMM-Config
                                          [2025-01-03 17:46:17.868] [INFO]  MMM-Config restart parm ='none'
                                          [2025-01-03 17:46:17.868] [LOG]   command =/home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                                          [2025-01-03 17:46:17.868] [LOG]   Starting module helper:MMM-Config
                                          [2025-01-03 17:46:17.868] [LOG]   execing /home/sam/MagicMirror.old/modules/MMM-Config/test_convert.sh override
                                          [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: MMM-HomeAssistantDisplay
                                          [2025-01-03 17:46:17.875] [LOG]   Connecting socket for: SampleModule
                                          [2025-01-03 17:46:17.875] [LOG]   Starting module helper:SampleModule
                                          [2025-01-03 17:46:17.876] [LOG]   Connecting socket for: calendar
                                          [2025-01-03 17:46:17.876] [LOG]   Starting node helper for: calendar
                                          [2025-01-03 17:46:17.876] [LOG]   Sockets connected & modules started ...
                                          [2025-01-03 17:46:17.876] [LOG]    got port=8300
                                          [2025-01-03 17:46:18.047] [LOG]   Launching application.
                                          [2025-01-03 17:46:18.224] [INFO]  System information:
                                          ### SYSTEM:   manufacturer: System manufacturer; model: System Product Name; virtual: false
                                          ### OS:       platform: linux; distro: Ubuntu; release: 22.04.5 LTS; arch: x64; kernel: 5.15.0-125-generic
                                          ### VERSIONS: electron: 32.2.7; used node: 20.18.1; installed node: 20.18.1; npm: 10.8.2; pm2: 5.4.3
                                          ### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
                                          [3484285:0103/174618.683913:ERROR:nss_util.cc(345)] After loading Root Certs, loaded==false: NSS error code: -8018
                                          [2025-01-03 17:46:18.707] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840963687&to=1666862563687&panelId=6 with error: ERR_NAME_NOT_RESOLVED
                                          (Use `electron --trace-warnings ...` to show where the warning was created)
                                          [2025-01-03 17:46:18.708] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840776401&to=1666862376402&panelId=2 with error: ERR_NAME_NOT_RESOLVED
                                          [2025-01-03 17:46:18.711] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                                          [2025-01-03 17:46:18.799] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_13_MMM-HomeAssistantDisplay' ]
                                          [2025-01-03 17:46:18.830] [INFO]  [MMM-HomeAssistantDisplay] [ 'HomeAssistant connected for module_7_MMM-HomeAssistantDisplay' ]
                                          [2025-01-03 17:46:18.833] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 120000
                                          [2025-01-03 17:46:18.834] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/sdetweil%40gmail.com/private-b01395933cda72021e36fae98c07a186/basic.ics - Interval: 120000
                                          [2025-01-03 17:46:18.834] [LOG]   SampleModule received a socket notification: CONFIG - Payload: [object Object]
                                          [2025-01-03 17:46:18.844] [ERROR] (node:3484285) electron: Failed to load URL: https://dummy:3000/temperaturen?orgId=2&from=1666840667772&to=1666862267772&panelId=4 with error: ERR_NAME_NOT_RESOLVED
                                          [2025-01-03 17:46:18.862] [INFO]  [MMM-HomeAssistantDisplay] [
                                            'Conected to Home Assistant for module_13_MMM-HomeAssistantDisplay after 0 retries'
                                          [2025-01-03 17:46:18.865] [INFO]  [MMM-HomeAssistantDisplay] [
                                            'Conected to Home Assistant for module_7_MMM-HomeAssistantDisplay after 0 retries'
                                          [2025-01-03 17:46:18.873] [LOG]   connection started = connect
                                          [2025-01-03 17:46:18.874] [LOG]   path=/home/sam/MagicMirror.old/modules/MMM-Config/schema3_16467085098090.json
                                          [2025-01-03 17:46:19.102] [INFO]  Calendar-Fetcher: Broadcasting 25 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                          [2025-01-03 17:46:19.635] [INFO]  Calendar-Fetcher: Broadcasting 156 events from https://calendar.google.com/calendar/ical/6/basic.ics.
                                          [2025-01-03 17:46:20.749] [LOG]   stdout: completed
                                          I have MMM-Config debug enabled
                                            @SteakExpert said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                                            yeh, that message was put there to tell you what to do instead of being dead
                                            that means the error trap worked…
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 13 / 15
