    MM won't launch at startup, but will launch manually
    13 Posts 3 Posters 3.4k Views 3 Watching
      ajgonzales @sdetweil
      was logged in as a user, not root. got the same errors after running the fixuppm2 script and rebooting. here are the results from the other command. looks like it does use wayland:
      aj          2524    2226  0 16:06 tty2     00:00:00 /usr/libexec/gdm-wayland-session env GNOME_SHELL_SESSION_MODE=ubuntu /usr/bin/gnome-session --session=ubuntu
      aj          2938    2674  0 16:06 ?        00:00:03 /usr/bin/Xwayland :0 -rootless -noreset -accessx -core -auth /run/user/1000/.mutter-Xwaylandauth.QXB9M2 -listenfd 4 -listenfd 5 -displayfd 6 -initfd 7 -byteswappedclients
      aj        393102  390657  0 19:44 pts/0    00:00:00 grep --color=auto -i way
        sdetweil @ajgonzales
        @ajgonzales ok thanks.
          @ajgonzales yep, I can recreate this… so far no hack fix has helped…
          I now have my system where it won’t finish booting… pm2 is uninstalled…
          so something is different between UBUNTU and RASPI OS
          cause we don’t see this problem on raspi
            ajgonzales
            In case anyone else has this issue, I was able to able to get it to run via pm2 by running this command first:
            xhost +si:localuser:[username]
            Next steps are to figure out how to automatically run that command at startup prior to MM.
              @ajgonzales add that to the launch script
              you can find that by doing
              pm2 status
              then use the name or number of the row of the app
              pm2 info x
              where x is the name or number
              can you give more info on the system?
              lsb_release -a
              uname -a
                I did try adding the command to the first line of the mm.sh script in the installers folder but that didn’t work. Here’s the sequence I run after rebooting, after which I have no issues.
                pm2 stop 0
                pm2 start 0
                Here’s the output from those other two commands:
                lsb_release -a
                No LSB modules are available.
                Distributor ID: Ubuntu
                Description:    Ubuntu 24.04 LTS
                Release:        24.04
                Codename:       noble
                uname -a
                Linux [computername] 6.8.0-31-generic #31-Ubuntu SMP PREEMPT_DYNAMIC Sat Apr 20 00:40:06 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
                  @ajgonzales yeh 24.04
                  pm2 has an issue on 24.04 during boot up. I opened an issue a couple weeks ago.
                  https://github.com/Unitech/pm2/issues/5820
                  I think you are also running the new Wayland display manager…
                  to verify
                  ps -ef | grep wayfire
                  so x11 commands won’t work
                    majsoft
                    Hi, this is how I’m running it for now, maybe it will help someone.
                    I will install PM2 according to the instructions
                    I will skip the command “pm2 startup”
                    After installation i proceed like this
                    i will create another boot file
                    cd ~
                    nano mm_start.sh
                    Add the following lines:
                    echo Start PM2......
                    pm2 start mm.sh
                    read;
                    set permissions
                    chmod +x mm_start.sh
                    we will set up the script after booting Ubuntu
                    now i can start and stop services at will.
                      sdetweil @majsoft
                      @majsoft cool. don’t know if we have that on other systems
                      sometimes if you do
                      sudo npm remove pm2 -g
                      then reboot and run the fixuppm2 script in my scripts list
