    MM won't launch at startup, but will launch manually
    13 Posts 3 Posters 4.5k Views 3 Watching
      sdetweil @ajgonzales
      @ajgonzales what user were you logged on as when you can my script?
      can u try to run the fixuppm2 script? last one on the list of my scripts…
      as a user, not root
        @ajgonzales said in MM won't launch at startup, but will launch manually:
        [35781:0511/163537.061675:ERROR:ozone_platform_x11.cc(244)] Missing X server or $DISPLAY
        is 24.04 using wayland instead of x11??
        do
        ps -ef | grep -i way
        is a terminal window
        S A 2 Replies Last reply
          @ajgonzales I am downloading 24.04 now to test in vm…
          • A
            ajgonzales @sdetweil
            was logged in as a user, not root. got the same errors after running the fixuppm2 script and rebooting. here are the results from the other command. looks like it does use wayland:
            aj          2524    2226  0 16:06 tty2     00:00:00 /usr/libexec/gdm-wayland-session env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --session=ubuntu
            aj          2938    2674  0 16:06 ?        00:00:03 /usr/bin/Xwayland :0 -rootless -noreset -accessx -core -auth /run/user/1000/.mutter-Xwaylandauth.QXB9M2 -listenfd 4 -listenfd 5 -displayfd 6 -initfd 7 -byteswappedclients
            aj        393102  390657  0 19:44 pts/0    00:00:00 grep --color=auto -i way
            S 2 Replies Last reply
              @ajgonzales ok thanks.
                @ajgonzales yep, I can recreate this… so far no hack fix has helped…
                I now have my system where it won’t finish booting… pm2 is uninstalled…
                so something is different between UBUNTU and RASPI OS
                cause we don’t see this problem on raspi
                • A
                  ajgonzales
                  In case anyone else has this issue, I was able to able to get it to run via pm2 by running this command first:
                  xhost +si:localuser:[username]
                  Next steps are to figure out how to automatically run that command at startup prior to MM.
                    @ajgonzales add that to the launch script
                    you can find that by doing
                    pm2 status
                    then use the name or number of the row of the app
                    pm2 info x
                    where x is the name or number
                    can you give more info on the system?
                    lsb_release -a
                    uname -a
                    A 1 Reply Last reply
                    • A
                      I did try adding the command to the first line of the mm.sh script in the installers folder but that didn’t work. Here’s the sequence I run after rebooting, after which I have no issues.
                      pm2 stop 0
                      pm2 start 0
                      Here’s the output from those other two commands:
                      lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Ubuntu
                      Description:    Ubuntu 24.04 LTS
                      Release:        24.04
                      Codename:       noble
                      uname -a
                      Linux [computername] 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
                        @ajgonzales yeh 24.04
                        pm2 has an issue on 24.04 during boot up. I opened an issue a couple weeks ago.
                        https://github.com/Unitech/pm2/issues/5820
                        I think you are also running the new Wayland display manager…
                        to verify
                        ps -ef | grep wayfire
                        so x11 commands won’t work
                        • majsoftM
                          majsoft
                          Hi, this is how I’m running it for now, maybe it will help someone.
                          I will install PM2 according to the instructions
                          I will skip the command “pm2 startup”
                          After installation i proceed like this
                          i will create another boot file
                          cd ~
                          nano mm_start.sh
                          Add the following lines:
                          echo Start PM2......
                          pm2 start mm.sh
                          read;
                          set permissions
                          chmod +x mm_start.sh
                          we will set up the script after booting Ubuntu
                          now i can start and stop services at will.
                          Reply Quote 2
                            sdetweil @majsoft
                            @majsoft cool. don’t know if we have that on other systems
                            sometimes if you do
                            sudo npm remove pm2 -g
                            then reboot and run the fixuppm2 script in my scripts list
