    MMM-Pir toggling
    22 Posts 3 Posters 1.7k Views 3 Watching
      sdetweil @ttt126
      @ttt126 troll wasn’t indended for you. he is a busy guy. PIR is busted all over the place with bookworm.
      • T Offline
        ttt126
        Thanks, opened an issue here:
        https://github.com/KristjanESPERANTO/MagicMirror-3rd-Party-Modules/issues
        Will see
        bugsounetB 1 Reply Last reply Reply Quote 0
        • bugsounetB Offline
          bugsounet Banned @ttt126
          MMM-Pir v2 is under coding
          Unfortunately, it is not possible to use mode 6 and 7 at the same time (same GPIO)
          This module send USER_PRESENCE notification with trueor false payload (it’s the screen state)
          You can trigger it with this module MMM-NotificationTrigger and exec a personal script for this
          Note:
          • python RPi.GPIO will be deleted (in next release) because there is a compatibility problem with pi5 and with bookworm too.
          • I will try to recode it with gpiod library for both compatibility
          • T Offline
            ttt126
            Would it be possible to create a mode in which a relay is switched when detected on the PIR and after the new timer has expired.
            So an on off toggle, so to speak. This would make it possible to switch any monitor using the Stanfby button. HDMI on/off would then not be necessary, simply a relay on the monitor button and all monitors could be used.
            Unfortunately, I’m not that good at cascading the module.
            Thank you for your great work
            • T Offline
              ttt126
              Thank you very much, I spent the whole day trying to understand notification triggers and producing a config, unfortunately without success.
              Maybe you can help me out. how do I do the config so that the trigger can be taken over by mmmpir? I’ve already created a small py script with a gpio pin that goes on and off, it’s in the root directory.
              But I just can’t get the execut function to be implemented.
              module: “MMM-NotificationTrigger”,
              triggers:[
              trigger: “USER_PRESENCE”,
              fires: [
              exec: “/neu1.py”
                sdetweil @ttt126
                @ttt126 said in MMM-Pir toggling:
                exec: “/neu1.py”
                that means in the root system folder’if you meant YOUR home folder
                that would be , replace username with really logged on user for home folder
                /home/username/neu1.py
                there may have been messages posted to the MM startup output
                • T Offline
                  ttt126
                  Even with /home/pi/neu1.py it is not responding.
                  Do I have to devine true and fals state in the config as well?
                    sdetweil @ttt126
                    @ttt126 can you execute the script manually from the terminal window?
                    • T Offline
                      ttt126
                      Yes, this I can.
                      Kliking - exexute, relay klliks on an off once.
                        sdetweil @ttt126
                        @ttt126 ok, i was checking for permissions
                        did you check the messages from npm start location, see if any errors were posted
