    MMM-Rugby
    22 Posts 2 Posters 9.6k Views 2 Watching
      manu85340 @mumblebaj
      @mumblebaj Update dates! if I change the dates in league_data.json will it work? if I put:
      "season": 2024,
      "current": true,
      "start": "2024-08-18",
      "end": "2025-06-08"
      • mumblebajM
        mumblebaj Module Developer @manu85340
        @manu85340 No. That is not how it works. The module looks at the date of each game and does calculations based on your apiSportDaysPast and apiSportsDaysFuture configs to work out if there is games data to display.
        If I change the apiSportDaysPast config to 124 days then I get data displayed. But after a few days that will disappear again.
        Until a new league season starts you will not have data again. Unless you follow an active league.
          @mumblebaj I don’t know if I understood what you said, but does that mean that I can no longer have the scores and rankings for the top 14 for this season?
          • mumblebajM
            @manu85340 You can have the rankings but not the scores. As they are out of date, they will not be displayed unless you set the apiSportDaysPast value to say 365 then they will display again.
              @mumblebaj yes but the championship will not be up to date, the ranking is that of the last season 2023/2024, and the matches if I put:
              apiSportDaysPast: 365,
              I would not have the scores of the last meetings, the top 14 started on September 7, 2024 and ends on June 7, 2025
              thanks for your help
              • mumblebajM
                @manu85340 I have now looked at the API and it looks like the data has changed. I need to have a look at it a little more. Will advise when I have an update available.
                  @mumblebaj ok, thanks for your work
                  • mumblebajM
                    @manu85340 Hi. I have updated the module. You can now do a gitpull and test if all is working ok. There seem to have been an issue with the call that refreshes the league data. Should be working fine now.
                      @mumblebaj hi, i did a git pull but nothing changes
                      • mumblebajM
                        @manu85340 Apologies, please redo the git pull.
                          @mumblebaj It’s ok, you’re the best, will we have to do this manipulation every year?
                          • mumblebajM
                            @manu85340 You should not have to repeat it again.
                              @mumblebaj perfect, thank you
                                Hi @mumblebaj this morning the magic mirror no longer displays the MMM-RUGBY module, do you know if this is normal? Thanks for your help
                                • mumblebajM
                                  @manu85340 Hi. Not normal behavior. Please check if you have any errors in the logs, either PM2 or the terminal if you started the mirror with npm.
