    MMM-Pir toggling
    22 Posts 3 Posters 2.3k Views 3 Watching
    • T Offline
      ttt126
      Is it possible to set the relay toggling not only when switching on or off, but during both state changes. So a toggle when switching off and a toggle when switching on.
      The background is that I want to use the relay to operate my standby button on the monitor.
      The relay currently switches off after a set time and switches on again when there is movement. This switches the supply voltage completely. It would be better to leave the power supply permanently connected and only switch the stanby button. But for this you need a change in the state of the relay with every process.
      I couldn’t get it to work in the settings. where can you change the behavior of the relay? mode 6 and mod 7 at the same time so to speak.
      • T Offline
        ttt126
        @ttt126 said in MMM-Pir toggling:
        triggers:[
        trigger: “USER_PRESENCE”,
        fires: [
        exec: (payload) => {
        return "python3 /homr/pi/neu1.py " + payload.option
        The pathon3 comand was missing. I´m not quite firm with programming.
        But a serce for executing a py script brought the answere!
          sdetweil @ttt126
          @ttt126 best to ask the author
          • T Offline
            ttt126
            How can i do so?
            Is he actice on this forum?
              sdetweil @ttt126
              @ttt126 generally youwould open an issue on the module githib page
              @bugsounet can you please add an issues tab to the module? so we can keep track of things like this without you having to troll the forum too…
              • T Offline
                ttt126
                Thanks for your answer. I don’t want to troll anything here.
                On Github I can make a pull request under mmm-pir. I think that’s not the point. I can’t find a new issue there.
                So here are my questions.
                  sdetweil @ttt126
                  @ttt126 troll wasn’t indended for you. he is a busy guy. PIR is busted all over the place with bookworm.
                  • T Offline
                    ttt126
                    Thanks, opened an issue here:
                    https://github.com/KristjanESPERANTO/MagicMirror-3rd-Party-Modules/issues
                    Will see
                    bugsounetB 1 Reply Last reply Reply Quote 0
                    • bugsounetB Offline
                      bugsounet Banned @ttt126
                      MMM-Pir v2 is under coding
                      Unfortunately, it is not possible to use mode 6 and 7 at the same time (same GPIO)
                      This module send USER_PRESENCE notification with trueor false payload (it’s the screen state)
                      You can trigger it with this module MMM-NotificationTrigger and exec a personal script for this
                      Note:
                      • python RPi.GPIO will be deleted (in next release) because there is a compatibility problem with pi5 and with bookworm too.
                      • I will try to recode it with gpiod library for both compatibility
                      • T Offline
                        ttt126
                        Would it be possible to create a mode in which a relay is switched when detected on the PIR and after the new timer has expired.
                        So an on off toggle, so to speak. This would make it possible to switch any monitor using the Stanfby button. HDMI on/off would then not be necessary, simply a relay on the monitor button and all monitors could be used.
                        Unfortunately, I’m not that good at cascading the module.
                        Thank you for your great work
                        • T Offline
                          ttt126
                          Thank you very much, I spent the whole day trying to understand notification triggers and producing a config, unfortunately without success.
                          Maybe you can help me out. how do I do the config so that the trigger can be taken over by mmmpir? I’ve already created a small py script with a gpio pin that goes on and off, it’s in the root directory.
                          But I just can’t get the execut function to be implemented.
                          module: “MMM-NotificationTrigger”,
                          triggers:[
                          fires: [
                          exec: “/neu1.py”
                            sdetweil @ttt126
                            exec: “/neu1.py”
                            that means in the root system folder’if you meant YOUR home folder
                            that would be , replace username with really logged on user for home folder
                            /home/username/neu1.py
                            there may have been messages posted to the MM startup output
                            • T Offline
                              ttt126
                              Even with /home/pi/neu1.py it is not responding.
                              Do I have to devine true and fals state in the config as well?
                                sdetweil @ttt126
                                @ttt126 can you execute the script manually from the terminal window?
                                • T Offline
                                  ttt126
                                  Yes, this I can.
                                  Kliking - exexute, relay klliks on an off once.
                                    sdetweil @ttt126
                                    @ttt126 ok, i was checking for permissions
                                    did you check the messages from npm start location, see if any errors were posted
                                    • T Offline
                                      ttt126
                                      @sdetweil said in MMM-Pir toggling:
                                      npm start location
                                      pi@MagicMirro-2:~/MagicMirror/config $ npm start
                                      magicmirror@2.29.0 start
                                      [2024-10-23 17:12:16.266] [LOG] Starting MagicMirror: v2.29.0
                                      [2024-10-23 17:12:16.334] [LOG] Loading config …
                                      [2024-10-23 17:12:16.341] [LOG] config template file not exists, no envsubst
                                      [2024-10-23 17:12:17.515] [INFO] Checking config file /home/pi/MagicMirror/conf ig/config.js …
                                      [2024-10-23 17:12:17.711] [INFO] Your configuration file doesn’t contain syntax errors :)
                                      [2024-10-23 17:12:17.712] [INFO] Checking modules structure configuration …
                                      [2024-10-23 17:12:17.959] [INFO] Your modules structure configuration doesn’t c ontain errors :)
                                      [2024-10-23 17:12:17.967] [LOG] Loading module helpers …
                                      [2024-10-23 17:12:18.020] [LOG] Initializing new module helper …
                                      [2024-10-23 17:12:18.022] [LOG] Module helper loaded: MMM-Pir
                                      [2024-10-23 17:12:18.026] [LOG] Initializing new module helper …
                                      [2024-10-23 17:12:18.028] [LOG] Module helper loaded: MMM-NotificationTrigger
                                      [2024-10-23 17:12:18.031] [LOG] No helper found for module: alert.
                                      [2024-10-23 17:12:18.042] [LOG] Initializing new module helper …
                                      [2024-10-23 17:12:18.043] [LOG] Module helper loaded: updatenotification
                                      [2024-10-23 17:12:18.044] [LOG] No helper found for module: clock.
                                      [2024-10-23 17:12:18.298] [LOG] Initializing new module helper …
                                      [2024-10-23 17:12:18.299] [LOG] Module helper loaded: calendar
                                      [2024-10-23 17:12:18.300] [LOG] No helper found for module: MMM-WebView.
                                      [2024-10-23 17:12:18.303] [LOG] No helper found for module: weather.
                                      [2024-10-23 17:12:18.306] [LOG] No helper found for module: MMM-RAIN-MAP.
                                      [2024-10-23 17:12:18.488] [LOG] Initializing new module helper …
                                      [2024-10-23 17:12:18.489] [LOG] Module helper loaded: newsfeed
                                      [2024-10-23 17:12:18.490] [LOG] All module helpers loaded.
                                      [2024-10-23 17:12:18.522] [LOG] Starting server on port 8080 …
                                      [2024-10-23 17:12:20.761] [ERROR] Whoops! There was an uncaught exception…
                                      [2024-10-23 17:12:20.816] [ERROR] Error: listen EADDRINUSE: address already in u se ::1:8080
                                      at Server.setupListenHandle [as _listen2] (node:net:1904:16)
                                      at listenInCluster (node:net:1961:12)
                                      at GetAddrInfoReqWrap.doListen [as callback] (node:net:2135:7)
                                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:111:8) {
                                      code: ‘EADDRINUSE’,
                                      errno: -98,
                                      syscall: ‘listen’,
                                      address: ‘::1’,
                                      port: 8080
                                      [2024-10-23 17:12:20.818] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      [2024-10-23 17:12:20.824] [ERROR] If you think this really is an issue, please o pen an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                                      [13489:1023/171222.609717:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.619958:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.622864:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.623145:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.623492:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.623703:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.623989:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.624237:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.624616:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.627519:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.631965:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.632229:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.632531:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.632730:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.634239:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.637235:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.639949:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.643515:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.647036:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.647506:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.648316:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.648593:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.648900:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.649075:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.649295:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.649472:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [13489:1023/171222.649704:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)
                                      [13489:1023/171222.649858:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)
                                      [2024-10-23 17:12:24.158] [INFO] System information:
                                      SYSTEM: manufacturer: ; model: ; virtual: false
                                      OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
                                      VERSIONS: electron: 31.7.1; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
                                      OTHER: timeZone: Europe/Berlin; ELECTRON_ENABLE_GPU: undefined
                                      I think no errors according to the problem.
                                        sdetweil @ttt126
                                        @ttt126 that means you started MM AGAIN…
                                        if you are using PM2, then you need to use the pm2 commands
                                        pm2 status
                                        pm2 stop x
                                        where x is the name or number of the row of the app you want control
                                        and then pm2 start x
                                        or you can do
                                        pm2 restart x
                                        I STRONGLY recommend using manual start while you are developing your mm solution
                                        changing config, adding modules
                                        pm2 stop all
                                        npm start
                                        to stop MM in this mode, hit ctrl-q on the MM screen
                                        if you do this over ssh cause you have no keyboard on the mm system (like me all the time) press ctrl-c in the ssh window where you did npm start
                                        (if you do this when PM2 is controlling, it will do its job, “keep the app running”,
                                        you stop it, and pm2 will restart it… )
                                        • T Offline
                                          ttt126
                                          so this is the aktual config
                                          the command python3 /home/pi/neu1.py is acting the relay if executed in termnal
                                          I use fire and exec both with no action.
                                          maybe there is no trigger natification.
                                          module: "MMM-NotificationTrigger",
        triggers:[
        trigger: "USER_PRESENCE",
        fires: [
        fire:"python3 /home/pi/neu1.py",
                                          • T Offline
                                            ttt126
                                            I got it working, many thanks for your Help :-)
                                              sdetweil @ttt126
                                              @ttt126 what was the issue? might help others in the same predicament
