    MM won't launch at startup, but will launch manually
    13 Posts 3 Posters 3.9k Views 3 Watching
      ajgonzales
      I installed MM via sdetweil’s script on Ubuntu 24.04. Everything seems to work fine after installation, but after a reboot MM doesn’t start up. Checking the pm2 logs shows these errors, and then it just keeps looping.
      [35781:0511/163537.061675:ERROR:ozone_platform_x11.cc(244)] Missing X server or $DISPLAY
      [35781:0511/163537.061869:ERROR:env.cc(257)] The platform failed to initialize.  Exiting.
      Authorization required, but no authorization protocol specified
      I can run MM successfully using
      npm start
      from the MagicMirror folder. Any ideas on how I can get it to run at startup?
        majsoft
        Hi, this is how I’m running it for now, maybe it will help someone.
        I will install PM2 according to the instructions
        I will skip the command “pm2 startup”
        After installation i proceed like this
        i will create another boot file
        cd ~
        nano mm_start.sh
        Add the following lines:
        echo Start PM2......
        pm2 start mm.sh
        read;
        set permissions
        chmod +x mm_start.sh
        we will set up the script after booting Ubuntu
        now i can start and stop services at will.
          sdetweil @ajgonzales
          @ajgonzales what user were you logged on as when you can my script?
          can u try to run the fixuppm2 script? last one on the list of my scripts…
          as a user, not root
            @ajgonzales said in MM won't launch at startup, but will launch manually:
            is 24.04 using wayland instead of x11??
            do
            ps -ef | grep -i way
            is a terminal window
            S A 2 Replies Last reply Reply Quote 0
              @ajgonzales I am downloading 24.04 now to test in vm…
                ajgonzales @sdetweil
                was logged in as a user, not root. got the same errors after running the fixuppm2 script and rebooting. here are the results from the other command. looks like it does use wayland:
                aj          2524    2226  0 16:06 tty2     00:00:00 /usr/libexec/gdm-wayland-session env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --session=ubuntu
                aj          2938    2674  0 16:06 ?        00:00:03 /usr/bin/Xwayland :0 -rootless -noreset -accessx -core -auth /run/user/1000/.mutter-Xwaylandauth.QXB9M2 -listenfd 4 -listenfd 5 -displayfd 6 -initfd 7 -byteswappedclients
                aj        393102  390657  0 19:44 pts/0    00:00:00 grep --color=auto -i way
                  @ajgonzales ok thanks.
                    @ajgonzales yep, I can recreate this… so far no hack fix has helped…
                    I now have my system where it won’t finish booting… pm2 is uninstalled…
                    so something is different between UBUNTU and RASPI OS
                    cause we don’t see this problem on raspi
                      ajgonzales
                      In case anyone else has this issue, I was able to able to get it to run via pm2 by running this command first:
                      xhost +si:localuser:[username]
                      Next steps are to figure out how to automatically run that command at startup prior to MM.
                        @ajgonzales add that to the launch script
                        you can find that by doing
                        pm2 status
                        then use the name or number of the row of the app
                        pm2 info x
                        where x is the name or number
                        can you give more info on the system?
                        lsb_release -a
                        uname -a
                          I did try adding the command to the first line of the mm.sh script in the installers folder but that didn’t work. Here’s the sequence I run after rebooting, after which I have no issues.
                          pm2 stop 0
                          pm2 start 0
                          Here’s the output from those other two commands:
                          lsb_release -a
                          No LSB modules are available.
                          Distributor ID: Ubuntu
                          Description:    Ubuntu 24.04 LTS
                          Release:        24.04
                          Codename:       noble
                          uname -a
                          Linux [computername] 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
                            @ajgonzales yeh 24.04
                            pm2 has an issue on 24.04 during boot up. I opened an issue a couple weeks ago.
                            https://github.com/Unitech/pm2/issues/5820
                            I think you are also running the new Wayland display manager…
                            to verify
                            ps -ef | grep wayfire
                            so x11 commands won’t work
                              majsoft
                              cd ~
                              nano mm_start.sh
                              pm2 start mm.sh
                              read;
                              set permissions
                                sdetweil @majsoft
                                @majsoft cool. don’t know if we have that on other systems
                                sometimes if you do
                                sudo npm remove pm2 -g
                                then reboot and run the fixuppm2 script in my scripts list
