    Raspberry Pi Zero W for Magic Mirror
    79 Posts 10 Posters 75.7k Views 11 Watching
      capedbuffethero @davidgagne
      @davidgagne said in Raspberry Pi Zero W for Magic Mirror:
      Summary
      • when running DISPLAY=:0 npm start I got an unexpected error
      • follow up question: export external_browser=firefox doesn’t this export vanish as soon as my session ends? Do I have to do this every time?
      • firefox is started and is visible on VNC
      • firefox is not able to connect to the node server (I guess the node server is not running)
      Details:
      When executing this script:
      on this step: I get this output:
      myname@raspberrypi:~ $ cd ~/MagicMirror
      myname@raspberrypi:~/MagicMirror $ export external_browser=firefox
      myname@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.27.0 start
      > ./run-start.sh $1
      ./run-start.sh: line 79:  8050 Killed                  node serveronly
      these are the lines that precede line 79:
          # if user explicitly configured to run server only (no ui local)
          # OR there is no xwindows running, so no support for browser graphics
          if [ "$serveronly." == "$true." ] || [ "$xorg." == "." -a $mac != 'Darwin' -a "$wait_for_x." != "." ]; then
            # start server mode,
            node serveronly
          else
            # start the server in the background
            # wait for server to be ready
            # need bash for this
            exec 3< <(node serveronly)
      if we do export external_browser doesn’t that vanish as soon as the RPI is rebooted or if my session ends?
      after a while the VNC client showed firefox start, but no URL, then the screen went white, then Firefox said “Unable to connect”
      then I ran this script, I am tailing logs. What does “fix 'em up” script do
    • Execute fix'em-up script:
      bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
    • the last line is this: pm2 setup completed - Fri Jun 14 21:52:48 PDT 2024
      cancelling the step DISPLAY=:0 npm start allows me to rerun this step, but the step always ends in failure.
      UPDATE: “Unable to connect” is because Firefox cannot connect to the node server. VNC can connect without issue! The error is actually an error from the Firefox browser.
        sdetweil @capedbuffethero
        @capedbuffethero
        the export is used on the MagicMirror system side. it is paired with the
        node server execution, which launches MagicMirror without a ui.
        then when the server is running, run-start.sh launches a browser to connect to the server
        the export has nothing to do with vnc,
        it is just used to tell run-start.sh which browser to launch. (on linux, env variables are NOT passed to children processes by default. you have to use the export keyword to enable it, for each env var you want to pass)
        if you set the MagicMirror config.js.js to
        address:"0.0.0.0",
        ipWhitelist:[],
        then you can use a browser on your phone, Windows, Linux, or Mac system to view MagicMirror directly without vnc
        the killed message is because you restarted MagicMirror, and run-start.sh found the server instance running already. so it must be stopped and restarted in case you changed the config
        • F Offline
          funkdafied
          Hello all giving MM a try again on a Rpi zero and have been trying to run the script in this thread but keeping getting the following message
          Am I missing something to by pass the Xorg check?
          OS
          achild@raspberrypi:~ $ cat /etc/os-release
          PRETTY_NAME=“Raspbian GNU/Linux 12 (bookworm)”
          NAME=“Raspbian GNU/Linux”
          VERSION_ID=“12”
          VERSION=“12 (bookworm)”
          VERSION_CODENAME=bookworm
          ID=raspbian
          ID_LIKE=debian
          HOME_URL=“http://www.raspbian.org/”
          SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
            sdetweil @funkdafied
            @funkdafied I have just pushed a fix for that… (was a test for text mode or graphical mode)
            (and I see I have to expand the test for the Bookworm compositor too,edit: just fixed that too)
            but it won’t help in your situation…
            you cannot run MagicMirror on bookworm successfully on a pi0-w, armv6l
            takes too much memory
            you need to use the legacy 32 bit image (bullseye)
            • F Offline
              funkdafied @sdetweil
              @sdetweil thank you that worked to a point please have a look at the below with the errors I getting:
                @funkdafied I cannot recreate this…
                try this to increase the timeout
                You can extend timeout with those two commands:
                npm config set fetch-retry-maxtimeout 6000000
                npm config set fetch-retry-mintimeout 1000000
                enter image description here
                Source: https://docs.npmjs.com/cli/v9/using-npm/config#fetch-retry-maxtimeout
                • F Offline
                  @sdetweil Thank you that did the trick. Only issue I see to be running into at the moment is Midori telling me it can’t find the page it is looking for.
                    @funkdafied ok,
                    when you run on a device that doesn’t have electron support, it doesn’t get installed via MM as expected…
                    then my install script changes the startup to use my run-start.sh script
                    which launches MagicMirror in server mode
                    and waits for the ready message
                    >>>   Ready to go! Please point your browser to: http://0.0.0.0:8080   <<<
                    and then launches midori like this (with whatever the port number is in the message)
                    midori http://localhost:8080 -e Fullscreen -e Navigationbar
                    just for grins can you do
                    npm start server
                    to see if that message appears
                      @funkdafied I think we solved this on discord
                      • S schris88 referenced this topic on
                        Mayank Arora @sdetweil
                        I made a magic mirror in my college time using Raspberry pi 3b+
                        Integrated google assistant with youtube play also in it.
                        Now i am graduated and doing job from past 2 years, i am thinking to build one for my home.
                        Raspberry pi 4 and 5 are expensive, does raspberry pi zero works?
                        Will google assistant work on it? And youtube also will work on it?
                        If not youtube, will spotify work on it using pi zero
                        Which raspberry pi zero will you recommend me
                          sdetweil @Mayank Arora
                          @Mayank-Arora you need the pi0-2w at minimum and a fast sd card
                          The google assistant module is no longer available
                          Most of the MagicMirror modules for Spotify are display only,
                          You need the raspotify system service to play ON the PI
                          YouTube might work, but you have no voice control without GA
                            roberto84
                            i’m new to magicmirror,but i’m not able to install it on my raspberry pi zero 2w.
                            What i did:
                            -Flashed sd with raspberry pi image, choosing the desktop 64 bit version of raspberry pi os
                            -Inserted sd to raspberry pi zero 2w
                            -Installed dphys-swapfile to increase swap to 1 gb
                            -rebooted raspberry pi zero 2w
                            -Without any apt-update, i just ran the raspberry.sh script from sdetweil repo here
                            Unfortunately,it tooks lot of time installing dependencies,more or less 1 hour, this sometimes cause my wifi connection to drop also, due to high i/o.
                            Is this a normal scenario?could be this due to a bad sd card?
                            thanks!
                              sdetweil @roberto84
                              @roberto84 I do not know. I just installed 64 bit on 02w last week. It is fragile due to the low memory and increased swapping
                              I can get the surf browser up, but it doesn’t update clock tick on seconds
                              So I think the 32bit image is the only choice, maybe back to legacy
                                roberto84 @sdetweil
                                @sdetweil thanks for reply!
                                So at the end ,retrying several times,I was able to install everything with your script.
                                I installed pm2 also when asked,then I was able to see the default magic mirror display with calendar and so on.
                                Unfortunately this occurred only first time,then at first reboot ,I see from pm2 logs that everything starts,but what I obtain its only a black screen with no modules loaded…
                                Those are some error logs on ps2 when I run ps2 Magic mirror start
                                [4086:0104/075509.190939:ERROR:content/browser/network_service_instance_impl.cc:613] Network service crashed, restarting service.
                                [4086:0104/075554.525130:ERROR:content/browser/network_service_instance_impl.cc:613] Network service crashed, restarting service.
                                [1381:0104/082529.351804:ERROR:content/browser/network_service_instance_impl.cc:613] Network service crashed, restarting service.
                                [1381:0104/082634.504111:ERROR:content/browser/network_service_instance_impl.cc:613] Network service crashed, restarting service.
                                But at the end it starts as you can notice from out logs
                                [2026-01-04 08:24:33.145] [LOG] [app] Sockets connected & modules started …
                                [2026-01-04 08:24:39.175] [LOG] [electron] Launching application.
                                [2026-01-04 08:26:37.186] [INFO] [utils]
                                System Information
                                • SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero 2 W Rev 1.0; virtual: false; MM: 2.34.0
                                • OS: platform: linux; distro: Debian GNU/Linux; release: 13; arch: arm64; kernel: 6.12.47+rpt-rpi-v8
                                • VERSIONS: electron: 39.2.7; used node: 22.21.1; installed node: 22.21.1; npm: 10.9.4; pm2: 6.0.14
                                • ENV: XDG_SESSION_TYPE: tty; MM_CONFIG_FILE: undefined
                                  WAYLAND_DISPLAY: wayland-0; DISPLAY: undefined; ELECTRON_ENABLE_GPU: undefined
                                • RAM: total: 416.15 MB; free: 173.97 MB; used: 242.18 MB
                                • OTHERS: uptime: 4 minutes; timeZone: Europe/Rome
                                this is output of pm2 show MagicMirror
                                Divergent env variables from local env
                                │ PWD │ /home/pi │
                                │ SSH_CONNECTION │ 192.168.1.14 47702 192.168.1.27 22 │
                                │ TERM │ screen.xterm-256color │
                                │ SHLVL │ 3 │
                                │ XDG_SESSION_ID │ 16 │
                                │ SSH_CLIENT │ 192.168.1.14 47702 22 │
                                Also ps2 status report MagicMirror online.
                                One important thing is that I can see MagicMirror contents correctly via the IP on Port 8080
                                What else can I try?
                                I also run your fixuppm.sh script ,but nothing changed.
                                Thanks in advance!
                                  sdetweil @roberto84
                                  @roberto84
                                  The fixuppm2 script just adds pm2 to start if you didn’t do it at install time
                                  as I said it fragile.
                                  I think you have to try using s smaller browser
                                  Like surf
                                  See the section of the readme at the bottom
                                  But I think the only solution is going back to the 32 bit pi os image
                                  • 4 / 4
