    Module Error
    6 Posts 3 Posters 971 Views 3 Watching
    • L Offline
      Lockslay
      Hello everyone,
      I have problems with two modules after updating MMM,
      weather and MMM-Globe, both are no longer displayed or weather only shows loading.
      I have just tried to update the modules, but there was no update available.
      Update modules
      /home/user/MagicMirror/modules
      git pull
      I have not changed anything in config.js.
      Can anyone help me and tell me how to get these modules running again?
      npm run config:check
      magicmirror@2.29.0 config:check
      node js/check_config.js
      [2024-10-02 11:11:05.053] [INFO] Checking config file /home/stefan/MagicMirror/config/config.js …
      [2024-10-02 11:11:05.267] [INFO] Your configuration file doesn’t contain syntax errors :)
      [2024-10-02 11:11:05.270] [INFO] Checking modules structure configuration …
      [2024-10-02 11:11:05.517] [INFO] Your modules structure configuration doesn’t contain errors :)
      Translated with DeepL.com (free version)
        sdetweil @Lockslay
        @Lockslay
        git pull
        no,
        each module has to be updated separately in each module folder
        can you post the position for both modules?
        we check position names now and don’t launch the module if bad. there is a message put out at startup for each such problem
          sdetweil @Lockslay
          @Lockslay weather. we changed to the supported apikey version(3.0) for openweather. as the old version is discontinued
          the 2.5 apikey doesn’t work there
          • KristjanESPERANTOK Online
            @Lockslay Which MMM-Globe? On the module list are two with that name. Go into the directory of the moule (cd ~\MagicMirror\modules\MMM-Globe) and than run git remote -v to figure it out.
            • L Offline
              Lockslay
              Hello everyone,
              thanks for the answers.
              I went into each module and updated it one by one.
              /MagicMirror/modules/MMM-Globe $ git remote -v
              origin https://github.com/LukeSkywalker92/MMM-Globe.git (fetch)
              origin https://github.com/LukeSkywalker92/MMM-Globe.git (push)
              I set up a new API at openweather, but that doesn’t work either and I couldn’t see if it was version 3.0. Unfortunately, both modules still do not work.
                sdetweil @Lockslay
                @Lockslay the new apikey was the one with the credit card, right? that is v3
