    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 77.5k Views 11 Watching
      sdetweil @capedbuffethero
      @capedbuffethero the pi0 is older armv6l processor, it can only run 32 bit mode. the memory is small on pi0,
      everything that doesn’t fit in memory causes swapping, to the sd card. pi0 has the older slower sd chip.
      so, use the legacy 32 bit image to reduce the footprint
        davidgagne @capedbuffethero
        @capedbuffethero Thanks! Please upvote if you found it valuable. I’m fairly new here and trying to improve my rep so all my posts aren’t held for moderation. :)
        C 1 Reply Last reply
          capedbuffethero @davidgagne
          @davidgagne It appears I need 1 reputation to upvote.
          S 2 Replies Last reply
            @capedbuffethero really? I’ll check on that. didn’t used to be.
            Reply Quote 2
              @capedbuffethero can you try this again… we should have reset this option to 0
              downvote still requires rep of 1 or above…
              • plainbrokeP
                plainbroke @davidgagne
                @davidgagne
                Does it matter that you install firefox-esr
                but in the mm.sh script you just call it firefox ?
                I went to midori to get mine to work it would not recognize the firefox in mm.sh for some reason.
                  sdetweil @plainbroke
                  @plainbroke the package is called firefox-esr
                  the program name is firefox
                  it must be on the path for mm.sh to execute it.
                  I don’t know if installing the package does that.
                  I don’t remember worrying about it
                  the command
                  which firefox
                  should return the full path to the executable if it’s on the path.
                  otherwise you can add its folder onto the path in the .profile or .bashrc scripts
                  that setup the shell environment
                    @davidgagne said in Raspberry Pi Zero W for Magic Mirror:
                    Summary
                    • when running DISPLAY=:0 npm start I got an unexpected error
                    • follow up question: export external_browser=firefox doesn’t this export vanish as soon as my session ends? Do I have to do this every time?
                    • firefox is started and is visible on VNC
                    • firefox is not able to connect to the node server (I guess the node server is not running)
                    Details:
                    When executing this script:
                    on this step: I get this output:
                    myname@raspberrypi:~ $ cd ~/MagicMirror
                    myname@raspberrypi:~/MagicMirror $ export external_browser=firefox
                    myname@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                    > magicmirror@2.27.0 start
                    > ./run-start.sh $1
                    ./run-start.sh: line 79:  8050 Killed                  node serveronly
                    these are the lines that precede line 79:
                        # if user explicitly configured to run server only (no ui local)
                        # OR there is no xwindows running, so no support for browser graphics
                        if [ "$serveronly." == "$true." ] || [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
                          # start server mode,
                          node serveronly
                        else
                          # start the server in the background
                          # wait for server to be ready
                          # need bash for this
                          exec 3< <(node serveronly)
                    if we do export external_browser doesn’t that vanish as soon as the RPI is rebooted or if my session ends?
                    after a while the VNC client showed firefox start, but no URL, then the screen went white, then Firefox said “Unable to connect”
                    then I ran this script, I am tailing logs. What does “fix 'em up” script do
                  • Execute fix'em-up script:
                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                  • the last line is this: pm2 setup completed - Fri Jun 14 21:52:48 PDT 2024
                    cancelling the step DISPLAY=:0 npm start allows me to rerun this step, but the step always ends in failure.
                    UPDATE: “Unable to connect” is because Firefox cannot connect to the node server. VNC can connect without issue! The error is actually an error from the Firefox browser.
                      @capedbuffethero
                      the export is used on the MagicMirror system side. it is paired with the
                      node server execution, which launches MagicMirror without a ui.
                      then when the server is running, run-start.sh launches a browser to connect to the server
                      the export has nothing to do with vnc,
                      it is just used to tell run-start.sh which browser to launch. (on linux, env variables are NOT passed to children processes by default. you have to use the export keyword to enable it, for each env var you want to pass)
                      if you set the MagicMirror config.js.js to
                      address:"0.0.0.0",
                      ipWhitelist:[],
                      then you can use a browser on your phone, Windows, Linux, or Mac system to view MagicMirror directly without vnc
                      the killed message is because you restarted MagicMirror, and run-start.sh found the server instance running already. so it must be stopped and restarted in case you changed the config
                      • F
                        funkdafied
                        Hello all giving MM a try again on a Rpi zero and have been trying to run the script in this thread but keeping getting the following message
                        Am I missing something to by pass the Xorg check?
                        OS
                        achild@raspberrypi:~ $ cat /etc/os-release
                        PRETTY_NAME=“Raspbian GNU/Linux 12 (bookworm)”
                        NAME=“Raspbian GNU/Linux”
                        VERSION_ID=“12”
                        VERSION=“12 (bookworm)”
                        VERSION_CODENAME=bookworm
                        ID=raspbian
                        ID_LIKE=debian
                        HOME_URL=“http://www.raspbian.org/”
                        SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
                          sdetweil @funkdafied
                          @funkdafied I have just pushed a fix for that… (was a test for text mode or graphical mode)
                          (and I see I have to expand the test for the Bookworm compositor too,edit: just fixed that too)
                          but it won’t help in your situation…
                          you cannot run MagicMirror on bookworm successfully on a pi0-w, armv6l
                          takes too much memory
                          you need to use the legacy 32 bit image (bullseye)
                          F 1 Reply Last reply
                          • F
                            funkdafied @sdetweil
                            @sdetweil thank you that worked to a point please have a look at the below with the errors I getting:
                              @funkdafied I cannot recreate this…
                              try this to increase the timeout
                              You can extend timeout with those two commands:
                              npm config set fetch-retry-maxtimeout 6000000
                              npm config set fetch-retry-mintimeout 1000000
                              enter image description here
                              Source: https://docs.npmjs.com/cli/v9/using-npm/config#fetch-retry-maxtimeout
                              • F
                                @sdetweil Thank you that did the trick. Only issue I see to be running into at the moment is Midori telling me it can’t find the page it is looking for.
                                  @funkdafied ok,
                                  when you run on a device that doesn’t have electron support, it doesn’t get installed via MM as expected…
                                  then my install script changes the startup to use my run-start.sh script
                                  which launches MagicMirror in server mode
                                  and waits for the ready message
                                  >>>   Ready to go! Please point your browser to: http://0.0.0.0:8080   <<<
                                  and then launches midori like this (with whatever the port number is in the message)
                                  midori http://localhost:8080 -e Fullscreen -e Navigationbar
                                  just for grins can you do
                                  npm start server
                                  to see if that message appears
                                    @funkdafied I think we solved this on discord
                                    M 1 Reply Last reply
                                    • S schris88 referenced this topic on
                                      Mayank Arora @sdetweil
                                      I made a magic mirror in my college time using Raspberry pi 3b+
                                      Integrated google assistant with youtube play also in it.
                                      Now i am graduated and doing job from past 2 years, i am thinking to build one for my home.
                                      Raspberry pi 4 and 5 are expensive, does raspberry pi zero works?
                                      Will google assistant work on it? And youtube also will work on it?
                                      If not youtube, will spotify work on it using pi zero
                                      Which raspberry pi zero will you recommend me
                                        sdetweil @Mayank Arora
                                        @Mayank-Arora you need the pi0-2w at minimum and a fast sd card
                                        The google assistant module is no longer available
                                        Most of the MagicMirror modules for Spotify are display only,
                                        You need the raspotify system service to play ON the PI
                                        YouTube might work, but you have no voice control without GA
                                          roberto84
                                          i’m new to magicmirror,but i’m not able to install it on my raspberry pi zero 2w.
                                          What i did:
                                          -Flashed sd with raspberry pi image, choosing the desktop 64 bit version of raspberry pi os
                                          -Inserted sd to raspberry pi zero 2w
                                          -Installed dphys-swapfile to increase swap to 1 gb
                                          -rebooted raspberry pi zero 2w
                                          -Without any apt-update, i just ran the raspberry.sh script from sdetweil repo here
                                          Unfortunately,it tooks lot of time installing dependencies,more or less 1 hour, this sometimes cause my wifi connection to drop also, due to high i/o.
                                          Is this a normal scenario?could be this due to a bad sd card?
                                          thanks!
                                            sdetweil @roberto84
                                            @roberto84 I do not know. I just installed 64 bit on 02w last week. It is fragile due to the low memory and increased swapping
                                            I can get the surf browser up, but it doesn’t update clock tick on seconds
                                            So I think the 32bit image is the only choice, maybe back to legacy
                                            R 1 Reply Last reply
                                            • 4 / 4
