    MMM-Rugby
    22 Posts 2 Posters 5.2k Views 2 Watching
      manu85340 @mumblebaj
      @mumblebaj ok indeed the top 14 ended in june 2024, I’m waiting for your news, thank you
        @mumblebaj Do you think it’s possible to update it?
        • mumblebajM Offline
          mumblebaj Module Developer @manu85340
          @manu85340 To update what?
            @mumblebaj Update dates! if I change the dates in league_data.json will it work? if I put:
            "season": 2024,
            "current": true,
            "start": "2024-08-18",
            "end": "2025-06-08"
              @manu85340 No. That is not how it works. The module looks at the date of each game and does calculations based on your apiSportDaysPast and apiSportsDaysFuture configs to work out if there is games data to display.
              If I change the apiSportDaysPast config to 124 days then I get data displayed. But after a few days that will disappear again.
              Until a new league season starts you will not have data again. Unless you follow an active league.
                @mumblebaj I don’t know if I understood what you said, but does that mean that I can no longer have the scores and rankings for the top 14 for this season?
                  @manu85340 You can have the rankings but not the scores. As they are out of date, they will not be displayed unless you set the apiSportDaysPast value to say 365 then they will display again.
                    @mumblebaj yes but the championship will not be up to date, the ranking is that of the last season 2023/2024, and the matches if I put:
                    apiSportDaysPast: 365,
                    I would not have the scores of the last meetings, the top 14 started on September 7, 2024 and ends on June 7, 2025
                    thanks for your help
                      @manu85340 I have now looked at the API and it looks like the data has changed. I need to have a look at it a little more. Will advise when I have an update available.
                        @mumblebaj ok, thanks for your work
