    calendar - wrong repeating count when using sliceMultiDayEvents
    17 Posts 2 Posters 2.5k Views 2 Watching
      MarcLandis Module Developer
      @sdetweil I know that parsing ics is a pita, but before I submit an issue at github, I wanted to have a quick discussion here in the forum.
      When using the sliceMultiDayEvents config option the calendar shows an additional day. This is probably caused by the RRule parsing.
      The code that causes this starts here
      BEGIN:VCALENDAR
      PRODID:-//Google Inc//Google Calendar 70.9054//EN
      VERSION:2.0
      CALSCALE:GREGORIAN
      METHOD:PUBLISH
      X-WR-CALNAME:Dirk Test
      X-WR-TIMEZONE:Europe/Berlin
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20240918
      DTEND;VALUE=DATE:20240919
      DTSTAMP:20240916T084410Z
      UID:2crbv1ijljc2kt9jclkgu5hqa0@google.com
      CREATED:20240916T083831Z
      LAST-MODIFIED:20240916T083831Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:1 day single
      TRANSP:TRANSPARENT
      END:VEVENT
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20240919
      DTEND;VALUE=DATE:20240920
      RRULE:FREQ=YEARLY
      UID:6gb19havnq6vp2qput51e5rmml@google.com
      CREATED:20240916T083850Z
      LAST-MODIFIED:20240916T083850Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:1 day repeat
      TRANSP:TRANSPARENT
      END:VEVENT
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20240920
      DTEND;VALUE=DATE:20240922
      UID:06e9u1trbqi3jbvstvq4qqutau@google.com
      CREATED:20240916T083902Z
      LAST-MODIFIED:20240916T083902Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:2 day single
      TRANSP:TRANSPARENT
      END:VEVENT
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20240923
      DTEND;VALUE=DATE:20240925
      RRULE:FREQ=YEARLY
      UID:0ui78rk6hpcv8rmbb6nuonhmgg@google.com
      CREATED:20240916T083919Z
      LAST-MODIFIED:20240916T083919Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:2 day repeat
      TRANSP:TRANSPARENT
      END:VEVENT
      END:VCALENDAR
        sdetweil @MarcLandis
        @MarcLandis said in calendar - wrong repeating count when using sliceMultiDayEvents:
        sliceMultiDayEvents
        thanks for the config
        looking at the results without sliceMultiDayEvents
        I see
        so the parsing was correct, the visual, we only show the start date, even if multi-day
        so both are ‘correct’ tho not informative
        with split day
        I don’t see any difference in the calendar parsing. (add “DEBUG” to the loglevel list in config.js)
        and redirect the npm start output to a file
        Calendar-Fetcher: Broadcasting 4 events from http://localhost:8090/modules/default/calendar/splitdays_test.ics.
        only 4 events… so not calendar parsing,
        the only place the split parm is used is in the front end… calendar.js
        but my output is different than yours.
        I am using the develop branch, coming Oct 1. however I don’t see a documented change here
        this split code was added in 2019…
        also tested on master (2.28.0) with same 4 lines of results
        you can get the develop branch and try it…
        https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
        I just copy/pasted your ics info in a file, unchanged
        I tested with America/Chicago timezone.
          MarcLandis Module Developer @sdetweil
          @sdetweil I am pretty sure it has to do with timezone settings. I am going to test some things on my end.
          btw: I have this problem for a long time and more or less always ignored it.
            MarcLandis Module Developer @MarcLandis
            @MarcLandis so it doesn’t happen when setting the time zone to America/Chicago but it happens for Europe/Berlin.
              @MarcLandis ok. system timezone.
                @MarcLandis interesting…
                change calendar.js 3 places
                give it a try
                change (line 633)
                const maxCount = Math.ceil((event.endDate - 1 - moment(event.startDate, "x").endOf("day").format("x")) / ONE_DAY) + 1;
                to
                const maxCount = Math.round((event.endDate - 1 - moment(event.startDate, "x").endOf("day").format("x")) / ONE_DAY) + 1;
                ceil takes 1.04 to 2, round to 1
                					let midnight
                						= moment(event.startDate, "x")
                							.clone()
                							.startOf("day")
                							.add(1, "day")
                							.endOf('day')  // add this (else its start of day, not end) line 641
                							.format("x");
                and recalc of midmnight (line split like above for clarity) line 654
                	midnight = moment(midnight, "x")
                                                   .add(1, "day")
                                                   .format("x"); // next day
                works in Europe/Berlin and America/Chicago
                2 bugs
                1 count incorrect
                2 loop control
                  @sdetweil this fixes it. The test calendar looks good and my real one with the birthdays (mostly affected one) is perfect. All other events are good too.
                  Thx for your help.
                    @MarcLandis i’ll submit an issue and a pr…
                    and a testcase
                      @MarcLandis
                      submitted PR https://github.com/MagicMirrorOrg/MagicMirror/pull/3543/
                      with new testcase to validate
                      hopefully we will get it into next release Oct 1.
                        @sdetweil Thank you - even it doesn’t make it into the next release I have a way to manually fix it now.
                        • M MarcLandis has marked this topic as solved on
