    Are you tired of editing config.js, or have trouble doing it, see my new module
    293 Posts 28 Posters 489.8k Views 31 Watching
      MarcLandis Module Developer @sdetweil
      @sdetweil I get the same blank page and the reason is that it errors on buildschema4.js.
      1|MagicMirror² | SyntaxError: Unexpected token ‘:’, …“^^-01-01”::[“Happy n”… is not valid JSON
      1|MagicMirror² | at JSON.parse ()
      1|MagicMirror² | at Object. (/home/dirk/MagicMirror/modules/MMM-Config/scripts/buildschema4.js:1173:14)
      1|MagicMirror² | at Module._compile (node:internal/modules/cjs/loader:1546:14)
      1|MagicMirror² | at Module._extensions…js (node:internal/modules/cjs/loader:1691:10)
      1|MagicMirror² | at Module.load (node:internal/modules/cjs/loader:1317:32)
      1|MagicMirror² | at Module._load (node:internal/modules/cjs/loader:1127:12)
      1|MagicMirror² | at TracingChannel.traceSync (node:diagnostics_channel:315:14)
      1|MagicMirror² | at wrapModuleLoad (node:internal/modules/cjs/loader:217:24)
      1|MagicMirror² | at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:166:5)
      1|MagicMirror² | at node:internal/main/run_main_module:30:49
      The reason is the compliments module:
      compliments: {
      anytime: [“Hey there sexy!”],
      morning: [“Good morning, handsome!”, “Enjoy your day!”, “How was your sleep?”],
      afternoon: [“Hello, beauty!”, “You look sexy!”, “Looking good today!”],
      evening: [“Wow, you look hot!”, “You look nice!”, “Hi, sexy!”],
      “…-01-01”: [“Happy new year!”]
        sdetweil @MarcLandis
        @MarcLandis thanks…
        in July I changed the processing for compliments… it worked before and the new process changed it to a different approach but still works…
        can you do
        in the module folder
        ls schemas -laF
        there should be 4 files related to compliments
        these two handle the correction for the possible . in the js object type
        -rw-rw-r-- 1 sam sam 2882 Jun 29 07:32 compliments_converter.js
        -rw-rw-r-- 1 sam sam 9006 Jul 6 19:14 compliments.schema.json
        and these two that improve the form look and feel and handling
        -rw-rw-r-- 1 sam sam 381 Jun 28 18:01 compliments_extension.css
        -rw-rw-r-- 1 sam sam 1980 Jul 6 19:10 compliments_extension.js
        M 1 Reply Last reply
          -rw-r–r-- 1 dirk dirk 2882 Sep 13 15:23 compliments_converter.js
          -rw-r–r-- 1 dirk dirk 381 Sep 13 15:23 compliments_extension.css
          -rw-r–r-- 1 dirk dirk 1980 Sep 13 15:23 compliments_extension.js
          -rw-r–r-- 1 dirk dirk 9006 Sep 13 15:23 compliments.schema.json
          I just did a fresh install of the module, to test something myself
            @MarcLandis gosh I hate git changing file dates…
            SO, can you do this for me
            in the module folder do
            node scripts/buildschema4.js …/defaults.js debug >somefile.txt 2>&1
            and send me somefile.txt
            I’d have you attach it to an issue, but it shows every line from config.js
            same id at gmail… and issue attachments are public
              @sdetweil I created a new issue on github and uploaded the file after removing some sensitive information.
                @MarcLandis great… thanks
                pushed fix to the with_unused_fix branch
                git pull
                git checkout with_unused_fix
                and run the buildschema4 test again
                  throws an error:
                  /home/dirk/MagicMirror/modules/MMM-Config/scripts/buildschema4.js:750
                  if(module_scripts[m.module] !== undefined ){
                  M S 2 Replies Last reply
                    MarcLandis Module Developer @MarcLandis
                    @MarcLandis said in Are you tired of editing config.js, or have trouble doing it, see my new module:
                    throws an error:
                    fixed it myself but ran into the next exception:
                    calling module data converter script for module=compliments
                    /home/dirk/MagicMirror/modules/MMM-Config/schemas/compliments_converter.js:24
                    		Object.keys(config_data.compliments).forEach(c =>{
                    TypeError: Cannot read properties of undefined (reading 'compliments')
                        at Object.converter (/home/dirk/MagicMirror/modules/MMM-Config/schemas/compliments_converter.js:24:27)
                        at /home/dirk/MagicMirror/modules/MMM-Config/scripts/buildschema4.js:754:49
                      @MarcLandis sorry, try again, git pull…
                        throws an error:
                        I f… up
                        After git pull I have an exception in one of my not published modules. Going to check that first.
                          @MarcLandis ok i have grandchild lunch at school, back in a couple hours
                            @MarcLandis change this
                            unused_module.module
                            to this
                            unused_module
                              @sdetweil I got the command running. There is also an issue when the default calendar module is not used. I fixed it by changing the following in buildschema4.js line 1050
                              // if the default calendar module is not used, tt will be empty and getValueObject will fail
                                  if (tt !== undefined && tt.length > 0) {
                                    module_properties = getValueObject(m, tt);
                              Maybe you have a better fix ready :)
                                @MarcLandis thanks git pull on the new branch again …
                                I didn’t see this particular error with the latest
                                  @sdetweil the command now works. Now I need to figure out why the socket.io connection isn’t working.
                                  Failed to load resource: net::ERR_CONNECTION_REFUSED
                                    Wrong URL :)
                                    All is working now. Thanks for the help.
                                      @MarcLandis what url were you trying? that didn’t work?
                                        @sdetweil /modules/MMM-Config/config.html without the port parameter that gets added when using /modules/MMM-Config/review
                                          @MarcLandis got it… thx
                                            SteakExpert
                                            Any chance this is still being worked on? Read through this entire thread in hopes I’d be able to solve my problem without bugging (see what I did there?) you, but alas, I did not.
                                            Simply returning the “builder encountered a problem, see MagicMirror messages for info” when I navigate via the QR code.
                                            Would appreciate any help you might be able to supply.
                                            Thank you!
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 12 / 15
