    Touchscreen Family Dashboard
    touchscreentouch
    51 Posts 26 Posters 61.0k Views 44 Watching
      jalow @sharkbait
      @sharkbait said in Touchscreen Family Dashboard:
      How did you manage to increase the font-size of the calendar month heading (SEPTEMBER 2023)?
      I added in the custom css:
      .MMM-CalendarExt3 .module-header {
      font-size: [changes here]
      [other options you’d like to change]
        sharkbait @jalow
        @jalow Thank you. It worked.
        • W
          wswenson
          I would love to see your configuration and CSS files for this layout - looks really clean.
          Walter
          E 1 Reply Last reply
            reverendz
            This is amazing! Thank you.
            Do you know if the Google calendar option works with iCal/iCloud calendar?
              roysim11 @jalow
              @jalow
              Could you elaborate on the changes you made to be able to be able add/edit/delete calendar entries in EXT3?
              I’m able to get the pop up to add events and the events add to the main calendar. I’m stuck tho, as I can’t edit or delete these events.
              A wishlist would be able to add events to some of the other linked calendars I have. I’m also stuck and can’t get the MMM-SimpleKeyboard to open. I’m running the magic mirror through server mode and view through a website and just use an attached wired keyboard for the time being.
              Thanks for any help!
              • E
                elwood1982uk @wswenson
                @wswenson @tjat i’d also love to see the original files. I’m very much a noob here. I’ve tried downloading and installing all the modules but it just looks like the default mm screen -how do I configure/edit to look like yours, etc, please?
                • E
                  elwood1982uk @roysim11
                  Man I thought I was the only person on the internet who wanted a family dashboard that was interactive (ie to enter events on Google calendar -not just view them!). I’ve got the RPI and touch screen (Hannspree 23") sorted but with no real knowledge of coding or magic mirror modules was at a loss. I will be looking through your posts/git in more detail then I next get time! Thanks!
                  M 1 Reply Last reply
                    mdiorio @elwood1982uk
                    @elwood1982uk
                    I was having issues with the calendar swipe feature not working. The keypress would work fine though. Looks like the new version of Electron has removed touchevents and changed to pointerdown and pointerup.
                    I forked the original and made the changes: https://github.com/B3DTech/MMM-KeyPress
                    I’m looking at cleaning up code in the add event module to remove some of the hard-coded customizations in the original. They are very much customized to the original creator with family names and icons hard coded. For the most part, that isn’t needed in a general framework for just adding events.
                    I am also looking at merging the code into the latest version of MMM-CalendarExt3 since it’s so far behind now.
                    It’s a slow work in progress. If anyone else has some time and wants to help out let me know.
                      sdetweil @mdiorio
                      @mdiorio electron still will provide touch events provided the underlying screen service does…
                      did you change OS levels since it last appeared to work?
                      they have changed the window manager twice in the last year.
                      Original was X11
                      last year introduced Wayland
                      this Oct introduced Labwc
                        mdiorio @sdetweil
                        @sdetweil said in Touchscreen Family Dashboard:
                        First time I’m using it is this week, so it would appear I’m using labwc.
                        All I know is that the old KeyPress module wasn’t working and doing a console debug in electron was showing no touchevents being sent, only pointer events.
                          sdetweil @mdiorio
                          @mdiorio you can change back to x11 using the raspi-config app
                            mdiorio @sdetweil
                            @sdetweil Why would I change back when my code works with the current version. General concept MM should be don’t require a crap ton of customization just to make it work. Making users who may want to use this switch to a different windowing system doesn’t really make sense. Especially since I’m sure RPi will eventually remove X11.
                              sdetweil @mdiorio
                              @mdiorio because it is new and not working in many cases yet
                              if you want it to work now, your only choice is to move back
                              you said your code does not work, touch doesnt
                              • E
                                elwood1982uk
                                Hi all. Back after Xmas break. I’m still very new to this and not entirely sure where to begin. Before Xmas I tried downloading the files provided (thanks!) but can’t get it to work. Any chance of a noob walkthrough or a link to somewhere that will tell me how to add the modules and get a working touch calendar? Thanks!
                                L 1 Reply Last reply
                                • L
                                  linkiln @elwood1982uk
                                  @elwood1982uk Hi, I’ve got similar problem with touch callendar. I’ve made two changes in https://github.com/B3DTech/MMM-KeyPress module.
                                  In node_helper.js:
                                  step: (direction === “ArrowRight” ? 3 : -3) // 1 to move forward, -1 to move backward
                                  to:
                                  step: (direction === “ArrowRight” ? 1 : -1) // 1 to move forward, -1 to move backward
                                  and second thing uncomment:
                                  // this.sendNotification(‘CX3_GLANCE_CALENDAR’, payload);
                                  After this changes changing calendar start working with touch.
                                  • E
                                    elwood1982uk @linkiln
                                    @linkiln @sdetweil thanks again both. I guess what else I need to know is what modifications I need to make to the original files to get them to work/personalised for my own family? (E.g. where do I change values, names, etc?). I do want to learn but have very limited time so when I get a chance to look at it I get very little time to figure stuff out through trial and error and therefore it’s sitting gathering dust - so any pointers/instructions gratefully received! 😉
                                    • E
                                      elwood1982uk @elwood1982uk
                                      I’m basically going round in circles. Whenever I restart I have to remember everything from before so it’s very slow progress. I’ve just started fresh, using the auto installer (thanks). Took a while to get node/npm to the right version (I’m not sure why the auto installer didn’t?). Now at the point of adding modules but again I’ve run out of time. Could really do with a straightforward walkthrough (I do realise there is lots of info around/on here, but I find it overwhelming to know where to start, or when something goes wrong (long the node version earlier) how to sort it. Just want an editable touch screen Google calendar! 🤪`
                                      S 2 Replies Last reply
                                        sdetweil @elwood1982uk
                                        @elwood1982uk send the ~/install.log to my email…
                                        same id as here at gmail. I’ll fix whatever caused the wrong node…
                                        you DID execute install DIRECTLY from the github page, with copy/paste… right?
                                        you did NOT clone that repo and execute from the copy (cause I update it all the time to keep it current)
                                        which is why it have copiable lines to paste and execute
                                        you did start with the FULL image, not the light… light makes things MUCH more complicated
                                        if you use my backup/restore scripts, then you wouldn’t have to remember the MM setup
                                        https://github.com/sdetweil/MagicMirror-backup-restore
                                        you can add one module, backup
                                        and another backup
                                        (I save versions, so you can get back to any one of them)
                                        but other than that there is no ‘straight forward steps’, do this, then this…
                                        welcome to the learning curve. someone created something new, (touch screen editable calendar)… so there are extra things everywhere…
                                        and a LOT to know…
                                        this is NOT plop a TV on the wall and you’re done…
                                          @elwood1982uk said in Touchscreen Family Dashboard:
                                          google has that already, open the calendar web page… done…
                                          don’t need MagicMirror to do that
                                          • E
                                            elwood1982uk @sdetweil
                                            @sdetweil thanks yes I think that’s what I’ll do but I can’t even get a virtual keyboard working (have tried onboard and another-the name has slipped my mind) -they either don’t pop up or are too big etc. It’s not that I thought it would be easy but I did think I’d at least get it partly done by now 🤪
                                            • 2 / 3
